• Designed and Made in the USA
• Made from Heat Treated Cast Aluminum
• includes Coupler for OEM or 3" Compressor Inlet
• Does not require removal of Intake Manifold
• Includes Fittings for OEM and Aftermarket Vacuum options
• Looks Terrific!
So I've always been skeptical of the 'hard' turbo inlet, but a tuner friend always used to tell me 'the hard inlets make best power'. Having used Silicone inlets (and been happy with the results) since ~2007 I had generally been happy with the gains from the silicone inlets. Assuming hard inlets likely couldn't produce more than a couple HP and were definitely NOT with the effort that's required to install them. Ignorance is bliss!
Fast forward many years and I finally get around to scanning an OEM turbo inlet and chipping away at a design. We got a couple of hard inlets in, and went through the install to see if they were as horrible as I remembered hearing about, and they were. Made some design tweaks so our version installs at least as easily as the silicone units and even got decent results from the sim. Yay!
Most decent aftermarket silicone inlets are in the $180-$260 price range. The cheap ones I've seen are not note worthy because they are just crap and customers that are shopping for cheapest price are not looking for our stuff anyway. I've not finalized production pricing, but we'd likely be in the $299 and up to $399 if you wanted to add a fancy heat reflective ceramic coating.
The million dollar question here... is the hard inlet we would produce, worth the price of admission? That is the question I am asking for your feedback on.
Here is some data from Flow Bench testing. OEM vs Silicone Competitor vs Killer B
Dyno plot from a stage 1 STi. Will have more date on a higher HP application soon, but according to the SIM and Flow Bench, the improvements will scale up with flow/power level.
