Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 04-06-2011, 02:45 PM   #926
Maxwell Power
Member#: 190729
Just run the 2200's. they work great and fit.
Maxwell Power is offline   Reply With Quote
Old 04-08-2011, 01:03 AM   #927
TORC
Member#: 164187
2006 STi
ID1000's aren't quite cutting it for me (well, my fuel system isn't quite coping with the extra fuel pressure needed), so I've decided to go for ID1600's and drop the fuel pressure back down. Wasn't sure how lean we could get ID2000's to idle on pump, and the 1600's will give me enough fuel.
Fitment should be OK in my case as I have PFI rails and soft lines as well as the Cosworth manifold which re-positions the coolant reservoir a little too.
TORC is offline   Reply With Quote
Old 04-08-2011, 01:26 AM   #928
Prevent
Member#: 149114
Id1600's are longer than id1000's
Prevent is offline   Reply With Quote
Old 04-08-2011, 06:22 AM   #929
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
Right now I have 3 93oct maps and 1 MS109 map...that I'll probly never run. I didn't even ask for that tune but oh well. I asked for e85 and they said not practical for dd's....it's my car and I wanted it :/ So I have:
- 1 x Walbro fp
- T1 Racing Topfeed coversion kit
- ID1000's
- -6an lines
What could I get besides a fpr to raise the pressure and a different pump? I've been looking at different surge tanks, in-line pumps....other peoples setups but don't have part numbers. So far I've came to:
- 2.2L surge tank
- Bosch 044 inline fp
- fittings and lines as needed
- Aeromotive fpr
* ??Injectors??
* ?Do I really need in-line filters?
armyssoldierboy is offline   Reply With Quote
Old 04-14-2011, 10:18 AM   #930
Glycerin
Member#: 127044
2005 STi WRB w RPF1s
DTC60s+BrakeDucts
bump!
Glycerin is offline   Reply With Quote
Old 05-18-2011, 07:44 PM   #931
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
For all of you guys running the T1 top/side feed conversion rails with Bosch injectors, what did you do about your per-cyl fueling compensation?
I can think of 4 possibilities
1 - leave it stock
2 - leave it stock but scale the x-axis due to the change in injector flow (similar to scaling tip-in)
3 - zero out the entire table
4 - re-tune it from scratch using a 4 channel EGT
4 is a bit much for me, I'm just trying to decide between #2 and #3. I've heard reports that the per-cyl compensations are due to the flow characteristics of the intake manifold, in which case you'd want to go with #2. I've also heard reports that the per-cyl fuel compensations are due to resonances in the stock fuel rails, in which case you'd want to go with #3 or #4 (I often see people saying to zero out the table when going to aftermarket parallel fuel rails).
So, what is it?
I just finished installing the ID2200s, top feed conversion rails, trunk mounted surge tank, all new fuel lines, filter, aftermarket FPR, etc. running E85. After fixing the leaks and adjusting the FPR to 43 psi with the engine off, the car fired up on the first try and idled well. It was idling a bit lean once it warmed up (~16:1) until I dropped the injector scalar by 9%. That brought the steady state idle fueling in line, but it's a bit uneasy and misfiring, and I think the per-cyl fuel compensation might have something to do with it (I just set my tables to 0).
Old 05-18-2011, 10:36 PM   #932
crashtke
Member#: 120912
Well, I can say that the best option is #4. We have a set of 2200's on a pretty hot build on E85. Leaving the parameters alone yields some plugs quite lean, others normal-rich. Zeroing them out yields crappy running in part throttle and cruise. We are going to adjust based on the plugs and go from there. We do not have individual EGT bungs welded in on this build and since the customer is planning on selling it in the next year or so, I really don't think he is particularly interested in messing with it to that extent and paying for the seat time and modifications on it to make a complete map for it.
crashtke is offline   Reply With Quote
Old 05-19-2011, 12:28 AM   #933
Maxwell Power
Member#: 190729
I think #2 sounds like a great starting point.
RC 1000cc injectors, Walbro in-tank garagedefeat Engine/Power/Exhaust 83 09-28-2010 05:20 PM
Id Bosch 1000cc injectors TDagen Engine/Power/Exhaust 9 02-01-2010 05:32 PM
FS: Chicagoland - Set of 07 STI Stock Injectors, Drop in for 02-05 WRX Super Nintendo Engine/Power/Exhaust 4 07-08-2009 11:44 PM
FS: Chicagoland - Set of 07 STI Stock Injectors, Drop in for 02-05 WRX Super Nintendo MWSOC Private Classifieds 5 07-08-2009 11:44 PM
Bosch 1000cc Injector's? TurboWRX32 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 03-08-2009 03:46 AM
