Welcome to the North American Subaru Impreza Owners Club Monday June 25, 2018
Old 09-04-2011, 01:04 AM   #651
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Originally Posted by Baconsnake View Post
Backstory:
12 months ago, bought a pair of supertones + relay. Installed and working fine
A couple months ago, my supertones stopped working, but the regular horn was fine.
This past week, during the rain - the supertones would go off for no reason, AND NOT STOP! I took the keys out of the ignition, WOULD NOT STOP! So I pulled the fuse, and it finally stopped even though it was really painful to get under the hood.
Fast forward to today, where I am checking out my connections, and what do I see?
Yes, always a good idea to use dielectric grease. Yes, it's a good idea to hang relays with the contacts/openings down.
But that is an abnormal amount of corrosion. I've seen less corrosion on relays used in a marine application for a decade.
Was the relay located near an aging battery or the coolant overflow? Was it exposed excessively to road salt? Was it submerged in water?
Did the relay fit the harness tightly when first installed? Did the contacts in the harness look like regular 'ole copper?
The corrosion seems to be concentrated around pin 86 which shouldn't see voltage unless the horn button is depressed.
Can you take the relay apart by pulling the mounting hole (case) section away from the terminals (bottom) and snap a picture? I think it's going to look like the Statue of Liberty in there
Mike Costin is offline   Reply With Quote
Old 09-04-2011, 09:39 AM   #652
Baconsnake
Member#: 214880
2009 Outback Sport
Obsidian Black
Located behind the front bumper, ahead of the radiator. VERY easily exposed to salt
It did fit very tightly originally. And the harness looked fine when originally installed.
Sorry I already tossed it, but I would bet you are right. That pin was pitted and almost ready to snap. In fact the connector that was attached to it had corroded and separated as well. Oh, one thing to add is the pin that was most corroded was the one at the bottom based on how it was mounted.
Baconsnake is offline   Reply With Quote
Old 09-06-2011, 11:51 AM   #653
Baconsnake
Member#: 214880
2009 Outback Sport
Obsidian Black
So I got everything installed and working correctly using a new relay and connector. It's packed with grease on the connections, and sealed with hot melt glue both where the wires enter the connector and the seam between the relay. I figure that should keep it water tight.
It's odd, but the yellow wire (not sure what pin that's on) was burnt about 6 inches up the wire. I kept snipping it back until I got to clean wire. A sign of overloading perhaps?
If this ends up failing, I'll definitely be creating my own harness. One that will be long enough to mount inside the engine bay anyway.
Old 09-06-2011, 03:47 PM   #654
Rippen Griffen
Member#: 91708
AD Motorsports FTW
06 OBP - Cobb AP Stg 2
Pre-made Harnesses are available, if you know where to look.
Rippen Griffen is offline   Reply With Quote
Old 09-06-2011, 07:43 PM   #655
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
Once it starts corroding, it'll just keep on travelling. I'm sure the corrosion causes increased resistance and thus heat.
aerosaaber is offline   Reply With Quote
Old 09-06-2011, 10:49 PM   #656
cbrkneedrggr
Member#: 293230
2006 WRX STi
Very nice, i love the look and sound of the supertones! This will defiantly help me out in a few months.
cbrkneedrggr is offline   Reply With Quote
Old 09-11-2011, 08:26 PM   #657
dickiescoob
Member#: 259508
2015 WRX Limited
I've had some hellas on my car for a little over a month now, and all I did was disconnect both stock horns, ground the hellas, then just hook up the hellas to the stock wiring and they were working fine. At least, they worked fine up until about a week ago. I used my hellas in some traffic when someone cut me off, then after that, they no longer worked. I found out it was just the fuse that was blown, so replaced and they worked again. I honked the hellas several times, and they worked for a few days, then blew the fuse again. I was under the impression we didnt need a relay, and could just use the stock wiring on the newer cars (2011). anyone have any suggestions?
dickiescoob is offline   Reply With Quote
Old 09-12-2011, 11:54 AM   #658
olazy
Member#: 263322
2011 WRX Limited
WRBP
it appears you got the wrong impression. looks like you'll be needing that relay.
olazy is offline   Reply With Quote
Old 09-12-2011, 12:01 PM   #659
dickiescoob
Member#: 259508
2015 WRX Limited
Some generic relay from like auto zone should work tho right?
Old 09-12-2011, 01:00 PM   #660
olazy
Member#: 263322
2011 WRX Limited
WRBP
did your horns not come with one?
and yes i believe they are generic 4 prong automotive relays, you will also need a new harness to wire everything together.
Old 09-12-2011, 01:06 PM   #661
dickiescoob
Member#: 259508
2015 WRX Limited
No they did not come with anything. Bought them used, just the horns. Didn't plan on using them on the car, but found out they worked, so I did. Why would I need a harness?
Old 09-12-2011, 01:11 PM   #662
Safe Drives
Member#: 75146
1998 Impreza Wagon
First check for corrosion like the above poster. This could increase resistance and end up blowing fuses. If no corrosion is found, put a 5 Amp bigger fuse in and report back in one week. You really should not need the relay, in my opinion.
Safe Drives is offline   Reply With Quote
Old 09-12-2011, 01:15 PM   #663
Safe Drives
Member#: 75146
1998 Impreza Wagon
Dude is trying to sell you something you don't need....
Old 09-12-2011, 01:25 PM   #664
dickiescoob
Member#: 259508
2015 WRX Limited
A new harness didn't make sense at all.. To me at least. I know its not corrosion because it is less than a year old, and I cleaned it. So I will try a 20amp today, and report back.
Old 09-12-2011, 01:34 PM   #665
Safe Drives
Member#: 75146
1998 Impreza Wagon
Well, keep in mind the you are likely rerouting the wires. You may have a wire pointing upwards where the stock wire was pointing downwards, or something like that. It just sounds suspicious of this since it worked fine for a while and then started crapping out on you. Don't be afraid to slather some grease on there. But first thing, check the wires very well. Make sure there is ZERO corrosion.
Old 09-12-2011, 01:49 PM   #666
dickiescoob
Member#: 259508
2015 WRX Limited
I know that I made sure the connectors were pointing down, since all I did was splice into the stock wiring, run new wire to horns and ground. But ill check that today after work, easy enough to get to. Im hoping that just a bigger fuse dues it.
Old 09-14-2011, 12:39 AM   #667
dibblejr
Member#: 94070
05 LGT
My expert advice- use a relay. I have installed dozens of Supertones and always use the relays supplied or go buy one from an auto parts store. The relay is there for a reason, I have had no problems whatsoever with any horns blowing fuses.
By simply using the oem horn wires and replacing the fuse with a larger amp you run the risk of an electrical fire that can cause you a lot more headaches than a $10 relay.
Best of luck
Jay-R
dibblejr is offline   Reply With Quote
Old 09-15-2011, 12:55 AM   #668
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Best of luck
Jay-R
From my own experience I haven't seen any Supertones kits that come with relays. I do use one on my setup.
I measured a while ago and the Supertones were pulling around 6 or 12 amps (separate or together, I forget) at 13-14V. So this person definitely has a wiring issue that he should sort out regardless of whether he uses a relay or not. There's a significant voltage drop en route to cause the Supertones to pull 15A together.
Old 09-15-2011, 11:09 AM   #669
dibblejr
Member#: 94070
05 LGT
Mike
Every Hella Supertone Kit comes with a relay. As you know I have installed hundreds of these and I have a kit right now. As you can see by the pics the relay is normally tucked under the horns also the box indicates the relay "is included".
Since the kit does not come with wires most people are confused by how to wire the relay and disregard the instructions that are also included in and on the box (as shown by my pictures).
Now if members out there are buying knockoffs or used Hella Supertones then yes they may not be including a relay. You can buy relays at almost any parts store.
Front of box
Inside box (in bottom upper right corner you can see relay)
Directions- show relay
Box showing Relay Included Inside
Old 09-16-2011, 12:27 AM   #670
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Mike
Dang, you're right
I'm going to go dig through my parts boxes because I suspect there are some Hella-stamped relays floating around
Old 09-27-2011, 07:43 PM   #671
SnowMan23
Member#: 135238
2002 Impreza WRX
I agree! I wish I had seem this post when I was installing mine! Although my setup wasn't working at all because I had a bad ground wire. Apparently it's a common problem for the 02 WRX.
SnowMan23 is offline   Reply With Quote
Old 10-06-2011, 09:50 AM   #672
LostAndFound
Member#: 253380
02 WRX
Has anyone purchased a knock off set from ebay? I did and regret it already. Not only am I an electrical retard, the terminals don't have any numbers, and even if it did I have no idea how to read wiring diagrams. Nor did the ebay kit come with anything aside from the horns (but it seems like I certainly have to buy the relay along with additional wiring.
Lesson learned, buy the real deal from one of our vendor.
LostAndFound is offline   Reply With Quote
Old 10-06-2011, 11:11 AM   #673
dibblejr
Member#: 94070
05 LGT
Even on the "Real" Hellas you still have to look at wire diagram. Only the relay is marked. A lot of people get confused.
If you look at the picture I posted above it has the wiring diagram. Study it and it will make sense. PM me if you need additional help.
Read, read and read again PRIOR to installing. I precut all of my wires and always keep them on hand so when a friend needs an install it is ready.
Takes me about 30 min for a complete install, but I have been doing them for a long time on probably over 100 cars.
Most of mine I purchased from rallylights.
Old 10-10-2011, 10:43 PM   #674
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
WTF is the hype about these horns? I have only seen them on subarus and I seems like almost everyone has them. I had never even heard of them until I bought my wrx. Just curious if there is a reason why its so common in the Subaru crowd.... They are loud though lol
mrjcotten is offline   Reply With Quote
Old 10-10-2011, 11:44 PM   #675
dibblejr
Member#: 94070
05 LGT
Loud, affordable, looks and fairly painless to install.
Loud being the main reason. Will help keep you from getting hit or when you want or feel the need to road rage.
How to: Install Alpine HU-Currently Have Sony gtwagon941 Car Audio, Video & Security 13 02-15-2006 01:35 AM
How to: install Megan coilovers? spooledwrx Interior & Exterior Modification 12 01-20-2006 12:14 AM
How to: Install a new clutch no_rex_yet Off-Topic 11 11-12-2004 02:45 PM
How To: Install WRX Turbo/IC on a 2.2L Pepo Normally Aspirated with bolt-on Forced Induction Powertrain 12 10-08-2004 11:18 AM
how to: install rear trailing arm bushings Scott F. Williams Brakes, Steering & Suspension 4 11-06-2002 11:37 AM
