Welcome to the North American Subaru Impreza Owners Club Sunday September 22, 2019
Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC > SCIC Vendor Classifieds
Old 08-12-2019, 05:47 PM   #1
Aristocrat Autosport
NASIOC Storefront Vendor
Vendor Sales Rating: (99)
Member#: 384404
MANY WRX, STI, 997TT
wrb
Default High Power calls for High Airflow - Perrin Turbo Inlet Hose for WRX/STI
Perrin’s inlet pipe is a must have for those of you with engines that require high airflow. The Perrin pipe is constructed from thick silicone with multiple stainless steel support wires that for a skeleton in the inlet, with a completely smooth path inside for airflow. These wires prevent the hose from collapsing when restrictive filters are used or high boost pressures are encountered. A machined aluminum insert which is bonded into the silicone layers provides a solid blow off valve connection, while the spigots are half inch in diameter, providing maximum flow from crank case vents and other vacuum connections. This inlet pipe is available in 2.4" and 3" versions.
PM with your zip code for an accurate shipping quote! Will call options are available for Southern California customers at our Buena Park facility.
Facebook:https://www.facebook.com/AristocratAutosport
Instagram:https://www.instagram.com/aristocrat_autosport/
Website:www.AristocratAutosport.com
CALL OR TEXT: 714-340-6596
Email/Paypal:[email protected]
Aristocrat Autosport is offline   Reply With Quote
