Welcome to the North American Subaru Impreza Owners Club Saturday December 15, 2018
Old 10-01-2018, 12:49 AM   #1
brandobot
Member#: 199552
2011 STI Hatch
Default Are tunes required for just catbacks?
Iím protuned for my stage 2 plus equal length header.
My car came with a cobb catback that is too loud for me. Iím considering going to stock or another quieter exhaust. Will this negatively affect my protune?
brandobot is offline   Reply With Quote
Old 10-01-2018, 01:55 PM   #2
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Yes, but not to the extent that I'd recommend doing anything about it unless you can tweak the tune yourself. It's likely been locked by the tuner.
mrsaturn7085 is offline   Reply With Quote
Old 10-03-2018, 07:54 PM   #3
brandobot
Member#: 199552
2011 STI Hatch
Thanks. I don't mind if I lose some power, but am concerned about reliability of the engine.
Old 10-03-2018, 10:25 PM   #4
mrsaturn7085
Member#: 375462
WR Blue
I would always log data and evaluate - make changes if you feel you need to.
Old 10-04-2018, 02:17 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I don't come in here much since I am not well versed on tuning.
Unless you had a major issue with the CATback on your original tune, then a new CATback should be about 95% fine on existing tune.
Just my thoughts.
Old 10-04-2018, 03:09 PM   #6
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Unless the catback is restrictive enough to noticeably affect the flow characteristics at the turbo (factory cbe won't do that, btw), then it's too far downstream of the turbine outlet to affect backpressure and therefore affect tune by altering the performance of the turbo.
SirBrass is offline   Reply With Quote
Old 10-04-2018, 03:30 PM   #7
mrsaturn7085
Member#: 375462
WR Blue
Though 5% is the limit of closed loop fueling in some cases
Seriously though, it'll be fine - much better than 95% okay!
Backpressure on the stock system is mainly caused by the wastegate being undersized for a 2.5 liter motor without a restrictive catalytic converter when the turbo was designed around a 2.0.
Old 10-15-2018, 04:53 PM   #8
ragnar007
Member#: 492740
2018 WRX
Default J-pipe
Do you have a catted J-pipe?
ragnar007 is offline   Reply With Quote
