Welcome to the North American Subaru Impreza Owners Club Thursday April 26, 2018
Old 02-25-2009, 11:40 PM   #51
puerto_rico_nc
Member#: 102852
06 sti
Thank you tony for chiming in and I cant wait to try them out.. THUMBS UP to T1 for taking everything to the next level!!!!!
puerto_rico_nc is offline   Reply With Quote
Old 02-26-2009, 09:56 PM   #52
Epic Motorsports
Member#: 198925
I cant wait to try them out either woot!
These going to plug and play mike or are we going to have to play with resistor boxes ect?
Robbie
Epic Motorsports is offline   Reply With Quote
Old 02-26-2009, 11:32 PM   #53
JSarv
Member#: 163445
l33t *******
[email protected]
Robbie
Yes drop in other than a simple cut and glue of the plugs since they use a different style of plug.
They are saturated (high impedance) that of all stock (or all obd2) Subaru injectors...
-Jerod
JSarv is offline   Reply With Quote
Old 02-27-2009, 12:11 AM   #54
puerto_rico_nc
Member#: 102852
06 sti
not all subarus are high impedence.. i know 02-03 wrxes have resistor boxes.. stis are high and thats as much as I know.. but they will be a complete bolt in situation.. and the connectors will be included as well which is a plus...
Old 02-27-2009, 12:27 AM   #55
JSarv
Member#: 163445
l33t *******
[email protected]
Strange...
No Subaru is low impedance...NO OBD2 Subaru is... OBD1 - MAYBE.. Not obd2...
Unless my 02 and my friends 02 and 03 all are 1 offs...
-Jerod
Old 02-27-2009, 07:04 PM   #56
Tony1
Member#: 204092
2001 8 second Integr
Red
Ok guys, we're good to go. I've got a perfect fit with the stock rail and aftermarket rail (both the same but checked just to be sure).
I've seen some guys use injectors that don't fit down into the hole in the manifold, resulting in the injector nozzle being very shrouded and fuel most likely hitting the port wall before it gets a chance to atomize well. These sit in very deep and they have a 5 deg included angle so there's no possibility of fuel hitting the TGV on the way out.
I milled out a section of the TGV for viewing and testing, you can see how well it all fits.
The ID 1000's and ID 725's will both fit the same, externally they're the same dimensions.
For some reason the pics from my site won't link here.
http://www.t1raceparts.com/PhotoDeta...uctCode=ID+725
Orders will ship Monday.
Tony1 is offline   Reply With Quote
Old 02-27-2009, 07:36 PM   #57
JSarv
Member#: 163445
l33t *******
[email protected]
Sweet something to look forward to next week!
-jerod
Old 02-28-2009, 12:05 AM   #58
puerto_rico_nc
Member#: 102852
06 sti
cant wait thanks again tony..
Old 03-02-2009, 12:08 PM   #59
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
Subscribed.
Tony, will these be plug and play as well? Or will clips need to be soldered?
-Ty
AMS is offline   Reply With Quote
Old 03-02-2009, 10:05 PM   #60
Tony1
Member#: 204092
Red
Clips will need to be wired in as standard, clips are included.
I have wireless adaptors that will convert these to 'EV1' style connectors (most common injector style) for a small upgrade price.
I also have sources for mating connectors for many different injectors, so I can also offer plug and play harnesses for those of you with stock injector connectors. On that note, do all WRXs come with the same injector connector or did that change over the years and models? Anybody have a good pic of the injector or connector so I can confirm that I have the mating connectors available?
Old 03-03-2009, 12:39 AM   #61
puerto_rico_nc
Member#: 102852
06 sti
I have some from a sti tony I can send to you if you would like. and il find out about the wrx ones...
Old 03-03-2009, 12:46 AM   #62
JSarv
Member#: 163445
l33t *******
[email protected]
top feed and side feed use the same plug...
I'm pretty sure its a female EV6 plug on the harness...
-Jerod
Old 03-04-2009, 08:54 PM   #63
JSarv
Member#: 163445
l33t *******
[email protected]
Little update..
Injectors arrived today as descibed - install was a breeze with NO issues at all!
I chose to use the clips Tony sent and wire it up rather than wait on Tony's plug and play ($40 (which is a stellar price) but I give impatient a new name)
Anyway Car started on first fire - injectors are a BIT loud, not much louder than stockers but you hear them...
Car idled at 16.5-1 afr without a single hesitation. RPMS went from fluctuating 0-100 to 0-20. IPW was VERY VERY stationary even at that lean of a mixture (under 1ms)
As a comparison for me to idle my car with these injectors vs modded stockers IPW DIRECT was at .95ms vs 1.3ms... At the same 14.7 afr. Stockers would not consistently idle leaner than 15.2-1 - these at 16.5 were solid... (even lower IPW)
I'm going out now to get them dialed in and see how OL reacts...
So far I'm more than happy I will update this post later this evening with some cl/ol results once I do a bit of tuning...
BTW, first fire was a cold start at 40*F on full E85 and fired on the first crank (usual but I don't even know if the scaling is right - so even out of scale it started )
-Jerod
Went for a short drive - Idle is FN rock solid! (so happy now ) OL is close to the same - BUT form pull to pull afrs stay almost Identical through the pull (no varience from pull to pull) I still have some work to do on getting the fueling exactly where I want it. But With 22psi (vs 23.5) and the same timing and nearly the same afrs I made the same torque but 35whp more at redline vs before (Honest to god nothing changed other than took 1.5psi of boost away)
WG hose blew off and pegged 24.59psi during a pull (not cool) but it stayed together!!!
Last note I was over boosting prior to this in the mid upper rpms- I had to remove almost 20% wgdc to drop 1.5 psi (before it was about 5% wgdc) So its making more boost with less wgdc than before (dunno why?)
Will have final results tom. night!
-Jerod
Old 03-05-2009, 12:03 PM   #64
MXJS
Member#: 129793
2004 STI
LSX RX-7
Sounds great! Mine are coming today. Can't wait to try them!
MXJS is offline   Reply With Quote
Old 03-05-2009, 01:08 PM   #65
wadester
Member#: 188054
05 STi Cosworth LB
FP Green 375whp
oh my god. DO WANT. Any chance of setting up a straight plug 'n play kit? Maybe team up with Grimmspeed and take over the market for injector/ tgv upgrades?
wadester is offline   Reply With Quote
Old 03-05-2009, 01:39 PM   #66
wittmer25
Member#: 102970
2004 STi gt30r
So for these to work on an 04 sti, I would need wrx tvg's and wrx top feed fuel rails? Is that it?
wittmer25 is offline   Reply With Quote
Old 03-05-2009, 03:25 PM   #67
GeneralTJI
Member#: 152680
Dood Jerod nice work on getting this happening... this is great news, I too am maxed out at 12.3:1 (E85) and need something larger for the motor I'm putting together. These sound like the way to go and they don't cost $550+ (and are also high impedance)
Nice!
I'm in when I have the cash for it...
GeneralTJI is offline   Reply With Quote
Old 03-05-2009, 04:04 PM   #68
jays05
Member#: 78165
05 STI 35r + e85
Need more updates
jays05 is offline   Reply With Quote
Old 03-05-2009, 04:23 PM   #69
Tony1
Member#: 204092
Red
Hey guys, here's some really good reading, check it out.
http://www.injectordynamics.com/dyna...erization.html
As far as injector clips, I have sourced the mating connector for the Denso clips, so we will be offering plug and play adaptors for these in the next week or so.
Old 03-05-2009, 06:35 PM   #70
JSarv
Member#: 163445
l33t *******
[email protected]
^^^ Good reading Tony!!!!
And yes my eyes are glossy!
I'm going to start getting into smoothing things out and see what kind of power I can make with these vs the stockers...
Anyone know off hand (anyone that has an fpr gauge) what the stock fuel pressure regulator TRULY sets fuel pressure at with a walbro 255? Is it REALLY 43.5psi with the vacuum line disconnected? I need to go check it but I'm waiting on my tester to come in..
-Jerod
Old 03-09-2009, 05:21 PM   #71
JSarv
Member#: 163445
l33t *******
[email protected]
Another update - it got real cold last night - startup fuel enrichment was set back to near factory settings (E85 and TGV deletes)
Car started on the first crank and had absolutely NO idle hunt. It never ever ever even considered doing this before even with fuel mixtures as rich as 11-1 at startup.
I have successfully leaned it out to almost 16-1 in closed loop with very smooth consistent results.
Going to start leaning out high loads as I feel more comfortable doing that now...
-Jerod
Old 03-09-2009, 05:46 PM   #72
Silverpike
Member#: 92399
Now THAT'S what I like to hear.
How much static rail pressure are you running?
Silverpike is offline   Reply With Quote
Old 03-09-2009, 06:07 PM   #73
MartinSTi05
Member#: 145145
2006 wrx STi
Ordered a set for my build today. Will post pics when i get them.
MartinSTi05 is offline   Reply With Quote
Old 03-09-2009, 07:43 PM   #74
xilles
Member#: 147056
hmm i got modded 06 wrx cleaned flow tested by deatschwerks at 1050cc...
xilles is offline   Reply With Quote
Old 03-09-2009, 08:19 PM   #75
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
I want these. I sent you an email Tony. E85 is getting really popular here and my modded 950's are maxed. I think these with an increase in fuel pressure will be perfect to support my new cams.
06rexwagon is offline   Reply With Quote
RC 1000cc injectors, Walbro in-tank garagedefeat Engine/Power/Exhaust 83 09-28-2010 04:20 PM
Id Bosch 1000cc injectors TDagen Engine/Power/Exhaust 9 02-01-2010 04:32 PM
FS: Chicagoland - Set of 07 STI Stock Injectors, Drop in for 02-05 WRX Super Nintendo Engine/Power/Exhaust 4 07-08-2009 10:44 PM
FS: Chicagoland - Set of 07 STI Stock Injectors, Drop in for 02-05 WRX Super Nintendo MWSOC Private Classifieds 5 07-08-2009 10:44 PM
Bosch 1000cc Injector's? TurboWRX32 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 03-08-2009 01:46 AM
