Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 06-25-2005, 12:04 AM   #1
rally_rx
Member#: 89103
1999 Forester
White/Yellow
Default Anyone on here with an RX?
just wondering if anyone on here has an RX and know's a little bit about tuning the older 1.8 turbo's?
rally_rx is offline   Reply With Quote
Old 06-25-2005, 12:05 AM   #2
5spdfrk
Member#: 46407
blew
Look up the name "WJM", I think he has dealt with a few...
You'll usually find him in the SE forum.
5spdfrk is offline   Reply With Quote
Old 06-25-2005, 01:13 AM   #3
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
There are a number of things you can do to an old RX.
I have a wagon with the same motor and the single range FT4WD trans..
I've had some fun with it
Look in the old school section of this board, and also check out www.ultimatesubaru.net
Calebz is offline   Reply With Quote
Old 07-03-2005, 07:30 PM   #4
Caboobaroo
Member#: 72335
89's RX/XT6
Blacksssssss
I picked up an '89 RX back in November. Still working on getting it running but I have a list of mods a mile long right now that I have been doing since I pulled the old motor out. Here's a few things I have been working on:
'02 WRX TD04 turbo
'02 WRX TMIC
Samco intercooler hose set (y-pipe, IC to TB, and recirc hose for stock BOV)
TurboXS BOV
modified stock header until I can get a TWE
WRX downpipe
custom cold air intake
Greddy Profec II B-spec EBC and Auto Turbo Timer
5-lug conversion with WRX front struts and brakes
WRX 3 gauge A-pillar pod
aftermarket steering wheel and shift knob
automatic to manual transmission conversion
stage 2 clutch kit
dual electric fan setup
The engine however is all stock. I do have another engine that will be getting built as soon as I get her running with this one. A short list of the new motor includes:
full rebuild with carbed pistons
spider intake manifold
300ZX turbo injectors
Delta 260 street cams
new pumps (oil and water)
rebuild heads with 3 angle valve grinds, port-n-polish, portmatching
lightened flywheel and custom crank pulley with EDIS ring attached
full MegaSquirt and EDIS setup
custom equal length fuel lines
higher volume fuel pump
well you get the idea
Caboobaroo is offline   Reply With Quote
Old 07-04-2005, 12:21 AM   #5
rally_rx
Member#: 89103
1999 Forester
White/Yellow
wow
that's going to be a monster. When you did the manual swap did you find a center locking diff with high and low gear AWD.
My goal after one year of production rally is to swap a 2.5 Rs turbo motor with all the standalone goodies. Hopeing for 250-300 bhp. In a car that weighs only 1900-2100 lbs. That be good times
Old 07-04-2005, 03:05 AM   #6
simple monkey
Member#: 81067
1989 RX, FX16
both white
i have an rx.
anyway, i would suggest taking off the intake muffler first of all. it sounds great without that thing on there. i turned the muffler into a lunch box since its so big. i never realized modding old cars like this costed so much money (i'm only 16, $100 is a lot). i think the tuning has a lot to do with the driver. i personally cant stand understeer, so the suspension is going first, then the engine later. good luck with the tuning.
-Victor
simple monkey is offline   Reply With Quote
Old 07-27-2005, 09:54 PM   #7
970subaru
Member#: 45703
I think that weight goal might be a little optimistic especially with an ej drivetrain. although I would love to be proven wrong.
970subaru is offline   Reply With Quote
Old 08-04-2005, 11:03 AM   #8
subyrally
Member#: 52662
2009 WRX. 06 Baja
17 Crosstrek 85 brat
i have an rx, granted im trying to sell it so i can get a brat. they are incredibly fun to drive. the sedan weighs in at 2400 lbs. you would be rather hard pressed to get the car down to around 1900lbs, as there isnt really much to take out that weighs anything.
subyrally is offline   Reply With Quote
Old 08-04-2005, 04:57 PM   #9
Calebz
Member#: 54398
1980 CB400 Hawk
Understeer? No understeer here
Old 08-09-2005, 11:30 PM   #10
alacrity024
Review Crew
Member#: 49476
mine never undeersteered much.. come to think of it, it was remarkably balanced on dirt.. never lost control of that car.. not that i can remember anyhow.
alacrity024 is offline   Reply With Quote
Old 08-28-2005, 01:17 AM   #11
subyrally
Member#: 52662
2009 WRX. 06 Baja
yeah, i think im going to keep the rx, i just got it running right again and have a lot of plans for it. im looking to squeeze about 350hp outta the rx engine i have at a shop. it could be fun if i can get it done.
Anyone on here with AP or Engunuity? NycFox Tri-State Area Forum 6 02-09-2008 04:44 PM
anyone on here with an sti in pheonix area, please email me.. CBRDSpeedfactory Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-13-2004 03:00 PM
Anyone on here with Adult ADD? Eric SS Off-Topic 38 11-02-2003 09:13 PM
Anyone here with an AT in a WRX break theirs yet? RobPA Transmission (AT/MT) & Driveline 20 04-16-2002 03:28 PM
Anyone here with an early 90's Legacy Turbo newscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-20-2001 05:59 PM
