Welcome to the North American Subaru Impreza Owners Club Monday February 26, 2024
Old 01-14-2022, 07:09 PM   #26
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Originally Posted by Waddlz View Post
Makes me wonder if they are checking for deleted emissions codes, and not reflashes.
My buddy with an 07 WRX with tune, bigger turbo, etc etc just puts his stock downpipe back on and passes but he doesn't have any emissions stuff deleted.
I can tell you from experience they are not checking for deleted codes. Active codes, yes, of course. The big thing for me was monitors. There are a group of 10-12 they check for. They will fail you if a monitor such as the evap monitor is not enabled. Simply unmarrying an AP is not enough to get the monitors turned back on. It took quite a few cold starts to get mine enabled. Give yourself enough time between the time you unmarry your AP to the time of your smog check for enough cold starts. I can't tell you how many it takes as every car/ECU is different.
Gallo2011 is offline   Reply With Quote
Old 03-03-2022, 03:07 PM   #27
Arossteven
Member#: 363673
2014 WRX (Sedan)
Originally Posted by Arossteven View Post
2014 WRX, first year smogging the car. I live in the SF Bay Area in CA. I went for smog, and I failed due to “Modified Software.” I passed visual/mechanical inspection, I have stock catback exhaust, I put on equal length headers, and I have an EcuTek “Shiggy” road tune. Was wondering what my options are to pass smog? Is it easy to put the software back to stock, re-smog, hopefully pass, then put the EcuTek back on after? Her perhaps a shop that’ll help me get through this issue? Please advise, and thank you in advance!
Update: I was able to obtain a Stock ROM from my tuner. He sent me the rom, and I had a buddie who had the EcuTek software on his laptop, reflash my ECU back to the stock ROM. I drove approximately 80miles, cold started maybe 6 times. I went back and got re-smogged and passed! )
Arossteven is offline   Reply With Quote
Old 03-03-2022, 10:30 PM   #28
nightcrawler60
Member#: 126438
Good to know.
nightcrawler60 is offline   Reply With Quote
Old 03-03-2022, 10:56 PM   #29
Kostamojen
Member#: 2272
2019 Macan 4cyl
1993 Impreza FWD WRX swap
I passed SMOG in January with my swap with BAR certification plus a COBB AOS and COBB Ecu tune with CARB stickers in the engine bay... They just looked at the stickers and didn't check the actual ECU tune at the SMOG shop.
Old 03-17-2022, 02:12 AM   #30
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
97 Ford Ranger on Bags
which Cobb tune is CA carb approved?
TRinityMtrSprts is offline   Reply With Quote
Old 03-18-2022, 03:34 AM   #31
Kostamojen
Member#: 2272
2019 Macan 4cyl
The 91 ACRN map included with the Accessport. They have all the CARB documents on the COBB website.
Old 03-19-2022, 01:07 AM   #32
bemani
Member#: 5673
05 LGT, 02 WRX
Hellcat CTR LC500 GRC
This was not a STAR smog station? I thought they were suppose to check even the CARB approved maps.
bemani is offline   Reply With Quote
Old 03-20-2022, 03:40 PM   #33
Kostamojen
Member#: 2272
2019 Macan 4cyl
It was a STAR station. I thought they would check the maps too, but I think the sticker allows that to be bypassed.
Old 03-21-2022, 01:37 PM   #34
bemani
Member#: 5673
05 LGT, 02 WRX
I wonder if they're still updating the process or if that is going to be how it works.
Old 06-04-2022, 10:23 AM   #35
Spec R
Member#: 187752
99 RS/Volt/Frntier
I have a 2000 RS with a 99 EJ207 BAR'd as a 2004 EJ205. In years past, 04 WRX MT ECU was good enough to pass since the car had all its monitors pass and no CELs.
Wish me luck, I'm going to try to pass with a Cobb APv3 OTS ACN91 Stage1 tune. I swapped out my 816cc injectors for stock 440s, Perrin EL header for stock manifold, k&n typhoon for stock box, and MRT DP for stock DP. Non-stock items currently on the car are only the Grimmspeed Up-pipe and Prodrive axle back.
My smog guy is strict, but he doesnt care about up-pipes and axle backs.
Not much info out there regarding the CVN and running the Stage1 map and smogging though.
Spec R is offline   Reply With Quote
Old 11-22-2023, 08:17 PM   #36
Kostamojen
Member#: 2272
2019 Macan 4cyl
Update on this...
Just passed SMOG for the second time with the swap. This time I was running:
-VF48
-STI Uncatted uppipe
-Resistor mod
-COBB 3-port EBCS (VERY well hidden for visual)
-STI Injectors
-AEM 320 Fuel Pump
-Pro Tune
-COBB AOS with CARB sticker
Passed with zero issues! Very clean on the charts/stats actually, not like I would fail the sniffer just the visual would be the issue.
Rumor has it anything 2005 or older isn't in the ECU database for CARB, plus my CARB sticker for the COBB tune is still on the car along with the BAR swap sticker of course. The SMOG guys see those and basically give you a pass for a lot, and they DID NOT scan the ECU for the map just the readiness monitors and for CELs.
Theoretically this means quite a few other mods are quite possible, along with changes with engine internals since the ECU tune is open to pro tunes. Turbos are pretty much free game too, as are injectors that look OEM (IDs would probably fail visual). Wondering if I could even get an OEM twinscroll downpipe to pass since they didn't go under the car
Newer cars like the BRZ and VA WRX/STIs are getting their ECUs scanned now though, wouldn't try to do too much with those. But an 04/05 STI should have lots of possibilities.
Old 11-27-2023, 02:27 AM   #37
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
Dumb question, how do you know they didn't scan the ECU map?
NutBucket is online now   Reply With Quote
Old 11-27-2023, 12:27 PM   #38
Kostamojen
Member#: 2272
2019 Macan 4cyl
It actually takes a considerable amount of time to do. I watched the BAR ref scan it during certification, and sat and watched what the smog station did and asked too since the guy who checked me in also had a swapped Subaru.
If they scanned it they would have found it didn't match the COBB CARB tune I have the sticker for, which is what the BAR guy did. Other newer CANbus cars are getting scanned and failed (BRZs for example), I've seen a couple posts on other forums about it and mention of it on social media.
Old 11-27-2023, 01:56 PM   #39
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
Got it, thanks!
I guess most smog guy probably won't bother scanning low-risk cars...or do you think perhaps the scans are initiated from the state?
Old 11-27-2023, 01:56 PM   #40
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
Got it, thanks!
Old 11-27-2023, 07:51 PM   #41
bemani
Member#: 5673
05 LGT, 02 WRX
I just swapped to a stock ECU on my 2002 WRX to prepare for next year's smog (takes awhile for all the monitors to be ready with my driving habits). Maybe that's something I don't need to do?
Old 11-28-2023, 07:50 PM   #42
Kostamojen
Member#: 2272
2019 Macan 4cyl
Got it, thanks!
The state supplies the reference for the maps. I'm starting to suspect its only CANbus cars in the system but can't confirm it.
Probably unnecessary.
Old 11-29-2023, 07:45 PM   #43
bemani
Member#: 5673
05 LGT, 02 WRX
I guess I'll try leaving my AP map in my Legacy when its time to smog it in 2025.
Old 11-30-2023, 04:55 PM   #44
Kostamojen
Member#: 2272
2019 Macan 4cyl
Hide a camera in the next car that gets smogged to see if they scan it
Old 12-02-2023, 03:31 AM   #45
bemani
Member#: 5673
05 LGT, 02 WRX
Is it going to look different from what they usually do hooking up to the OBD2?
Old 12-02-2023, 03:52 AM   #46
Kostamojen
Member#: 2272
2019 Macan 4cyl
Of course. Checking readiness monitors takes seconds like with any OBD scanner. Checking a map takes awhile.
