Welcome to the North American Subaru Impreza Owners Club Tuesday January 26, 2021
Old 01-04-2009, 06:43 PM   #1
redwrxhead
Member#: 156834
Default sti heads vs wrx heads
ok so i have a 2.5 block and im trying to decide which heads to go with. what are the differences between the wrx heads, STI heads, and JDM V7 sti heads. i know the AVCS difference but what else? and could i use the stock wrx ecu with either of them besides the wrx heads?
thanks in advance for the info
redwrxhead is offline   Reply With Quote
Old 01-04-2009, 07:56 PM   #2
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Better breathing and sensors. You can make anything work with the wrx ecu but will need some adapters for the cam sensors at the very least...
Fongers is offline   Reply With Quote
Old 01-04-2009, 11:02 PM   #3
305mouse
Member#: 106792
2005 Saab 92X
Stage Pi w/ VF35
Here's a fun little chart to use. I copied it from another thread, very usefull. Look at the head volume.
305mouse is offline   Reply With Quote
Old 01-05-2009, 12:53 AM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
In factory form the USDM STi heads will flow a tiny bit better at lower lifts because of the bigger combustion chamber around the valves. The AVCS also allows the cams to open earlier and the cams themselves have HIGHER lift than the WRX, but are the same duration.
Overall FLOW of the USDM heads, not so much difference at all. The Ver.7 would have to be the Spec C / Type RA head to have a bigger INTAKE port. All Ver.8 heads will have large ports being GD specific.
For me I just like to keep it simple with ported WRX heads and big cams.
Old 01-05-2009, 01:45 AM   #5
Maxwell Power
Member#: 190729
my advice is to match the heads to the bore/block.
Old 08-20-2016, 07:16 PM   #6
ej2007
Member#: 437259
2007 wrx
Default 07 wrx needs heads. Options 07 sti or 08 sti
Just wondering if one of these choices is better. The big difference, from what I can tell, is the single and dual avcs. Not sure but don't think I can get the dual avcs feature to work on my car without a wiring harness from an 08, which I am not going to do. other than that the 08 will be the same as the 07, right?
The reason I am asking is because my cam journals are scored from loosing a rod bearing and I need new heads. Both these head are available for the same price.
ej2007 is offline   Reply With Quote
Old 08-22-2016, 09:52 AM   #7
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Do the least amount of work, it is more likely you will get the car running and enjoy it.
slowgenius is offline   Reply With Quote
Old 08-29-2016, 01:00 AM   #8
VMOMMO
Member#: 408486
2001 STi Wagon
V7 JDM has the big ports too, Spec C had a little bit of porting done. V8 and V9 they didn't do any porting work on.
VMOMMO is offline   Reply With Quote
wrx heads/sti block, current wrx heads ej20g 4banger4dr Built Motor Discussion 6 11-14-2009 04:55 PM
STi heads vs WRX heads with big cams japslapr Built Motor Discussion 1 06-09-2009 01:05 AM
ej20g vs. wrx heads TorqueMaster Built Motor Discussion 3 06-24-2008 02:15 AM
JDM Sti Head vs. wrx head M3GTR Subaru Conversions 14 03-07-2005 08:16 PM
RS Heads vs. WRX heads JDM_Scobaru Subaru Conversions 39 01-10-2005 03:36 AM
