02-13-2013, 03:59 PM | #5776 |
Member#: 20952
Vehicle:BRZ & Datsun White & White |
i might need to add another home screen for that. but then i'll have an even number of homescreens so ill have to add 2 more. what am i going to do!
02-13-2013, 04:01 PM | #5777 |
Member#: 93830
Re: VZW Note 2 Battery consumption
I've had the Note 2 for a little over two-weeks now and have been mostly pleased with everything about it. Battery life was substantially better than my Gnex. At one point I was at 1.5 days with about 40-50% remaining...great stuff. Starting two-days ago, for no apparent reason, the battery consumption has increased significantly. For example, i'm at 60% after 7 hours of on-time, 2.5 hours in airplane mode... Something isn't right. A couple of things I have noticed: 1) In airplane mode, battery consumption is zilch--so i'm thinking it has somethign to do with the radios. 2) This morning when I woke up, the battery only charged to 96%. It should have been 100%. I've rebooted, shut down, and removed the battery several times. OS is bone-stock, non rooted. Any suggestions? Or does did the battery crap out or something? |
02-13-2013, 04:02 PM | #5778 |
Member#: 59141
International
Vehicle:ManU Redsox Notre dame |
Nope
today I am at 68% left Watched 2 hours of netwflix last night on it before bed. Listen to podcasts for 11 hours a day at work, or music. Then I watch a Tv show usually every night from my itunes library, or stream netflix for 1-2 hours. The other night was heavy use, and still it dropped 22%. I charge it once every 4-5 days at most. I cannot tell you how unreal the battery life on this device has been. |
02-13-2013, 04:09 PM | #5779 | ||
Member#: 87015
http://phandroid.com/2013/02/13/sams...medium=twitter |
02-13-2013, 04:11 PM | #5780 | |
Member#: 7121
Lastly, as far as the charging is concerned, make sure you are using the charger that came with the phone or one that puts out at least 2A (2000 mA). One night I had ran down my battery to somewhere around 3% before I went to bed. I charged it with a 1A charger. The next day I had something like 58% charge. Good luck! |
02-13-2013, 04:15 PM | #5781 | |
Member#: 93830
THanks for the tips |
02-13-2013, 04:34 PM | #5782 |
Member#: 7121
One other thing. Check your motion settings. I found that the quick glance setting, if turned on, eats some battery.
02-13-2013, 04:35 PM | #5783 | |
Member#: 84815
Vehicle:2015 water n badass. badass n water. |
Maybe I should charge my Nexus 7 more than once every 4-5 days. |
02-13-2013, 04:48 PM | #5784 |
Member#: 93623
the new Google Search/Now update has home screen Now widgets
02-13-2013, 04:49 PM | #5785 | |
Member#: 87015
02-13-2013, 05:07 PM | #5786 |
Member#: 93623
I scrolled too quickly down the page on my phone I guess |
02-13-2013, 05:18 PM | #5787 | |
Member#: 69369
< haven't really dicked around with it yet... just glad the pull downs are fixed. |
02-13-2013, 06:10 PM | #5788 |
Member#: 195061
NWIC
Vehicle:1997 ¯\_(ツ) Green |
Installed an AOKP ROM last night on my N10. Seems petty snappy, destroys smartbench 2012 for whatever that's worth. Was fully charged this AM and was at 97 percent battery when I left. Got home just a few minutes ago and it is at 95 percent after 8.5 hours standby.
02-13-2013, 06:11 PM | #5789 | |
Member#: 87015
02-13-2013, 06:12 PM | #5790 |
Member#: 84815
I've been pleased with the battery life I get with Jelly Belly on my GNEX.
02-13-2013, 06:37 PM | #5791 |
Member#: 185374
to those on N4,
I'm trying this out: http://forum.xda-developers.com/show....php?t=2072930 it's what google is suppose to be patching in the next update. when i come back into wifi range, it doesn't seem to connect every time. these seems to work, haven't tried it on campus yet though. |
02-13-2013, 06:45 PM | #5792 | |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
Every battery run-down test I've seen on that device puts it at 12-14 hours screen on and wifi on. Which is great, but what you're describing is unreal. You're describing a device that can get over 45 hours of actual use between charges... |
02-13-2013, 06:49 PM | #5793 | |
Member#: 87015
02-13-2013, 07:11 PM | #5794 |
Member#: 84815
02-13-2013, 07:14 PM | #5795 |
Member#: 121031
Nexus 4 came today. Picked up a Microsim on the way home from work. Did an online chat once I got home and the dude got me all set up, but the play store and speedtest didn't work. Changed my APN to one recommended on XDA forums and I'm pulling about 5 down, 1 up now. MMS and speedtest work fine.
One weird thing is, don't have two APN's saved. I was getting crap speeds until I deleted the default one completely. Maybe coincidence, maybe not. Great phone though. Though I don't like the bumper. It makes it just a tiny bit too big. |
02-13-2013, 07:39 PM | #5796 | |
Member#: 185374
Here are my settings which I both confirmed w/ AT&T and XDA. XDA has a TON of misinfo as of late. |
02-13-2013, 08:49 PM | #5797 |
Member#: 93623
Anybody try Crossbreeder? Looks cool and should work on all Android devices. Common sense approach to big time performance boosts.
http://forum.xda-developers.com/show....php?t=2113150 I think I'll flash it tomorrow. |
02-13-2013, 09:05 PM | #5798 |
Member#: 530
E. Canada
Vehicle:2005 9-2x Aero FastAr Red |
02-13-2013, 09:08 PM | #5799 | |
Member#: 140163
Vehicle:03 STi hellaflunctional |
02-13-2013, 09:22 PM | #5800 |
Member#: 121031
Damn, uninstalling iTunes felt amazing. The iPhone has been good to me for years, but it does feel pretty good to be Apple free for a while.
