Welcome to the North American Subaru Impreza Owners Club Sunday July 12, 2020
Old 05-15-2018, 08:10 AM   #626
Eli_303
Member#: 482725
2004 Impreza Wrx
Thanks for the reply..
Eli_303 is offline   Reply With Quote
Old 08-11-2018, 07:18 PM   #627
kchaquico
Member#: 490021
2018 STI
Good read, thanks!
kchaquico is offline   Reply With Quote
Old 08-22-2018, 11:54 AM   #628
Keith Lafleur
Member#: 490499
Default Newbie asking for help
Originally Posted by Defiant Autospeed View Post
There are a lot of posts asking what it takes to hit a certain HP number, but almost none of them ever give the info we need to give good advice on this. There is almost never enough info, and a lot of misconceptions.
First thing you need to know is that there is no 100%, black and white, sure thing answer. All cars respond differently and what makes 300whp on one car, will only make 280 on another, and 320 on yet another. ON THE SAME DYNO.
Second thing you need to know is that all dynos read differently. So if your goal is 300whp on a dynapak, what you need to get there will be INCREDIBLY different than what you need to hit 300whp on a Mustang dyno.
Even when looking at the same type of dyno, some read lower and higher.
There is fully a 100whp difference between the highest and lowest reading dynos. So if your goal is 300whp on a Mustang, be prepared to shell out a LOT more money than if you want to hit 300whp on a dynapak. And again, even on the same model dyno, some read +/-15+whp.
Where you live makes a BIG difference, elevation severely changes power output, as does the quality of your local gas. Its a lot harder to hit a given hp level on California's 91 octane than on 93 elsewhere.
When are you doing this? In winter, 20 deg ambient temps on winter mix gas? Or in summer in 100deg temps on summer gas?
And most importantly, are you trying to make this power level at the WHEELS or at the CRANK. Take for instance an 04 STI. It makes 300hp. But only about 240hp at the WHEELS. (on an average dyno that is)
So, when you ask "what do I need to hit XXXhp" you need to give us the following information
1. HP at the WHEELS (whp) or hp at the CRANK (chp)?
2. What type of dyno are you going to be shooting for this number on?
3. If possible, tell us what shop it is. Someone may know how high or low that particular dyno reads.
4. Where do you live? If not a well known city, what is the elevation?
5. What kind of gas will you be using? (octane level)
6. Are you opposed to a FMIC? (this way we dont recommend one if you dont want it, or we DO recommend it if you DO want it and it would be beneficial to your setup/goals) (sp?)
Please note, that even with this info, while we can give you a good idea of what it will take, we cannot give you a 100% surefire recipe for making an exact number. You may make even up to 30hp more or less than your goal based on what we tell you.
However, with the above information, we can give you a pretty solid path to take to hit that goal.
But simply asking "I want XXXhp" will get you nowhere. You will get answers that on a given dyno will make WAY more or less than each other, and the cost difference between them will be huge.
The last thing to know, is that in general, people will give you answers based on an "average" reading dyno. Unless you directly state, "I want to make this power on THIS type of dyno"
Hopefully this helps some people out. I see these posts all the time, and the threads get confusing at best with the huge range of setups that people suggest.
Trying to get around 375 380 horsepower to the wheels I have put a bunch of stuff into it already including DW fuel pump, injector Dynamics 1050 injectors, GrimmSpeed top mount intercooler, GrimmSpeed electronic boost control solenoid, AEM cold air intake, tomie unequal length header with up pipe, nameless catted downpipe and full exhaust, 1 range colder spark plug and professionally tune on a Mustang dyno (ECS Tuning Connecticut) and got 313 horsepower to the wheels and 404 horsepower at the crank... .Does this sound about right can someone help me out do I need to upgrade the turbo and go to E85 to see that kind of power???
Keith Lafleur is offline   Reply With Quote
Old 08-23-2018, 04:41 PM   #629
Chrisjdumas
Member#: 488749
05 STi
In my opinion I would be considerate of the stock motor. I ran 362 wheel on a dyno dynamics on a conservative boost and timing tune and a bearing went... I would keep it in the low 300's until you can build the bottom end. After mine blew up I went all in but I used to think I was fine at 360 but I couldn't settle for a nice daily with 300 hp. I had a lot of similar parts as you have but I would be very careful testing the stock motor. You can find tons of threads about it. Some cars last a week at 300 and some last 50k miles on 400 hp. My personal experience was rod knock at 362/340 lol.
Chrisjdumas is offline   Reply With Quote
Old 11-16-2018, 04:10 PM   #630
truexh
Member#: 493017
Here is my #. Are they Low, High, or just about right?
MODS: ETS Turbo back exhaust, Tomei UEL Header, COBB Flex Fuel Kit, COBB Intake, Grimspeed EBCS, Cobb Fuel Pressure regulator, ID 1300 injectors, IAG AOS, AEM 320 fuel pump.
CAR: 18 WRX STI
Mustang Dynamometer
91 Octane: 286 WHP, 326 WTQ
E85: 321 WHP, 387 WTQ
truexh is offline   Reply With Quote
Old 11-27-2018, 01:26 AM   #631
Tmack2425
Member#: 493909
My E60 2017 WRX Made 380WHP and 370Ftlb Torque.
Full mod list.
E-60 Tune
IAG EGR delete
Pernnin TGV delete
Grimspeed 3 EBC
Mishimoto FMIC
Cobb flex fuel kit
Dw65c fuel pump
Cobb Big SF CAI
3" high flow cat 1320 DP & Mid
STI transmission & Dif
DCCD pro controller
Brembo Brakes
Megan Racing rear control arms
Raceland coilovers
Tmack2425 is offline   Reply With Quote
Old 12-03-2018, 09:19 PM   #632
DinoMagic
Member#: 462387
CAR: 18 WRX STI
Mustang Dynamometer
Sounds just right .. mine was very similar with this setup and stock turbo. Did you get larger injectors for future potential?
DinoMagic is offline   Reply With Quote
Old 12-13-2018, 02:19 PM   #633
Roczz
Member#: 495213
my 06 wrx hit 345 whp with a conservative tune from IAG with:
Engine: Stock
Management: Cobb AP V2
Turbo: Blouch Dom3
IAG 44mm EWG kit with TIAL 44mm EWG
Injectors: ID 1000cc
Intake: KSTech 83mm MegaMAF
Boost Control: Grimmspeed EBCS
Spark Plugs: NGK 1-Step Colder
Exhaust: HKS Exhaust w/ INVIDIA Catless Downpipe
Intercooler: TurboXS FMIC
STi header setup with Grimmspeed high flow crossover
APS 3.0" Turbo Inlet
Turbosmart Dual Port BOV
Fuel Pump: Aeromotive 340lph
Other: Air Pump Deletes, TGV Deletes
Roczz is offline   Reply With Quote
Old 12-28-2018, 07:15 PM   #634
DinoMagic
Member#: 462387
Engine: Stock
Turbo: Blouch Dom3
How much boost are you running? Also why the Dom 3 vs the 1.5
Old 01-12-2019, 02:30 PM   #635
Scrub_Consultant_Q
Member#: 495400
2008 WRX Hatchback
Recently rebuilt my 08 WRX hatch with the following:
  • Manley pistons
  • Stock bore just rehoned
  • King bearings
  • Cobb AP V2
  • Cobb intake
  • Cobb intake tube to turbo
  • New VF52
  • 3in catless downpipe
  • Stock exhaust but not opposed to going to a quiet catback as i'm going for a 'sleeper' build
Still breaking her in and am planning on a tune @ Precision Tuning in NJ at 1k miles. My goal is 300awhp on 93 without sacrificing drivability as I will be dailying the car to and from work and using at a grocery getter.
Is 300 to the wheels with stock exhaust achievable without sacrificing reliability with the parts listed above? If not, what should I add for 300? Injectors? Fuel Pump?
Scrub_Consultant_Q is offline   Reply With Quote
Old 01-15-2019, 12:08 PM   #636
Christiansti
Member#: 496511
Default Dyno
Not sure what my local shop uses
Christiansti is offline   Reply With Quote
Old 01-15-2019, 01:57 PM   #637
Eli_303
Member#: 482725
2004 Impreza Wrx
I could be wrong but the stock exhaust has a bit of restriction in the muffler
Old 01-15-2019, 03:55 PM   #638
Loyale93
Newbie Moderator
Member#: 91347
2004 Tacoma Crew Cab
2012 Triumph 1050
Ok... Great...
No. It doesn't. Not at power levels below 400hp. Above that, maybe you could argue it does, but the stock muffler is fine. May not be ideal, but think about a Stage 2 setup from Cobb. They require a downpipe only, not a full exhaust. And that's getting close to the 400 crank hp number with an OTS tune.
Loyale93 is offline   Reply With Quote
Old 01-15-2019, 05:09 PM   #639
Zcypot
Member#: 372777
2014 WRX Sedan Lmtd
Originally Posted by Loyale93 View Post
Ok... Great...
I had stock mufflers and it didnt seem to affect power when I was "stage 2"
Zcypot is offline   Reply With Quote
Old 01-15-2019, 05:44 PM   #640
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I don't normally do turbo anything.
I will say.......
What is your altitude (high like Denver will yield lower numbers compared to sea level)?
What dyno? Some read higher or lower than others.
What is the calibration on THAT dyno? There are MANY things that can affect the final readings.
What is your fuel? Arizona, California and Nevada tend to suck (part of why COBB has ACN maps for their AP). Summer fuel vs. winter fuel (NY metro is an example) makes a difference.
To me, a dyno is fine for "before/after" mod runs. Basically, I had this, dyno said this, did that, dyno said that.
Compare to others (sorta) from the same dyno.
Do NOT compare to ANY other dyno in any other location.
Old 02-13-2019, 01:48 PM   #641
dud3tt3
Member#: 497730
Default I made 390whp/360wtq with my set up. I expected more?
Hey everyone,
I'm really just looking for some opinions. I recently finished my built motor and dyno tuned up in southern pa on a dyno jet. I only made 390whp/360twq and ran into some issues while tuning and wanted to know your thoughts.
Here's what I have:
Engine:
Built 2.7 Hydra by Element Tuning
100mm Manley pistons
Manley rods
GSC 272 Cams
Stock Crank
TGV Deletes
Super Tech Valvesprings
ARP Head studs
IAT Visconti
AEM 3.5 MAP Sensor
Grimmspeed 3 port EBC
Aeromotive Fuel Rails
Deatschwerks 340LPH Fuel Pump
Injector Dynamics 1050X (1065cc) Injectors
NGK Iridium Spark plugs
Speed Density on Cobb Access Port
Turbo smart BOV
Blouch 1.5 XT-R (Twinscroll)-IWG
3inch Inlet & 10cm hot side
Tomei Expreme Equal Length Headers & Up-pipe (Twinscroll)
Perrin FMIC
ACT Heavy Duty Street Performance Clutch
OEM Fly wheel
(I may be forgetting some things)
Located in Northern Va but tuned up at PSI Proformance in Lansdale PA.
Final Dyno pull on a Dynojet (Jan. 17, 2019)
4th gear 387whp/360tq @ 21PSI on 93 pump
When I first finished this project my goal was to break 400 to the wheels. I was confident with this set up to at least break 400whp and have torque right around the same, even on 93 pump. If I had to actually ballpark it, I expected to make around 420-430whp and 440-450tq.
Down the road, I do want to eventually go with a cobb flex fuel kit to have the ability to run E85, but it's not a necessity at this time.
While tuning we discovered that the IWG was opening up too soon. We also saw on that last pull that my clutch was starting to slip which pretty much concluded my dyno tune. Granted my clutch is relatively new, I have a friend who ran into this same issue with the same clutch. They are supposed to be rated 515tq to the crank, so I was quite surprised to see it not hold any more than 360 to the wheels.
"Wastegate duty cycles were mid 30's on hit to full boost (according to my tuner). The issue he ran into was he was 50-60% up and the turbo was tapering more than usual. If the spring was off it would have a slow PID to full boost. We had the opposite issue. The turbo was tapering more up top than usual, dropping power a tad even when hitting it with lots of WGDCs."
^(I know absolutely nothing when it comes to tuning so I don't fully understand what he's referring to in all of this tuning lingo.)
Now, knowing what I know, I have been contemplating converting to EWG's and knowing that I am twin scroll, I would need a dual ewg set up. It's rather a complex project to complete a dual ewg on a stock location turbo with this setup. A pretty penny is required (as usual with Subarus imo) to fabricate my current up pipe or have one completely fabricated from scratch to accommodate this. I also plan to invest (unfortunately) in yet another clutch that hopefully doesn't give out on me. I might just throw a 6puck disc in and call it a day, but I may also consider switching out to a lightweight flywheel as well.
Curious what are some of your opinions or thoughts on this and I'm open to suggestions on alternative solutions.
Thanks!
dud3tt3 is offline   Reply With Quote
Old 05-17-2019, 10:29 PM   #642
Nitrousspeed
Member#: 183192
2019 STI
World Rally Blue
Default 2019 STI (337.2whp/378.6wtq)
2019 Subaru WRX STI
Modifications List:
- Cobb SF Intake
- APS Dual Vent Blow Off Valve
- GrimmSpeed EBCS
- Turbo XS Downpipe
- Turbo XS Test Pipe
- Remark Blue Tip Exhaust
- Cobb Accessport (V3)
- Protune <- Best thing ever!
- Dialed Mount Accessport Mount
Nitrousspeed is offline   Reply With Quote
Old 05-20-2019, 01:01 PM   #643
nvtive_b
Member#: 500186
2018 Subaru STI
Pure Red
Love this build. looks solid! Makes me wanna start power modding mine!
nvtive_b is offline   Reply With Quote
Old 01-26-2020, 07:08 PM   #644
streetlight1080
Member#: 511105
hey guys im new here to NASIOC and to the Subaru world as well, I love all types of cars but have most experience with honda. I recently bought a 2011 wrx hatch with 33k on it and fell in love. I am not sure if this is the best thread to ask this question so forgive me if it's not. I am curious to know if 280-300hp (whp) is realistic for reliable daily driving and where in the North east area are some good pro-tuners to visit. Thanks.
streetlight1080 is offline   Reply With Quote
Old 02-01-2020, 03:32 PM   #645
gs300cky
Member#: 296248
2005 wrx
wrb
Yes that is definitely an easy to hit number and easy daily driver. I was on about 400awhp and that was still a fun daily until rush hour hit, then my left leg hated me. To hit those numbers you will probably need to add about $1000 of upgrades to hit it.
Starting with intake exhaust header maybe swap to e85 and TUNE IT!!!!
The ecu is not as adaptable as Hondaís are sadly so you need the tune ASAP or once you install each part
gs300cky is offline   Reply With Quote
Old 02-02-2020, 05:43 PM   #646
streetlight1080
Member#: 511105
Thanks for the advice, I have a CBE and plan on installing a downpipe and an intake with the cobb accessport until I can bring it in for a protune. Combine that with some shocks and springs or coilovers. There is so much information out there however there is also a lot of opinions and as I don't really know anyone personally who has modified any turbo Subaru or any Subaru for that matter it's tough to find out what the right thing to do is with certain modifications. I will always love a well setup N/A honda but I fell in love with the boxer engine as well, they just seem to be a bit more delicate from what ive learned so i'm very hesitant about any mod and I want to be absolutely sure before doing anything to the engine.
Old 02-02-2020, 08:38 PM   #647
gs300cky
Member#: 296248
2005 wrx
wrb
Yes there are a lot of opinions and some people get away with some things but most of the time and to be safe, ALWAYS tune for every modification. And yes Subaruís are very delicate in some aspects. My last wrx was pushing 400 and never had a problem, my current wrx is fairly stock and only pushing 285 and my engine already crapped out.
Old 02-02-2020, 10:41 PM   #648
streetlight1080
Member#: 511105
Yeah those are the type of stories that make me nervous, I will just have to start slow and as you said absolutely tune it after every modification. I would even be happy at 285WHP. I'll just have to be ready for anything financially it looks like. It is my daily driver after all. Thanks for the reply.
Old 03-18-2020, 11:26 PM   #649
dogtrumpert
Member#: 418964
2015 wrx
blue
Base + 20% on gas (93) would be safe with tune.
dogtrumpert is offline   Reply With Quote
Old 03-19-2020, 09:42 PM   #650
speedracer48
Member#: 512738
2015 WRX
This is the first time I have used this forum. I have a 2015 Wrx with a K&N typhoon air intake and Nameless muffler deletes. The car came with an SPT/Sti exhaust. I am looking to tune the car to Stage 2 from COBB. Would I need a J-pipe or would the car be fine without the J-pipe?
speedracer48 is offline   Reply With Quote
what do I need to hit 250whp? juvenescence Newbies & FAQs 29 01-15-2019 02:38 PM
What do I need to hit 350-375 HP? pipchick Newbies & FAQs 60 01-15-2019 02:38 PM
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-14-2010 11:49 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 06:43 AM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
