Welcome to the North American Subaru Impreza Owners Club Saturday July 11, 2020
Old 09-21-2015, 12:27 AM   #751
ReconRiehl
Member#: 430487
2005 Impreza WRX
Very insightful. I always wonder if my factory bov is still working properly. There are no apparent problems with it but I feel like a brand new valve with better audible feedback would be more reassuring.
ReconRiehl is offline   Reply With Quote
Old 09-22-2015, 02:14 PM   #752
skeletorr
Member#: 219893
06 wrx
With my first 07 wrx back in 08 as a kid with zero knowledge I added a bov in the beginning, it was alright, then started leaking and the car would stall at low rpm starts. I took it off and went stock BPV for life. My current 06 is running an 18g xtr 10cm and a lot of other mods with the stock bpv perfectly fine. The bpv/bov never seemed like a necessary mod to me and I have almost always run a FMIC too.
skeletorr is offline   Reply With Quote
Old 09-30-2015, 10:35 AM   #753
legacyshlee
Member#: 431210
Default Thanks for the info
Hopefully I didn't overlook my question, but is there any "performance" advantages to running recirc? When would you want one versus the other?
legacyshlee is offline   Reply With Quote
Old 10-07-2015, 07:58 AM   #754
jfisch822
Member#: 404527
2013 WRX hatch
Stage 2+
Recently got a protune on speed density styling tuning for my 13 WRX with 19psi target. My tuner actually recommend an aftermarket valve. I went with GFB because it's hybrid and it was a decent price. I am currently running at 50/50. Spent awhile dialing it in and still get just a very little bit of flutter in low rpm occasionally when I lift. Seems to be working fine. Can't say I notice any performance advantage, just noise.
jfisch822 is offline   Reply With Quote
Old 10-29-2015, 09:03 AM   #755
daceo215
Member#: 433156
2002 Impreza WRX
Great post!
daceo215 is offline   Reply With Quote
Old 11-05-2015, 10:42 AM   #756
mk187
Member#: 329517
Had an HKS BOV on my mr2, loved it and had no issues with it
mk187 is offline   Reply With Quote
Old 11-08-2015, 01:08 AM   #757
angrychair
Member#: 433824
good read!
angrychair is offline   Reply With Quote
Old 11-19-2015, 08:30 AM   #758
Goik727
Member#: 389234
2008 WRX STI Hatch
Great post! I was interested in purchasing an HKS SSQ but I'll probably be rethinking that now.
Goik727 is offline   Reply With Quote
Old 11-21-2015, 12:11 PM   #759
Daves05
Member#: 405713
Anybody have an answer to this, I have a greddy vta blow off valve and I'm having a hell of a time tuning it.... For some reason it tends to stay open after I change gears and leak boost or it's too tight and I get turbo back surge so if there's any tips to find the happy middle ground that would be much appreciated and yes I've tried adjusting the tension on the spring and lighter spring and it seems to not find the sweet spot yet
Daves05 is offline   Reply With Quote
Old 11-21-2015, 12:45 PM   #760
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
Go speed density and you won't have to worry about it.
bmxhotsauce is offline   Reply With Quote
Old 11-21-2015, 01:48 PM   #761
Daves05
Member#: 405713
So I realize my comment didn't give enough description and what I'm doing is not holding my boost under high boost right now and I'm back surgeon one lower boost any ideas
Old 11-23-2015, 07:24 PM   #762
parabola164
Member#: 431747
2011 WRX
Thanks - we're looking to put one on our '11 WRX, but hadn't been able to find a good FAQ yet. Appreciate the good info!
parabola164 is offline   Reply With Quote
Old 11-24-2015, 08:02 PM   #763
Dom_McKee
Member#: 434382
2008 Subaru Wrx
2008 wrx took it to TIC for inspection guy named Eric there told me my BOV was decent but he personally doesn't like them and also notices they make the car produce less power a lot of the time. He closed my BOV it was a 50/50 Go Fast Bits and after he closed it off I realized the car did feel stronger threw the gears and ran a little better. With the right set up and power I think it would be a great thing
Dom_McKee is offline   Reply With Quote
Old 11-27-2015, 01:51 AM   #764
eyim
Member#: 434912
2016 STI Limited
CWP
Thank you for the faq. Good info!
eyim is offline   Reply With Quote
Old 11-30-2015, 06:42 PM   #765
One Slick Trick
Member#: 416542
2015 STI
New to the thread, found this very interesting. Seemed to de-bunk most of the myths associated with BOV. Sounds like there needs to be a device invented to make sure the BOV are not leaking and installed correctly. After all the bad I have read about them I might consider the Cobb 50/50, just for the added noise. After hearing a buddies, as dumb as it is I have always wanted one.
One Slick Trick is offline   Reply With Quote
Old 11-30-2015, 07:22 PM   #766
Clark Turner
Member#: 178047
02 WRX STI Spec C
A pressure test is the way to test if the bov is leaking. You can make a tester cheap or buy one from frozen boost.
Clark Turner is offline   Reply With Quote
Old 12-02-2015, 04:42 AM   #767
Hawky
Member#: 426208
A BOV used to be high on my list but not I think I'll wait until I really think I want one lol. Thanks for the info.
Hawky is offline   Reply With Quote
Old 01-03-2016, 08:52 PM   #768
sea.godz
Member#: 435801
Thankful for threads like this as I get ready for my Subaru journey!
sea.godz is offline   Reply With Quote
Old 01-04-2016, 10:03 AM   #769
acewayne
Member#: 434010
Pretty much the most common thing I saw threads about when I started looking about in this forum. BOV threads and issues everywhere.
acewayne is offline   Reply With Quote
Old 01-19-2016, 02:36 PM   #770
Lilmadmoney01
Member#: 438467
2003 WRX
Lilmadmoney01 is offline   Reply With Quote
Old 01-21-2016, 11:09 PM   #771
zachs2004wrx
Member#: 438600
Default sweet setup
nice rides good info
zachs2004wrx is offline   Reply With Quote
Old 02-15-2016, 07:35 PM   #772
Wylde123
Member#: 440518
Default Great Read
This was a solid write up, you did an excellent job of answering my questions, and making me realize that with the setup I have, its far safer to stay stock.
Wylde123 is offline   Reply With Quote
Old 02-28-2016, 09:58 PM   #773
Capo1016
Member#: 440364
2000 Be5
Originally Posted by Davenow View Post
Dont get me wrong, his FAQs are a huge help. They just need some tweaking to stay current. A lot has changed and much of the info in them is off a bit and in some cases, no longer true at all.
And like I said, I think they are a bit too techy and dont get right to the heart of the issue of directly addressing the common misconceptions on things like intakes and BOVs.
So intakes are good ? I'm confused now,I read on unibom that they are somewhat bad,new to this !
Capo1016 is offline   Reply With Quote
Old 03-02-2016, 01:51 AM   #774
evondahl
Member#: 433801
2015 Subaru WRX
good info to know! thanks!
evondahl is offline   Reply With Quote
Old 03-09-2016, 12:15 PM   #775
Jramirez0484
Member#: 441863
2004 WRX
Default Good post
great post, after all that being said I was wondering then what is the loudest recirculating BOV anyone has encountered.
Jramirez0484 is offline   Reply With Quote
General Subie Newbie FAQ. Lets answer a few common questions and dispell some myths. Defiant Autospeed Newbies & FAQs 60 11-11-2016 01:23 AM
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
The ups and downs of life MGXsport Off-Topic 14 09-10-2007 10:03 PM
S-AFC ups and downs y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-16-2003 05:21 PM
What are the ups and downs of a dog box- any brand? GT2WRX Transmission (AT/MT) & Driveline 23 08-06-2002 08:30 PM
