Welcome to the North American Subaru Impreza Owners Club Sunday July 22, 2018
Old 08-21-2009, 02:07 PM   #476
640k
Member#: 160315
2008 STI
that looks like it makes sense. bnr34rb26dett, is that what you've done?
640k is offline   Reply With Quote
Old 08-21-2009, 04:59 PM   #477
bnr34rb26dett
Member#: 188424
2012 LS6 FD RX7, Evo
this is what i was doing.
would splitting the grounding cables into two separate cables really make that much difference??
and also, should i ground the cables at separate points or would that not matter?
Rippen Griffen, thanks for the awesome picture and quick response by the way
bnr34rb26dett is offline   Reply With Quote
Old 09-03-2009, 10:30 PM   #478
subyrally
Member#: 52662
2009 WRX. 06 Baja
17 Crosstrek 85 brat
i was going to install the hellas that i had in my old impreza into my 09 tonight, but i couldnt find the stock horn, lol. does anyone have a pic of the stock horns on the 08-09 wrx? also, when i was looking behind the grille for places to mount the hellas, i only noticed one viable hole on the passenger side, any suggestions?
subyrally is offline   Reply With Quote
Old 09-03-2009, 11:39 PM   #479
J-Rod 555
Member#: 209231
2008 WRX, 95 leggy
White to the both of them
there is one horn in the grille. The other one is under the airbox, you will have to remove the airbox to get at the second one...
J-Rod 555 is offline   Reply With Quote
Old 09-04-2009, 01:23 AM   #480
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
weird mine only have 1 hella stamp at the top
feint05 is offline   Reply With Quote
Old 09-04-2009, 10:13 AM   #481
subyrally
Member#: 52662
2009 WRX. 06 Baja
thanks, ill post pics when i finally get it done.
Old 09-04-2009, 05:30 PM   #482
J-Rod 555
Member#: 209231
2008 WRX, 95 leggy
heres what mine look like.......terrible pic though
Old 09-05-2009, 01:03 PM   #483
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
If want to keep my stock horns and switch between the two, can I simply (yeah, I know, nothing is that simple) wire the steering wheel switch through a 2 position switch (one for OEMs one for Hellas) then from that switch to each horn relay? I haven't done much automotive wiring so any suggestions here would be appreciated.
Ogden is offline   Reply With Quote
Old 09-11-2009, 12:53 PM   #484
Cllzzrd
Member#: 209228
2002 Bugeye WRX
Ogden, I am planning to do something very similar. When i do my install, I plan to make a write up so people who want to be able to switch between their stock and hellas can see an easy way. I have put a lot of thought into how I am going to do it, but I am still uncertain of a few things, so I am not going to say anything right now. This is to avoid confusion.
My hellas come in monday, and hopfully go on tuesday!
Cllzzrd is offline   Reply With Quote
Old 09-11-2009, 01:55 PM   #485
POP3Y3
Member#: 149465
2003 2.5R(eal)S(low)
^^^evil red eyes... shape of the grille makes it look like you have a Ninja in your car ready to jump out and karate chop someone
POP3Y3 is offline   Reply With Quote
Old 09-11-2009, 07:21 PM   #486
Safe Drives
Member#: 75146
1998 Impreza Wagon
Not too far from the truth really...
Safe Drives is offline   Reply With Quote
Old 09-11-2009, 10:07 PM   #487
J-Rod 555
Member#: 209231
2008 WRX, 95 leggy
Changed the grille a little bit, painted the WRX badge...sorry bout the piss poor lighting.
Old 09-13-2009, 09:10 PM   #488
Civ2Sub311
Member#: 178149
2018 WRX Limited
CWP
Followed Car vs. Driver's instructions today to the T...worked great on the first shot! Took a while but it was worth it! Make sure you get a ring terminal or two for the battery connection..they help and he forgot to put them in the tools needed list!
Civ2Sub311 is offline   Reply With Quote
Old 09-15-2009, 08:33 PM   #489
mctecnica
Member#: 216068
Note to self: If you install hella supertones inside a garage wait to get outside to test them. My ears are still ringing.
mctecnica is offline   Reply With Quote
Old 09-16-2009, 03:55 AM   #490
Evilchargerfan
Member#: 183529
i wanna help teh
haters ... love life ...
^^^ i too learned that lesson teh hard way, lol
Evilchargerfan is offline   Reply With Quote
Old 09-16-2009, 06:04 AM   #491
640k
Member#: 160315
2008 STI
when i installed them, i honked them from inside the car and though, "how directional could they be?" and thought they didn't sound very loud. so I went around the front of the car and chirped the horn and that's when i knew...
Old 09-16-2009, 06:16 AM   #492
Aggent15
Member#: 173755
05 STI Satin Black
Specialized Allez Elite:)
lmao yeah I learned my lesson when I had just the FIRST ONE hooked up and my roommate walked by, reached in the car, and said do they work HHOOONNNNKKKK. I was turned sideways with the first horn pretty much right next to my ear.
Aggent15 is offline   Reply With Quote
Old 09-16-2009, 04:38 PM   #493
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
just installed them, this write up made it sooo easy!
codesoccer is offline   Reply With Quote
Old 09-18-2009, 04:41 AM   #494
chino_says
Member#: 94265
MY05 WRX
stg2
+11billion!
chino_says is offline   Reply With Quote
Old 09-18-2009, 03:34 PM   #495
Aggent15
Member#: 173755
05 STI Satin Black
How ya like me now
Old 09-18-2009, 03:35 PM   #496
640k
Member#: 160315
2008 STI
you should angle the bottom two horns to the side. they're not doing you any good anyway.
Old 09-19-2009, 12:18 AM   #497
SnakeFart
Member#: 217632
2009 Impreza WRX
Dark Grey Metalliac
Nice write up, going to do this tomorrow.
But I have a few questions. I have an 09 wrx, there is only 1 horn behing the grill. Where is the other? Under the air cleaner box or near the abs controller? I haven't torn into anything on this car yet.
When I chirp the alarm will the hellas go off or will it use the 2nd horn (if I have one)?
When the alarm/panic sounds will it use the hellas or the 2nd horn (if I have one)?
SnakeFart is offline   Reply With Quote
Old 09-19-2009, 12:18 AM   #498
SnakeFart
Member#: 217632
2009 Impreza WRX
Dark Grey Metalliac
Double post
Old 09-19-2009, 06:23 PM   #499
640k
Member#: 160315
2008 STI
08 sti. same system. your other horn is beneath the passenger side of the bumper. once you take the bumper off, you will see it.
If you splice into the front horn, your hellas will go off with panic/chirp. can't say the same about the other one, since i wouldn't know.
Old 09-20-2009, 12:49 AM   #500
SnakeFart
Member#: 217632
2009 Impreza WRX
Dark Grey Metalliac
Thanks 640k. After I put them on ill hae to remember to chirp when I'm not walking away from it. :P
How to: Install Alpine HU-Currently Have Sony gtwagon941 Car Audio, Video & Security 13 02-15-2006 01:35 AM
How to: install Megan coilovers? spooledwrx Interior & Exterior Modification 12 01-20-2006 12:14 AM
How to: Install a new clutch no_rex_yet Off-Topic 11 11-12-2004 02:45 PM
How To: Install WRX Turbo/IC on a 2.2L Pepo Normally Aspirated with bolt-on Forced Induction Powertrain 12 10-08-2004 11:18 AM
how to: install rear trailing arm bushings Scott F. Williams Brakes, Steering & Suspension 4 11-06-2002 11:37 AM
