Welcome to the North American Subaru Impreza Owners Club Tuesday January 26, 2021
Old 03-03-2005, 06:43 PM   #1
M3GTR
Member#: 21965
V-mounted 40R...what
Default JDM Sti Head vs. wrx head
Hey I am just curious if the jdm sti ver. 7 or 8 is the same volume as the usdm stock wrx heads. I know the usdm sti heads have larger volume compared to wrx ones, and I wanted to be safe in case I plan on switching over to sti heads when I do my swap. Thanks all.
-Nate
M3GTR is offline   Reply With Quote
Old 03-03-2005, 11:44 PM   #2
JDM_Scobaru
Member#: 57809
usdm things dont even compare to JDM things.
JDM_Scobaru is offline   Reply With Quote
Old 03-03-2005, 11:51 PM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
V8 are the ultimates for now, best flowing
Hyper is offline   Reply With Quote
Old 03-03-2005, 11:59 PM   #4
JDM_Scobaru
Member#: 57809
agreed with hyper
Old 03-04-2005, 01:11 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
DO a search. There was great thread last year on heads with pics and measurements and all that jazz with Kingpin and Sponaugle and many of the serious tuners around here comparing notes on a number of heads...
Old 03-06-2005, 01:58 PM   #6
M3GTR
Member#: 21965
i am not talking about how much the heads flow, I am talking about the actual volume of the combustion chamber. i want to know how much volume each combustion chamber contains as to be sure my compression ratio stays the same.
Old 03-06-2005, 02:25 PM   #7
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
v7 RAC--is 48cc's (factory spec) but jeff sponaugle measured them at 50cc. WRX ones are 52cc's and jeff measured at 51cc.
What setup is this going to be...obviously you have a bunch of other factors to take into account. Hope this helps.
Soon2Bgreat is offline   Reply With Quote
Old 03-06-2005, 04:46 PM   #8
M3GTR
Member#: 21965
my setup is the following: EJ22t bored 20 over, 2.5RS crankshaft, stock wrx length pauter rods, custom dished CP pistons (for 8.5:1 compression i believe). I am debating between cylinder head setups. I can either go with the stock wrx head, ferrea valvetrain, and crower stage 4 cams, or I can go with the sti ver. 7/8 cylinder head, also with crower cams. I am wondering if I do decide to go with the sti cylinder head, how badly it will affect my compressino ratio.
Old 03-06-2005, 08:19 PM   #9
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Sounds nice...any reason you didn't opt for 2.5 length rods also since you are doing custom pistons? What comp. ratio are you shooting for?
Old 03-06-2005, 08:52 PM   #10
M3GTR
Member#: 21965
the wrx length rods are only 1.2mm shorter than the 2.5 length rods. There are some benefits to running the longer rod, but it was more convinient to run wrx length rods. Also the benefits will be relatively minimal since the length difference is so small. I am shooting for 8.0 - 8.6:1 compression ratio.
Old 03-07-2005, 01:41 AM   #11
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
http://forums.nasioc.com/forums/show...light=cam+info
I would just stick with the wrx heads if your going with the cams. Trying to put the crowers in the jdms seems like a waste.
Old 03-07-2005, 03:09 PM   #12
M3GTR
Member#: 21965
what makes you say that, because i cant use avcs?
On a note on the heads. I was told that the wrx heads are 52cc, and the jdm heads are 48cc. If my compression ratio would be 8.5:1 with the wrx heads. My compression ratio would be 8.89:1 with the jdm heads. This is a little high for me. Do I want the upgraded flow of the jdm heads? or do I want more boost and more timing advance out of lesser heads. I am leaning towards the latter.
Old 03-07-2005, 03:14 PM   #13
M3GTR
Member#: 21965
totoherbs, i wish you wouldnt send me a link to a thread with 173 posts, mainly about engine codes, without pointing out a specific area of the thread. I appreciate the help though.
Old 03-07-2005, 07:24 PM   #14
totoherbs
Member#: 7321
.... 122 IggPoints
With a turbo larger ports do not matter that much, all they will do is move your power band over some. The cams will more then make up for the small port wrx heads.
Ya, doing your own research sucks huh...
Old 03-07-2005, 08:16 PM   #15
M3GTR
Member#: 21965
i have done plenty of my own research, and yes it does suck
sti heads vs wrx heads redwrxhead Built Motor Discussion 7 08-29-2016 01:00 AM
Indiana FS: v3 JDM STi tranny, 02 wrx heads, misc parts Feign MWSOC Private Classifieds 30 09-14-2009 09:55 AM
STi heads vs WRX heads with big cams japslapr Built Motor Discussion 1 06-09-2009 01:05 AM
jdm v7 heads vs cosworth heads petawabit Built Motor Discussion 24 09-09-2006 07:44 AM
RS Heads vs. WRX heads JDM_Scobaru Subaru Conversions 39 01-10-2005 03:36 AM
