08-26-2016, 12:59 PM | #26 |
Member#: 441050
Coolant piping done. 02-07 wrx don't have the middle case vent like 255 and 257 blocks. The two black piping is attached together one coolant and vent the other.given i have the 2011wrx heads it all worked out ok.
08-26-2016, 02:40 PM | #27 |
Member#: 401977
TXIC
Vehicle:IDFK Wat bish whet |
I'm really interested to see what your opinions are on how well this paint holds up.
I'll be doing a full removal on my forester some time in the near future and was thinking of sprucing it up with some classic silver. |
08-27-2016, 11:10 AM | #28 |
Member#: 441050
I hear you man, frombthe expert opinion this should hold good even though i skipped the aluminium treatment before the primer so far its even hard to scratch it off. As long as there isnt a crack scratch on the paint during install I think i should be good. It was all a high temp paint. I will update hiw it holds up after it starts running
11-19-2016, 11:22 PM | #29 |
Member#: 441050
Hi gang! A few updates coming soon, I have decided to enlarge my TB from 60mm to 62.5mm any one done this before and have some good results. I know it won't make a tonne of power but can enable a few ponys on the way. I looked at the boomba 70mm but lacks the coolant lines and cruise control option for the money,there is an eBay one with coolant in let just lacks the cruise control option too, so I decided just modify the oem one.
11-19-2016, 11:24 PM | #30 |
Member#: 441050
That's a boomba TB looks cool comes with 60mm and 70mm adaptors.
11-28-2016, 01:34 PM | #31 |
Member#: 441050
Hi guys has anyone ever found out if a banjo connections flows worse than a straight through connections am trying to eliminate the coolant line banjo for the turbo with a AN -6
Yu can deffinately tell even though the oem coolant hose is a 5/8 making it almost a -8 line I think the outlet onnthe banjo is tiny meaning this will improve flow if i eliminate it, any input is welcome, some progress on the build coming soon. |
11-28-2016, 01:39 PM | #32 |
Member#: 441050
I finally found a swivel fitting that will work the turbo will have a -6 fitting on the coolant inlet side and a -8 on the exit side to accommodate an even connection with the IAG AOS
11-29-2016, 09:46 AM | #33 |
Member#: 441050
Finally the swivel push loc set up
12-02-2016, 10:23 PM | #34 |
Member#: 441050
Cat is out the bag and it will definately take some tricks to make it fit stay tuned. That td04 is dwarfed
12-16-2016, 01:36 PM | #35 |
Member#: 441050
Big ups to morrocco88 he is on board making me the uppipe to mount this baby.
12-29-2016, 09:35 PM | #36 |
Member#: 441050
Today got a tease from morrocco and all i can say is wow! Those welds are prime. I will miss em after coating one more week and supports will be welded on too then down to do a custom downpipe
12-31-2016, 03:41 PM | #37 |
Member#: 441050
So the throttle body is in almost 3mm bored and poweder coated all in all its a mint job by jim at proflow, here is before and after pics
01-06-2017, 02:02 PM | #38 |
Member#: 441050
The efr 7670 taken apart for painting and custom making the downpipe, it don't look much to flowing 64lbs but how can yu tell till it runs, compared to a stock turbo I say the IWG here looks bug enough. Anyone has suggestions in changing the BOV SPRING to the stiffer one to start with?
01-25-2017, 08:59 PM | #39 |
Member#: 441050
Powder coated
02-23-2017, 11:35 PM | #40 |
Member#: 441050
Why can't i post pics anymore?
03-09-2017, 11:28 PM | #41 |
Member#: 441050
Work in progress, just can't figure out why i can't post pics.
04-01-2017, 07:23 AM | #42 |
Member#: 441050
Custom rotated uppipe fit loke a glove. |
04-01-2017, 07:32 AM | #43 |
Member#: 441050
For those who need a solid piece made morrocco88 is your man. He did serious welding on this plus the downpipe for my efr 7670. Am also doing custom IC Piping and he welded a piece on the TB and came out fantastic |
04-07-2017, 04:54 PM | #44 |
Member#: 463739
Vehicle:2006 Forester XT Red |
Awesome work! Subscribed.
04-08-2017, 07:38 AM | #45 |
Member#: 441050
Thanks Dan for subscribing am almost on the end of it if i can figure this IC AND FUEL SET UPS. Interesting twists here and there.
04-08-2017, 07:40 AM | #46 |
Member#: 441050
04-08-2017, 11:06 AM | #47 |
Member#: 441050
Today i will bolt on the jdm intake so i can start measuring my fuel lines. I wanted to re do tbe wiring kind of hid some of it but at this point i wish i knew where to get new specific wire clips or connectors.
04-08-2017, 11:11 AM | #48 |
Member#: 441050
FYI my power steering set up will be changed somehow. a custom reservoir (a modified catch can custom hoses bolted right into the rack the low pressure line is a nylon hose that can take the abuse but after putting it on a not so sure
04-08-2017, 11:14 AM | #49 |
Member#: 441050
I want to put a vibrant resonator here. I want silence and still retain the whole 3" opening on my exhaust its going to take some diagonal cutting and welding. |
04-08-2017, 11:21 AM | #50 |
Member#: 441050
This are the couplers am using all through the IC pipping, finally i found a local guy who is working good with me. This goodies can withstand 500psi and i think 250°c. They are quick connects and have 2 Orings verses 1 Oring of some other american made ones what i can say i searched a whole lot and finally got them. |
