Welcome to the North American Subaru Impreza Owners Club Thursday January 21, 2021
Old 11-27-2004, 05:09 PM   #1
JDM_Scobaru
Member#: 57809
Default RS Heads vs. WRX heads
I am thinking about doing a Turbo Legacy Swap to my car, but I want to relplace the legacy heads with different better flowing heads. So how do the RS heads compare to the WRX heads in terms of flow.
Thanks,
Zach
JDM_Scobaru is offline   Reply With Quote
Old 11-27-2004, 05:50 PM   #2
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
Zach,
Just wanted to let you know. I'll be in chicago after december 20th. If you would like to check out the head then you certainly can. I'll also give you a good deal because I need to empty my garage (the heads have both cams and should be perfectly fine, but they need to be cleaned and I would suggest replaceing the cams because I accidently droped one onto the floor.
DoctorNick is offline   Reply With Quote
Old 11-27-2004, 07:51 PM   #3
JDM_Scobaru
Member#: 57809
So how do WRX heads compare to RS heads?
Old 11-28-2004, 04:37 PM   #4
darksurfer81
Member#: 57459
2001 2.5RSTi
Blue Ridge Pearl
I have heard that the RS heads were some of subarus best flowing heads, but you may need to do a search on www.RS25.com, I know there are some threads about it there I remember reading awhile back.
darksurfer81 is offline   Reply With Quote
Old 01-05-2005, 12:03 AM   #5
lotus2843
Visiting NASIOC Timeout
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
good question.... Anyone???
lotus2843 is offline   Reply With Quote
Old 01-05-2005, 01:09 AM   #6
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
Zach, you still want these wrx heads?
Old 01-05-2005, 01:11 AM   #7
JDM_Scobaru
Member#: 57809
No thanks though i already gave a guy $5000 for a wrx swap in March, If anything changes though or plans dont go through Ill contact you.
Thanks again,
Zach
Old 01-06-2005, 04:21 PM   #8
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
There are two different verions of the 2.5 RS head. The first was the MY 1998 DOHC head that came on the 1998 RS. After that, Subaru changed over to a SOHC design for the remaining GC8 RS body style (through 2001). There was no increase in power as a result of the transition to the SOHC for the RS.
COBB is about the only company that has done any extensive work on the RS head. On the intake cycle, a BONE STOCK *SOHC RS head flows more air than a stock GM LS1 head. Quite impressive. The only problem that I have found with the SOHC RS head is that the cam profile is too small, netting a rather dramatic dropoff in power past 5500 RPM. However, a large turbo suited to high RPM power making can alleviate some of the fall-off that RS-T owners experience. A cam is another good option.
I have not seen any empirical evidence to suggest that the WRX head flows MORE than the RS head. I would imagine though, that it does have a more aggressive cam profile to lengthen the threshold of power fall-off as a result of the rather small turbo that the WRX comes with from the factory. However, I have not seen any benchflow statistics to prove that the WRX flows more. COBB would be a good source to research for factual evidence.
To say one is better is not entirely accurate. A lot of it depends on what you want to do. Both heads (with stock cams) have made VERY VERY impressive numbers on the dyno. For the RS head, one must look no further than how much power Mark R. (xephyr on the forum) has recently made in his 2.5 RS with the stock DOHC design heads. 452 WHP @ 21 psi.....The WRX has also pushed similar, and prob higher, power levels.
Graham
Graham is offline   Reply With Quote
Old 01-06-2005, 04:46 PM   #9
JDM_Scobaru
Member#: 57809
hmm very informative
Old 01-06-2005, 04:52 PM   #10
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
RS heads can probably be had a bit cheaper and maybe more readily available. I would get RS heads personally, but in the end it probably won't make the hugest difference assuming a semi-realistic power goal for most daily drivers. My 2cents
Soon2Bgreat is offline   Reply With Quote
Old 01-06-2005, 05:24 PM   #11
JDM_Scobaru
Member#: 57809
Hmm....Thanks everybody for the good input
Old 01-06-2005, 05:55 PM   #12
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Talking
Neither have I.
Wedge is offline   Reply With Quote
Old 01-06-2005, 06:57 PM   #13
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
I was wondering when you were gonna step in wedge
Old 01-06-2005, 07:15 PM   #14
JDM_Scobaru
Member#: 57809
Hmm interesting results, what about a stage one for WRX heads?
Old 01-06-2005, 07:27 PM   #15
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Vic- thanks for the information, quite helpful.
JDM- A stage one setup for the WRX would certainly improve airflow, but then again so would a stage one for the RS heads. Also, about 6 months ago I saw a dyno plot of a WRX that had done a cam swap to HKS 264's I believe. With something along the lines of a VF22 sized turbo, the power increase was ALL transferred to the upper RPM range. Yes, this would be fun if you want a car that is top-end heavy in the powerband, but that is not going to get you out of corners quickly on a race track. Thus, the whole argument goes back to what kind of application you are aiming for. A cammed, top-end happy WRX head would be wicked on the drag strip, but horrible for a road course where you want power down low. Also, depending on what size turbo you are using, having a medium range power cam in the car can aide spoolup tremendously versus a a high profile cam that only delivers power on the top-end.
Soon2beGreat- You hit the nail on the head...unless you hovering above the 400+ WHP range, I just don't think you find extremely noticeable differences between the two heads. Another factor is that assuming you have a GC8 chassis/ECU, you would have to wire in the WRX heads. RS heads are certainly easy to come by, and cheaper.
Graham
Old 01-06-2005, 08:13 PM   #16
JDM_Scobaru
Member#: 57809
Well in a little whie, I will have a JDM ej20 in my car, what cams would be an upgrade for the car?
Old 01-06-2005, 08:14 PM   #17
JDM_Scobaru
Member#: 57809
Also how hard is it to put cams in that motor, how long and what would have to be done?
Old 01-06-2005, 08:17 PM   #18
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
Jun 264 would be a nice medium.
Subarustore.com has cheaper cams, forgot who makes them.
Its a PITA, better do it while the motor is out. Did cams once in the RS, and thats much easier then the wrx.
Old 01-06-2005, 08:33 PM   #19
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I think you should leave the stock cams in the car and save money on the cams you would have put in. Plus, I would not doubt it if the JDM cam profile was more aggressive than their USDM companions. But then again, it would be easy to do while you have the motor out of the car.
Graham
Old 01-06-2005, 08:40 PM   #20
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
RS heads: SOHC you gotta buy cams, DOHC, you have to oversize valves and port. Which bang are you going to take is the question i think...
Old 01-06-2005, 08:46 PM   #21
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
I hear the usdm sti cam is another option. Also more likely to find a set of those for a decient price with all the new deep pocket sti owners.
Old 01-06-2005, 09:23 PM   #22
JDM_Scobaru
Member#: 57809
Then what mod, if i choose to leave the JDM cams in, should i do, to the motor?
Old 01-06-2005, 10:32 PM   #23
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
What kinda JDM motor? G? K?
Honestly, if your getting an older JDm model, like V4 old, I would get cams. But I would just say just do the BPU mods (IC, samco hoses, TBE, Headers mabye?)
Old 01-06-2005, 11:12 PM   #24
JDM_Scobaru
Member#: 57809
its a JDMEJ20G
Old 01-06-2005, 11:12 PM   #25
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I'd just leave the cams stock, just get basic stuff like exhaust and get the car tuned.
sti heads vs wrx heads redwrxhead Built Motor Discussion 7 08-29-2016 01:00 AM
STi heads vs WRX heads with big cams japslapr Built Motor Discussion 1 06-09-2009 01:05 AM
ej20g vs. wrx heads TorqueMaster Built Motor Discussion 3 06-24-2008 02:15 AM
RS DOHC vs SOHC heads Unsung Boxer Normally Aspirated with bolt-on Forced Induction Powertrain 31 09-12-2005 04:49 PM
JDM Sti Head vs. wrx head M3GTR Subaru Conversions 14 03-07-2005 08:16 PM
