Welcome to the North American Subaru Impreza Owners Club Wednesday March 22, 2023
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC > NWIC Private Classifieds
Old 01-28-2023, 04:31 PM   #1
Huntergreengc
Member#: 457508
Default 2004 wrx wagon with 04 sti trans swap
I have a 2004 wrx wagon that is highly modified with 120k on the odo car is in Washington north of seattle
https://www.facebook.com/marketplace/item/414001457603363/?mibextid=dXMIcH
Mod list
Guages
Defi boost and oil pressure with controlled and innovate wideband
Engine:
Vf22 turbo
38mm ewg
Grimspeed 3 port boost controller
Cobb intake
3in catless dp and catless uppipe
Recently replaced alternator and piwersteering pump
Grawford v2 AOS (mounted so that cruise co trol is still usable
Transmission:
04 sti trans with replaced syncro mesh gears (redline 75-140 used for gear oil)
R180 rear diff with cusco 1.5 way lsd (cusco 75-90 gear oil used)
Iwire spyder controller with factory knobs
04 sti cluster with mileage matched to actually mileage of vehicle
Perrin semisolid trans mount
Chasis:
Cusco frame bracing frome subframe back
Whiteline anti lift kit
Rear diff lock down kit
All poly urethane mounts from subframe back
Trq solutions driveline bushings
Cusco rear strut tower upper brace
Whiteline front and rear sway bars with kartboy end links
Car has not been tracked or raced I have it tuned to 19psi map or a 17psi map by surgeline in Portland.
Asking 17k obo
Email me at
[email protected]
Huntergreengc is offline   Reply With Quote
