Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2024
Old 10-05-2005, 04:14 AM   #1
...lostwrx
Member#: 97403
2002 WRX Wagon
Default speedo and tach are not working properly
I just installed some indiglo gauges and now my tach and speedo are sticking... the movement is jerky and doesnt respond well... How do I fix this?
...lostwrx is offline   Reply With Quote
Old 10-05-2005, 04:19 AM   #2
sdogg3kgt
Member#: 38397
2002 Lovemachine
Replied to PM.
sdogg3kgt is offline   Reply With Quote
Old 10-05-2005, 04:25 AM   #3
...lostwrx
Member#: 97403
2002 WRX Wagon
this is the stock instrument panel BTW
Old 10-05-2005, 04:26 AM   #4
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
think there is a rice alert sensor behind the speedo... on a more serious note, you have something loose or half connected
szeny is offline   Reply With Quote
Old 10-05-2005, 04:30 AM   #5
Lexington
Member#: 50221
I'm on internets
Racin on ur bandwidth!
it is because your needles have not re-seated
get a pin or a thumbtack or anything very thin, even the tip of a knife
if you look at your needles, at the base there will be a VERY thin circle between your needle and the gauge face. This small ring has to be SEATED against the gauges. not close. not kinda touching, the whole thing has to be "popped" down.
Lexington is offline   Reply With Quote
Old 10-05-2005, 06:49 PM   #6
minx1225
Member#: 89034
2015 STI Limited
Crystal Black Silica
^^ Wut he said... It needs to be popped to the gauge. Do it with carefully..
minx1225 is offline   Reply With Quote
Old 10-24-2005, 12:16 AM   #7
MdWRX
Member#: 69636
2002 Wrx
Sedona Red
Does anyone know if there is an easy way to determine where the needle needs to be positioned when you re-seat it so that you are not always unpopping it and popping it back in until the needle rests on the pin/correct rpm with power going to the cluster???
MdWRX is offline   Reply With Quote
Old 11-07-2005, 03:21 PM   #8
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
omg thank you.. my speedo is finally working perfectly
Spy is offline   Reply With Quote
key ring light, radio and clock are not working moose00015 Newbies & FAQs 5 03-23-2010 12:29 PM
speedo and cruise control not working 2002 subaru wrx redrex002 Electrical & Lighting 1 03-15-2009 03:42 PM
Speedo/headlights are not working subaru mike Electrical & Lighting 5 05-24-2004 03:01 PM
Anyway to Switch Speedo and Tach gauge? Devilchrist Interior & Exterior Modification 9 09-15-2002 11:38 PM
