03-05-2008, 12:19 PM | #1 |
Member#: 172732
Vehicle:2006 Impreza N/A Silver |
Is Bump starting an AWD bad..?
This is my first AWD so I'd like to be sure if bump starting is safe.
Towing an AWD vehicle, with say the front wheels in the air, will mean a 100% speed difference between the axles. Say goodbye to your center diff. Bump start: Pushing the car, setting the key to on, and slowly releasing the clutch in second gear will start the engine. All axles and drivetrain are at the same speed.
03-05-2008, 03:01 PM | #2 |
Member#: 40674
SCIC
Vehicle:94 Impreza wagon 1.8L + 657cc's |
I don't see why there would be any problem, although I've never been able to bump start my impreza. Even going ~15 mph and using 2nd gear, it won't start.
03-05-2008, 03:29 PM | #3 |
Member#: 145883
SCIC
Vehicle:2008 wrx psm |
if all wheels are rolling then your fine.
but ouch that hurts doing that. |
03-05-2008, 06:43 PM | #4 |
Member#: 165749
why 2nd gear? wont the lowest gear (1st) give the most engine rotation per wheel rotation? i.e - lower wheel speed required and more mechanical advantage to spin the crank.
03-05-2008, 08:01 PM | #5 |
Member#: 172732
1st is too rough on the drivetrain. I would generally try it rolling downhill with the electric power on, clutch pedal down and 2nd selected.. when going fast enough for 2nd let the clutch up quickly... be ready to give it gas and if needed you can also drop the clutch again again as soon as it fires.
03-05-2008, 08:27 PM | #6 |
Member#: 168129
SCIC
Vehicle:2013 WRX WRBP |
03-05-2008, 08:45 PM | #7 |
Member#: 59980
Vehicle:03 Forester |
I once had a tiny car with a bad starter solenoid. Before I fixed it, the easiest way to start it was, sitting in the drivers seat, put it in reverse, depress clutch with right foot, put left foot on the ground to push the car back a little, then pop the clutch. The last time I ever did that, it started fine, but just sat there with the engine running, in gear and not moving: Busted axle.
03-05-2008, 08:49 PM | #8 |
Member#: 64673
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
I bump start mine daily, cause it dies coming out of gear. haha. but yeah, I will sometimes bump start mine 10 times a day. I don't like it though, its just a fact of highly modified life.
03-05-2008, 10:05 PM | #9 |
Member#: 165749
i have never heard of highly modified cars not running out of gear. what mods do you have?
03-05-2008, 10:15 PM | #10 |
Member#: 64673
It dies when I take it out of gear (sometimes) and then coast. Like to a stop.
03-05-2008, 10:25 PM | #11 |
Member#: 170616
Vehicle:1998 MiatA! BLACK |
I had a old 95 nissian altima, the starter went, didnt want to spend the money to fix it because i was get rid of it soon. anyways i had no issues with bump starting it, minus the pain in the ass if i had to go somewhere and it was all flat. but lucky me, my driveway is a hill. parked it at the top every night, next morning bumb started it down the hill. and drove to work, park in on the hill (far from my job, but it made it easy to get it going when i left) did it every day for a month had no issues.
It was fun when i had anyone with me, "why do you park up here?" oh... you'll see!!!! |
03-05-2008, 11:31 PM | #12 |
Member#: 74907
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
The easiest way to do that is to use 3rd gear. You have to selcet a gear that gives the engine more leverage over the car's weight. Think of it from the engine's point of view, would it be easier to use 3rd or 4th gear(fewer engine rpm's in relation to the axles rpm's) Or using a gear where the engine has to turn many rpm's to turn the axle few rpm's.
~Josh~ |
03-06-2008, 01:26 AM | #13 |
Member#: 115154
Vehicle:2005 Outback XT White on grey |
03-06-2008, 08:46 PM | #14 | |
Member#: 165749
03-06-2008, 11:23 PM | #15 |
Member#: 74907
When you turn your car on the starter doesnt exactly spin the motor at a very high rpm either. It's probably about or under 100 rpms. I guess I didnt type it the way I was thinking it. I should have said you have to select a gear that uses the car's weight to an advantage. You can try using 2nd gear, but I have found it easier to use 3rd.
~Josh~ |
03-07-2008, 12:48 AM | #16 | |
Member#: 167703
Vehicle:2005 '05 2.5RS 5MT '10 Forester X Limited |
03-07-2008, 01:05 AM | #17 |
Member#: 142754
SWIC
Vehicle:2009 Forester XT |
I'm under the impression it is bad for cats.
Correct me if I'm wrong. |
03-07-2008, 01:35 AM | #18 |
Member#: 59980
05-27-2016, 10:15 AM | #19 |
Member#: 447549
Vehicle:2015 WRX 6MT Premium CWP |
05-27-2016, 03:34 PM | #20 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
05-29-2016, 01:10 AM | #21 |
Member#: 3409
Vehicle:98 My FMIC Is bigger than yours. |
lol
I always use 5th gear, it gets the engine spinning plenty fast and there isn't much shock. |
Similar Threads | ||||
Thinking of buying an AWD dyno/starting a business | therealratfink | General Community | 33 | 11-20-2009 05:17 PM |
How bad is it really, to have 2 different sets of tires on an AWD car? | WhiteFox | Tire & Wheel | 12 | 03-19-2008 03:22 PM |
How bad is bumping the rev limiter?? | waitandbleed92 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 10-29-2003 05:56 PM |
is bump good or bad? sorry ...new to forum | IMPREZ03 | Newbies & FAQs | 4 | 04-16-2003 11:25 AM |
okay so its bad to tow an AWD car with 2 wheels on the ground | jasona | Normally Aspirated Powertrain | 15 | 12-11-2002 02:04 AM |
