Welcome to the North American Subaru Impreza Owners Club Monday September 24, 2018
Old 06-11-2012, 11:51 AM   #726
mhs5074
Member#: 184485
'06 STi AW
'08 FXT Sport 4EAT DGM
Here are mine:
mhs5074 is offline   Reply With Quote
Old 06-11-2012, 11:58 AM   #727
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
^^^ beautiful
GhostSenshi is offline   Reply With Quote
Old 07-03-2012, 07:56 PM   #728
Vigher
Member#: 316092
2012 Impreza Hatch
Dark Gray Metallic
When installing these do most people remove the stock horns or leave them in? Reason I ask is with the stock security system ( i assume the horns and security are connected) how would the alarm be integrated into the Hellas if the stock horns are pulled?
Vigher is offline   Reply With Quote
Old 07-03-2012, 08:23 PM   #729
aeion
Member#: 182114
1996 Nissan HARDbody
1931 Ford Model A
Remove the stock. The hellas run on the stock horn system using the stock wires
aeion is offline   Reply With Quote
Old 07-03-2012, 10:38 PM   #730
theoutbackdream
Member#: 301179
2013 WRX Limited
In my 09 I left the stocks that's near the dlr connector.
theoutbackdream is offline   Reply With Quote
Old 07-04-2012, 06:46 AM   #731
frederik
Member#: 64405
2018 STi
Of the two stock horns wires, I used one to trigger the relay powering the hellas, and I kept the lower note stock one in place. After trying them I felt that the hellas needed a little more low end frequencies, and it probably makes for an even more dissonant tone
Fred
frederik is offline   Reply With Quote
Old 07-08-2012, 09:15 PM   #732
Subi3b00bi3
Member#: 237190
2003 Matte White Wrx
2006 WRB STi 2007 SWP STi
does anyone know if u could buy a new relay at any autozone/advanced?
Subi3b00bi3 is offline   Reply With Quote
Old 07-08-2012, 10:27 PM   #733
cpc691
Member#: 195739
2002 wrx wagon
I know for sure you can get a new one at radioshack
cpc691 is offline   Reply With Quote
Old 07-09-2012, 04:08 AM   #734
Subi3b00bi3
Member#: 237190
thanks man
Old 07-15-2012, 01:53 PM   #735
seattlesuperchronics
Member#: 297651
Does anybody have a link/tips on how to wire the 4 horns. I am willing to delete or keep the stock horns. Do not want a switch. I couldn't find one last night and right now I'm at work so I dont have the time till I'm off. Thanks in advance guys
seattlesuperchronics is offline   Reply With Quote
Old 07-15-2012, 03:01 PM   #736
frederik
Member#: 64405
2018 STi
Use one of the 2 oem horns wires to trigger a relay. Then use the contact of the relay to switch a fused 12v coming directly from the battery. On the "ouput" side of the contact, splice into 4 wires feeding power to the 4 horns. Run a negative wire to the other side of all the horns (you can take a single wire from the battery, go to the first hella, and jump it one hella to the other. As long as the wire is big enough voltage drop sbould not be an issue).
It is pretty much the same as you would do with 2.
Old 07-15-2012, 04:20 PM   #737
dibblejr
Member#: 94070
05 LGT
Just delete the stockers and replace with the ST's. The stock ones are useless. I have installed hundreds of sets. Ensure to use the harness, relay ect that comes with the kit.
Takes about 30 or so minutes for an easy install
dibblejr is offline   Reply With Quote
Old 07-16-2012, 12:58 AM   #738
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Originally Posted by frederik View Post
<snip> Run a negative wire to the other side of all the horns (you can take a single wire from the battery, go to the first hella, and jump it one hella to the other. As long as the wire is big enough voltage drop sbould not be an issue).
I'd ground the horns directly to the chassis right there and protect the connection with dielectric grease.
Additional wire length will inevitably increase the total circuit resistance, especially as the cable degrades from environmental exposure after the first year.
Mike Costin is offline   Reply With Quote
Old 07-16-2012, 01:14 AM   #739
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Old 07-19-2012, 04:02 AM   #740
Member#: 297651
i was worried about the horns losing power if i spliced all 4 from one line, and as for the harness set up i made my own a while ago when i hooked up 2, now i am (will be) hooking up the second set. i have 12 gage wire, will this be an issue with resistance? and also is there any problems with that so far? and yea im pretty sure i get exactly what your saying but i wasnt sure if there was a better way, or a diagram. but thank you all!
Old 07-19-2012, 04:13 PM   #741
nappynick
Member#: 317114
'12 WRX Hatch
This is regarding the SuperTones. Where do you guys recommend buying these? I saw a vendor selling them in a bunch of different colors. I looked and could find that vendor. whats is a good price for these. Car is a '12 WRX. thanks again.
nappynick is offline   Reply With Quote
Old 07-19-2012, 04:29 PM   #742
dickiescoob
Member#: 259508
2015 WRX Limited
Bought my wife's from subimods. Liked how they came powdercoated, she got the pink, and they are very bright.
dickiescoob is offline   Reply With Quote
Old 07-19-2012, 04:49 PM   #743
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
JNA Performance: http://www.jnaperformance.com/index....&variant_id=71
Old 07-21-2012, 01:11 PM   #744
aggiee7
Member#: 318648
2007 Impreza 2.5i
UGM
To those who used the stock wiring harness, how were you able to lengthen the wires? I just unplugged them and have no slack to bring them to where the are supertones mounted?
aggiee7 is offline   Reply With Quote
Old 07-21-2012, 03:50 PM   #745
theoutbackdream
Member#: 301179
2013 WRX Limited
Buy the connectors and more wire......??????
Old 10-12-2012, 09:49 PM   #746
nukem384
Member#: 126749
nukem384 is offline   Reply With Quote
Old 10-13-2012, 04:28 PM   #747
JavaBot
Member#: 156723
17 2.5i foz dgm
rip wrx/rs/2.5i/foz1
All you need to make your own harness is a male to female wire, and female to ground(spade) wire for each horn.
I just got the jna green Hellas and some 18 gauge green wire from pep boys with a few connectors and put about a foot extension for each wire and was able to reach.
It's actually quite easy using stock power connector, and I didn't realize gc's only had one puny stock horn.
JavaBot is offline   Reply With Quote
Old 10-21-2012, 07:42 PM   #748
youngxlos
Member#: 232169
2002 Hawkeye
World Rally Blue Pearl
does the size of the wire matter? i ran out of 14 gauge wire but i have a lot of 18 gauge wire, could i just use the 18 instead of the 14??? would this decrease the sound????
youngxlos is offline   Reply With Quote
Old 10-23-2012, 04:43 PM   #749
infinite012
Member#: 74392
08 LGTB, 15 Foz
DGM, SWP
Old 10-24-2012, 09:29 PM   #750
frederik
Member#: 64405
2018 STi
These looks like a small pair of boxing gloves haha
How is the tone of these compared to the regular supertones ?
How to: Install Alpine HU-Currently Have Sony gtwagon941 Car Audio, Video & Security 13 02-15-2006 01:35 AM
How to: install Megan coilovers? spooledwrx Interior & Exterior Modification 12 01-20-2006 12:14 AM
How to: Install a new clutch no_rex_yet Off-Topic 11 11-12-2004 02:45 PM
How To: Install WRX Turbo/IC on a 2.2L Pepo Normally Aspirated with bolt-on Forced Induction Powertrain 12 10-08-2004 11:18 AM
how to: install rear trailing arm bushings Scott F. Williams Brakes, Steering & Suspension 4 11-06-2002 11:37 AM
