Welcome to the North American Subaru Impreza Owners Club Sunday June 7, 2020
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 03-21-2020, 02:18 PM   #1
ssmokeyy
Member#: 485907
Default Putting my 03 wrx up for sale. Need some info on what i can get for the car.
So I have a dark red wrx. I need to sell it fast for cash to pay some bills, I have put over 23k into this car and wasn't planning on selling it. Here is my list. Also the a/c pump started leaking last week and was wondering if u guys think I should worry about it or if it has to be fixed to get good money for the car.
Parts list
engine
ej25 with manley h-tuff rods, je hybrid pistons, tomei headgasket,
crower stage 2 cams, brain crower valve springs and retainer kit
11mm Subaru oil pump, all new bolts, belts, ferrea upgraded 1mm oversized valves and valve guides, heads ported and polished, Engine built by sunwest and balanced, new 2017 sti forged crank, 8mm intake manifold spacer, intake manifold ported. Exhaust manifold ported, grimspeed center joint, grimspeed uppipe with waste gate dump, tial external wastegate, Forced performance red 10cm hot side 3 inch cold side cover, mishimoto front mount kit, mishimoto oil cooler kit custom mounted in pass side front fender, id 1000cc,
snows performance meth kit, Mishimoto radiator, upgraded reservoir tank, 3 inch exhaust all the way back with a 3 inch dump valve, cobb down pipe, walbro 450 fuel pump with upgraded wiring, high flow fuel filter
Transmission
2004 sti transmission with front and rear lsd
r180 rear diff
new axles front and rear
exedy stage 1 heavy duty kit
motul fluid used transmission, clutch fluid, rear diff
stainless steel clutch line,
Brakes
06 wrx 4 piston front caliper
06 wrx 2piston rear caliper
sti dba rear rotors
slotted front rotors
dba red pads front and rear
stainless steel brake lines front and rear
motul brake fluid
suspension
Pedders sport kit struts and springs .5 drop still amazing ride and handling
whiteline front and rear sway bars,
all new bushings front and rear,
metal bushing kit for center driveline mount
sti seats, 5 gauges for o2 oil pressure meth digital control gauge, new sti floor mats new tint , new bfg gforce a/s tires 17 inch black wheels,
ssmokeyy is offline   Reply With Quote
Old 03-24-2020, 01:22 PM   #2
geddesk2
Member#: 119397
06 STI & 13XT
I would look online for other bugeyes that have had an sti swap and see how they are priced. Anyone looking to buy a project like that will only pull the trigger if it's all in order, so I would say you should definitely resolve any all issues that someone would find at an inspection.
You didn't list the chasis miles, or the condition of the exterior/interior. You can probably estimate a price based on STIs for sale with similar mileage and condition. What I can tell you for certain is that it's not worth what you put into it.
geddesk2 is offline   Reply With Quote
Old 03-29-2020, 01:10 PM   #3
ssmokeyy
Member#: 485907
I know im not going to get what i put into it. I have receipts for over 22k with out my labor cost. 04-05 sti's go for 14k-22k still here. the body has 198k miles on it. If someone doesn't want to pay the 14k i might just have ot keep it or sell it part by part and send the chassis to the junkyard if no one wants it. But my tuner says its one of the cleanest bugeyes hes ever seen even with the damage on the quarter panel.
