#526 | |
Member#: 492327
Vehicle:19 WRX 16 STI 17Golf-R 16FiST 20Supra |
![]() Quote:
Someone noted they wanted a used BRZ because at the $1x,000 prices it made sense. I can understand that, my pos FiST is used and had less than 19K miles, only paid $16.5K plus tax.. basically pocket change for a beater scooter and it's been flawless, actually. I don't really care to keep it or toss it.
#527 | |
Member#: 377200
Vehicle:20 Camaro SS1LE Shadow Grey |
![]() Quote:
Tada-San wanted NA. Subaru wanted turbo. Tada-San won and this is what we got. I suspect it's why the next variant will be NA as well. Because Tada-san wants it. That said, nothing wrong with NA if you have an engine that produces enough hp/tq. And has the right tune. |
#528 | |
Member#: 492327
![]() Quote:
I'm also perfectly okay with NA if it matches the shape of the car and hype.. but probably will not meet the emissions and mpg expectations of 2021 at those power levels we are thinking about. |
#529 | |
Member#: 2272
BAIC
Vehicle:1999 2019 Macan 4cyl 93 FWD Base Imp WRX swap |
![]() Quote:
If you think one flaw of the twins, the engine power delivery, is reason enough to write off the whole car as half baked then yes, GTFO and grow up. |
#530 | |
Member#: 7887
Vehicle:2016 Red Car 2019 Blue Car |
![]() Quote:
Given the choice between a 200hp 1.6T and a 200hp 2.0 N/A, I’d go N/A all day for a car like this. If we were talking a FWD hatch, 1.6T. |
#531 | ||||
Member#: 153088
Vehicle:2005 Baja Turbo 95 Sambar 06 Forester |
![]() Quote:
![]() ![]() Quote:
#532 | |
Member#: 94408
E. Canada
Vehicle:17 STI Sport-Tech 20 Corolla Hybrid Premium |
![]() Quote:
And it’s not slowness that makes those sporty underpowered cars handle well, its weight. Light cars respond better to inputs, plain and simple... quicker input response and a tossable feel. In the case of this segment, add in weight distribution, CoG, and RWD and it gets even better. Why bother making another? To have a light and nimble, close to 50/50 weight, RWD, manual sports car with a more modern interior, and most likely more chassis/handling refinements than the previous gen... sounds like good reasons to me. I do get the twins’ formula isn’t everyone’s cup of tea, but I really don’t want to see this turn into a pig of a car pushing 3000+ lbs. |
#533 | |
Member#: 87888
South East
Vehicle:2007 Mazda Miata POS Green(and black) |
![]() Quote:
#534 | |
Member#: 87888
South East
![]() Quote:
#535 | |
Member#: 73805
![]() ![]() Quote:
#536 |
Member#: 94408
E. Canada
![]() That grille shot looks like a normal AC heat exchanger... it looks set in too deep to be a front mount. But who knows... I don’t get how it would work with the 4-cylinder Supra in the mix either, both on power and price point.
#537 | |
Member#: 183032
NESIC
Vehicle:RWD Camry Pull me over red |
![]() Quote:
Think if it similarly to the Camaro & Corvette strategy, higher end Camaros walk into Corvette pricing and performance, but are 2+2 and don't carry the same "prestige" that a Corvette does. |
#538 |
Member#: 492327
#539 |
Member#: 46277
Vehicle:** LP640 575M DMC-12 |
#540 |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
![]() Dual eyesight cameras on that prototype. Interesting. I believe an earlier mule had a single camera.
#541 |
Member#: 67807
NWIC
Vehicle:V^V justrememberall capswhenuspellyomansname |
![]() Daym Daniel. |ntrc00lrz ![]() |
#542 | |
Member#: 183032
NESIC
![]() Quote:
Throwing more power at an FF chassis to combat the weight gain just means traction issues and torque steer, not to mention increased/constant computer intervention. Nearly all cars out there have gotten 'better' in measurable metrics or at least maintained where they were, but in the immeasurable, the enjoyable, from an enthusiasts standpoint, nearly all have gotten worse. Admittedly - I really don't care for FF, the only modern performance FF offered in the US that I haven't driven is the CTR, because I have no interest in owning one, yeah it has more power than and higher handling limits than a GTI, but it's not going to be any less front wheel drive than the GTI is, and the only reason I test drove a GTI and other FF stuff was because people kept telling me "FWD isn't what it used to be". There is nothing modern out there that can mask it's weight. Drive some modern FF stuff back to back with the same model from a few years and a couple hundred pounds ago, you can feel the added weight, regardless of how well the newer iteration may handle or how much quicker it might be. Same goes for FA and FR stuff, I'm not just beating up on FF; the difference is though that an FA and FR chassis has physics on it's side when trying to put the power down/accelerate. You could make the same argument about RWD as you did FWD, it's not the same - the Mustang & Camaro have gotten significantly better than previous iterations with regards to handling chops, interior quality, comfort, etc. They have however, also gained weight, like a lot of weight, and it's obvious when you toss them around, yeah they handle better but they feel heavier. My fox body didn't even have ABS (or cup holders), the SN95 and new edge models managed to gain a couple-few hundred pounds, and the S550 a couple-few hundred more. I've driven examples from every gen except the 2nd gen, and although they've gotten "better" every generation, they've also gotten worse. Then again, I could just be an old man yelling at clouds. In closing, FF is still FF, it's just a nicer place to be than it used to be, and that applies to every vehicle layout out there. Last edited by Sid03SVT; 08-14-2020 at 03:23 PM. Reason: I can't English good |
#543 | |
Member#: 94408
E. Canada
![]() Quote:
Now if the Supra 2.0 (and consequently the 3.0) get a power bump by the time the hypothetical turbo twins come out, it might clarify the difference more. I don***8217;t see the turbo happening either, but time will tell.. Ooooh look a turbo 86! boost yo! ![]() Exactly... that looks the same setup as the spy shot Last edited by littledrummerboy; 08-14-2020 at 04:04 PM. |
#544 | |
Member#: 153088
![]() Quote:
If there was one with one camera, you think they may have been testing a Toyota Safety Sense system, then one with EyeSight to see which would go better with this car? My question, since seeing this, is will Toyota put "EyeSight" on theirs? If they do, do they just call it "TSS"? Or actually still call it EyeSight? My main interest in this car now is, what platform/who builds it. |
#545 |
Papi Chulo
Moderator Member#: 53794
RMIC
Vehicle:... 2017 BMW M2 2017 F-150 |
#546 |
Member#: 128484
International
Vehicle:2006 EDM WRX STI WRB |
![]() that´s what you see after the grill delete, and it´s not an intercooler for a terbo
#547 | ||
Member#: 67807
NWIC
![]() Quote:
#548 |
Member#: 87888
South East
#549 |
Member#: 28976
Vehicle:2016 Step 2 Push Buggy GT |
![]() WHOA!! I go away for a few hours to work and looky here looky here. New spy pics. The dimensions look good, the rear hatch/spoiler reminds me of the supra.
#550 | |
Member#: 115480
Vehicle:2014 Mazda3 sGT Soul Red |
![]() Quote:
Look, I realize the futility in calling the most tracked car in the world half-assed, I do. And indeed, I will prefix the notion I'm not one of those knuckleheads asking for moar powar in the Miata. I only hope my post delivers the nuance that I have in my head. But I do think, as far as my personal considerations, that the Miata has spent most of it's life as a outstanding chassis in search of a motor. Again, not because of power, but more so power delivery. At least in my own experience with the models I haven personally driven, the NA, NB, and NC were all saddled with "average"... kind of "USDM-economy-car" feeling motors. I don't know if that was a direct result of Ford's input, as Mazda did indeed design all the variant MX-5 engine designs AFAIK even if they did double for Ford duty. But regardless, none of the motors I have personally driven had exciting powerbands, they were all kind of boat-anchory engines (the NC perhaps least of all, but not a concise difference thanks to the weight gain of that generations' shared platform), with even the turbo Mazdaspeed MX-5's running out of steam in the last 1000rpm. Only now with the ND2 have they finally fitted a performance-feeling engine with a higher revving, peakier powerband that accentuates the light and handling focused chassis's strengths, imo. By coincidence, it is also now quite a properly quick car; significantly quicker than the twins even with less power. It's always been a wonderful car, especially as a platform for tuning and track duty, but only now I think has it realized the potential it's had all these years. If that constitutes that the old ones were half-assed, I don't know, but I do think they were flawed masterpieces. Last edited by Skunkers; 08-16-2020 at 06:34 PM. |
