Welcome to the North American Subaru Impreza Owners Club Thursday February 22, 2018
Old 06-02-2010, 08:54 AM   #1
garinhash
Member#: 149670
2002 impreza wrx
blue
Default 02 impreza headlight wiring issue
I receved some headlights recently, but the wiring was incorrect.
I wired the headlights to the D shape plug to what I had found when I searched around, I thought i had wired them correctly but I had issues with the lights after.
the driver's side would not light up at all.
and the high beam/low beams were reversed (low beams were lit when highs was turned on, when high beams were switched off the high beam lights would be on).
so I checked the wires and their colors.
passenger side:
yellow/red (I wired high beam to)
blue/white (common)
red (I wired low beam to)
driver side (did not light up at all):
red/blue (common)
is the wiring on my car screwed up??? i dont have any issue with my standard bugeye lighting (plugged right into the bulb itself).
garinhash is offline   Reply With Quote
Old 06-02-2010, 08:58 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What lights are they? If they're the cheap "projectors" sold on Ebay I wouldn't even bother with them, not only is the wiring wrong but the lighting is horrible.
Old 06-02-2010, 09:53 AM   #3
garinhash
Member#: 149670
2002 impreza wrx
blue
they are some cheap lights that used to be on ebay.
I also have some morette's that I havent used yet either for the same issue, was using these cheap lights to try to figure out the wiring so i wouldnt ruin the morette.
I also could never figure out how to propely wire the morette's because I am not sure what wires were supposed to go to the battery + and - terminals and the high/low/common pins.
since I am having issues with the general wiring I didnt want to go into the morette wiring yet.
Old 06-02-2010, 01:22 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Your common wires are correct and they supply fused power to the lights. As you noted, the red wire needs to go to both high beams and the yel/red wire needs to go to both low beams. If one side of the lights still doesn't work then you most likely have a bad fuse for that side of the lights or a bad connection to the common power lead for the lights on that side.
Old 06-02-2010, 01:49 PM   #5
garinhash
Member#: 149670
2002 impreza wrx
blue
hmm, ill have to recheck it after work when it gets light out (graveyard shift)
update:
ok, it seems this wiring I did was correct, when I plugged in the drivers side the 3 pins of the plug did not go in(cheap lights and cheap plugs I guess).
I'll wire my morettes this way, now I need to figure out what pair of wires go across the car to connect the lights together, and what pair go to the battery.
when I bought the morettes they were shipped separately, and instead of disconnecting the wires that went across the car to the other light they cut the wires, and cut the wires that went to the battery.
the difficult part is that the 2 sets of wires both have brown wires and both have red wires.
stock 03 Subaru WRX Impreza headlight Wires AbioticSoul Electrical & Lighting 4 05-12-2010 01:20 PM
WTB: 2003 Subaru WRX Impreza Headlight Wires AbioticSoul Private 'Wanted' Classifieds 1 05-10-2010 02:45 PM
02 headlight wiring converted to 05 wiring? WickedRS Electrical & Lighting 10 05-03-2008 02:16 PM
WTB 02-03 headlight wire harness ScoobyRacing03 Private 'Wanted' Classifieds 0 04-30-2006 05:23 AM
Wiring issues 02 usdm wrx into 95L..help! Aspen_2.5RS Subaru Conversions 2 11-10-2003 01:32 AM
