Welcome to the North American Subaru Impreza Owners Club Tuesday February 7, 2023
Old 03-17-2005, 05:57 PM   #1
slvrwrx13
Member#: 55857
04 WRB WRX: Sold
06 CGM WRX Wingless: Sold
Subaru Stars Spring install costs
I just purchased a set of springs and i was wondering what it normally costs to have a set installed. I have called a few places and they all quoted me at $160. Is that normal, good or bad?
slvrwrx13 is offline   Reply With Quote
Old 03-17-2005, 06:22 PM   #2
wrxpeed
Member#: 49958
'03 Cobra DSG
SOLD '02 WRB WRX
sounds about right, my buddy had some teins installed for $180...
Mine was free, did it myself
wrxpeed is offline   Reply With Quote
Old 03-18-2005, 01:53 AM   #3
Mark Avery
Member#: 10313
2002 WRX wagon
$160 isn't bad. You will also need an alignment after a spring install.
Mark Avery is offline   Reply With Quote
Old 03-18-2005, 01:48 PM   #4
majmun
Member#: 18298
2004 STi
Do them yourself and use the $160 on something else. It is an easy job if you have any sort of mechanical skills and only a little more difficult if you don't. There are a couple very good step-by-step write ups on this site to guide you.
$160 bucks isn't horrible, but it's a lot worse than free.
majmun is offline   Reply With Quote
Old 03-18-2005, 03:23 PM   #5
russd32
Member#: 63961
I agree, do them yourself, spend $100 on an alignment, $60 on beer and still be money ahead. It's really easy. all you need is like a 17mm socket, 13mm socket, 19mm socket and wrench, lug wrench, floor jack and stands, spring compressors and a few hours of time. i would also have someone there to hang out and help occasionally for things like lining up the tops when reinstalling the struts. I took my sweet time on everything and it took around 6 hours or so. Now that I've done mine I could probably do another car in 2 or 3 hours.
russd32 is offline   Reply With Quote
Old 03-18-2005, 11:35 PM   #6
slvrwrx13
Member#: 55857
04 WRB WRX: Sold
Thanks for all the advice... I think I might do it myself now. I have always done all of my other installs but this one sounded kind of scary.
Old 03-18-2005, 11:51 PM   #7
EntrustXXX
Member#: 79484
04 WRX
do it yourself, it's not hard, just make sure you have a big ass breaker bar to get the stock lower strut bolts off
EntrustXXX is offline   Reply With Quote
Old 03-18-2005, 11:52 PM   #8
EntrustXXX
Member#: 79484
04 WRX
oh and you don't need spring compressors, don't listen to anyone that says you do. i did mine without them and didn't need them i've also done like a dozen other spring installs over the last few years and never needed them.
Old 03-19-2005, 01:08 AM   #9
voam
Member#: 33460
2003 WRX Wagon
Around here I called 3 places and was quoted $125 per wheel. They all consulted a book that said that is how much it cost. What a RIP! If I was quoted 160, I probably would have paid to have it done. But the downside is you are foregoing an opportunity to get intimate with your Subie. And in a year when your struts go you will have to shell out that amount again!
voam is offline   Reply With Quote
Old 03-19-2005, 06:33 PM   #10
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
You are flat out WRONG to generalize like this. While the stock springs usually are not under a dangerous load, the new springs very well might need compression in order to fit on the struts. GDA STi springs for example need compression in order to fit on the STi struts. Why don't you try putting the stock springs back on the stock struts without a spring compressor?
rex n effect is offline   Reply With Quote
Old 03-30-2005, 04:47 PM   #11
wgb113
Member#: 32478
2018 WRX DGM
2017 Forester XT CWP
I was just quote $682 to install a set of dealer-provided Prodrive springs. ***!!!
Bill
wgb113 is offline   Reply With Quote
Old 03-30-2005, 05:02 PM   #12
B WReX
Member#: 50747
2004 WRX
Use a compressor for sure! Its easier and safer! If you don't got one, you can rent one for probably $10 - it's well worth it.
The install is pretty easy - I'm an install n00b, and I did it 4.5 hrs with friends.
B WReX is offline   Reply With Quote
Old 03-30-2005, 07:30 PM   #13
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
springs are easy to do, you can EASILY do it yourself with just basic tool set and a spring compressor. a good compressor will run you about $500, i suggest use a friend's or something.
the alignment you should spend money on. WAY too much of a headache to measure the angles at home and adjust them. using the alignment rack and machine at my college i can do it myself for free in an hour
eltrouble is offline   Reply With Quote
Spring installation cost in phoenix rtd2 South West Impreza Club Forum -- SWIC 61 07-28-2009 06:02 PM
Spring Installation Cost? Bman Brakes, Steering & Suspension 13 07-06-2005 10:36 PM
What should a spring install cost? Liq2 Brakes, Steering & Suspension 9 02-13-2004 08:48 AM
Spring Install Cost Nizer Brakes, Steering & Suspension 6 04-01-2002 10:00 PM
H&R Spring installation cost GPH993 Brakes, Steering & Suspension 14 12-30-2001 02:37 PM
