![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 10830
Vehicle:2002 WRX Silver |
![]() I'm thinking of having a shop install the springs (4) on my 02
wrx wagon. I just have one quote so far from the local dealer. I would appreciate feedback on what people have spent for this labor only since I have the springs already. Also, if anyone has any referrals to good shops in the Portland, Oregon area, I would appreciate it. TIA
#2 |
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
![]() I would guess about $200-$300 not including the alignment. The dealer probably quoted you between $600-$900. Am I close?
#3 |
Member#: 7769
Vehicle:1981 Brat GL AWD World Rally Blue Pearl |
![]() Only cost me $80.00 in SoCal.
#4 |
Member#: 6585
Vehicle:1997 acura integra champion white |
![]() we charge 100.00 here
#5 |
Member#: 10830
![]() The dealer quoted 7 hours at 70 bucks per hour = 490
plus 79 for the alignment. Total of 569. |
#6 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
![]() before i knew what i was doing, i paid to have mine done.
$280 and that was in 1999..... arent there any local Scooby owners near you? some with experience who could help you do this yourself? sure it takes a few hours, but we're talking $$$ here.... alignments are generally $80-100.... good luck Jamie www.subiegal.com |
#7 |
Member#: 4461
NWIC
Vehicle:02 2.slow |
![]() try fast trax.... or ground zero.. or if you wanna come down to eugene, racing trendz. Or do em yourself
#8 |
Member#: 10830
![]() Thanks for your replys and tips. I'll pursue this after the holiday.
Hope you all have a safe New Year! Cheers! |
#9 | |
Member#: 3716
![]() Quote:
Try somewhere else! Chris 2002 WRX |
#10 |
Member#: 10830
![]() Chris,
I looked at the STI strut install in the 'Mods' forum and I am closer to doing this myself. I have air tools and will rent a spring compressor. My only remaining question is: do I have to remove the whole strut assy, or can the spring be installed leaving the bottom of the strut intact? Your help is most appreciated. |
#11 | |
Member#: 3716
![]() Quote:
The brake lines are clipped on on the '02 models so you won't have to go thru all the brake line stuff that is listed in those install instructions. If you decide to do it yourself one word of caution. Be very careful when you are re-installing the struts. The upper strut bolts are weak and only need about 15 ft lbs of torque. I broke one of mine with a hand ratchet. ![]() If you have air tools and have worked on cars before I would defiantly do the install yourself. It's not hard at all. Just think of the mods you could buy with the money you would save. ![]() Chris |
#12 |
Member#: 8945
TXIC
Vehicle:MY02 WRX Blue |
![]() I have to agree with Chris. We put a set of springs on GregUnd's car in around 2 hours using air tools. It's probably the easiest thing I've done to a Subaru. I would definitely take the whole strut out. I'm pretty sure you couldnt do it any other way. You have to get the old spring off and the new one on and I don't think the suspension allows enough movement for that. It's only 2 bolts per strut anyway.
Good Luck, Dustin |
#13 |
Member#: 12445
NWIC
Vehicle:17 WRX Red |
![]() Iv'e done a lot of business with Altasports in Beaverton. Adam and his crew are quick,professional,experienced,and they love Subarus. The hourly labor is quite reasonable.
Call them at 503.649.8781. Ther is also an alignment shop right there in the complex, and Adam usually can get an alignment scheduled the same time as a spring installation. Spend a little for an install, get it right the first time, and let the guys at Altasports skin their knuckles. (P.S. there is a boatload of Subaru parts "in stock" there too !) Please tell them Mike sent you, it'll keep me on their good list, I bug Adam all the time. |
#14 |
Member#: 10830
![]() Chris,
The brake line issue is why I didnt want to remove the struts. Since there is no issue with getting the lines off, I will go ahead and do the install myself after the holiday when I can rent a spring compressor. Thanks for the heads-up on the torque spec for the bolts. Mike, thanks for the Altasports contact. I have heard of them but since I live way out on the eastside, it would be a bit of work for getting transportation to and fro. I will keep them in mind for future work. Thanks again to all and to all a happy New Year! |
#15 |
Member#: 12235
NESIC
Vehicle:2006 WRX Limited Red |
![]() Does Altasports have a web site to browse parts and to place orders?
Bill |
H&R spring installation | GPH993 | Brakes, Steering & Suspension | 1 | 01-01-2002 08:31 PM |
H&R springs installed (before & after pics) | megatron | Brakes, Steering & Suspension | 46 | 12-20-2001 09:52 AM |
HELP: H&R Spring Install | MGS'sWRX | Brakes, Steering & Suspension | 4 | 11-29-2001 03:07 PM |
H&R spring install Beaverton/Hillsboro area? | paulw | North West Impreza Club Forum -- NWIC | 1 | 07-25-2001 01:14 AM |
H&R Springs Installation | BuRnToAsT420 | Brakes, Steering & Suspension | 0 | 06-25-2001 12:46 PM |
