11-06-2012, 02:26 PM | #1476 |
Member#: 33458
Vehicle:Your BOV sounds lame 93 RX7+09 Forester |
Are any of you guys running the Weldon pump controller? How do you like it? I picked one up when I saw it BNIB for about half price. I wanted to for my Magnafuel 4303 in order to keep the flow down while cruising.
11-06-2012, 04:47 PM | #1477 |
Member#: 180514
Vehicle:2004 Sti WRB |
What do people think about Ixizconcept fuel rail design ?
It has 3 ports and one of the can be used to link both rails together ? And the return line is in the middle of rails. Are there any benefits to run it like in the diagram below ? |
11-07-2012, 11:37 AM | #1478 |
Member#: 170439
Vehicle:I <3 Lamp |
Best bet for those would be having the return in the center and feeds on both ends.
11-11-2012, 02:23 PM | #1479 |
Member#: 180514
11-11-2012, 05:22 PM | #1480 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
How would you ensure that there are no air bubbles in the system?
Four feeds and two returns actually sounds advantageous in that respect. |
11-11-2012, 06:14 PM | #1481 |
Member#: 295846
Vehicle:WRX FP HTA GT3076R Sexual Chocolate |
Not a good design imo, seems like a bottleneck having the return setup like that.
Look at how every fuel rail from, I4 to v8 is. Fuel in one end fuel out the other. Series rail setups are the best way to insure you have the least amount vapor pockets. I have run them both ways, series seems to have less issues especially when going to fill up and disturbing the vacuum created, and then having a problem starting the car. |
11-13-2012, 04:11 AM | #1482 |
Member#: 132978
Vehicle:2004 Mike angel tund efr 7670 1.05 Twiscroll |
just wanted to throw this out there. i installed a in tank bosch 044 to feed my surge tank and i used jbweld steel and regular on e85 and that stuff just melts away. i was trying to seal up the wiring to the bosch 044 in tank so my cabin wouldnt smell like gas and wasted a bunch of time testing both jbwelds, i dont know about regular gas but e85 for sure melts that stuff right off.
my solution was using atl wiring bulkhead from summit, part was like 21 dollars and it sealed my 12 guage wiring nice and tight. |
11-13-2012, 01:39 PM | #1483 |
Member#: 179846
NWIC
Vehicle:07 STi Limited EFR 8474 TS EWG |
With this surge tank and pump will stock lines be fine? DB300 in tank! im running out of ID1000 at 26 psi on pump gas Last edited by Bariga; 11-13-2012 at 01:58 PM. |
11-13-2012, 02:29 PM | #1484 | |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
11-13-2012, 02:32 PM | #1485 |
Member#: 32669
SCIC
I'm not sure where you see 4 feeds but I see two feeds and two returns just like a normal parallel setup and a cross connect to balance pressure between the rails
11-13-2012, 07:49 PM | #1486 |
Member#: 132978
Bosch 044 intank feeding 2L surge tank feeding 2x Bosch 044 pumps feeding id2000. All 3 Bosch pumps are hard wired to a relay to battery.
11-13-2012, 09:59 PM | #1487 |
Member#: 156877
Vehicle:04 sti |
Wow that's alot of pump! What turbo you running?
11-13-2012, 10:21 PM | #1488 | |
Member#: 195711
Vehicle:PART OUT. PM ME 02-07 Goodies |
11-13-2012, 11:23 PM | #1489 |
Member#: 179846
NWIC
11-13-2012, 11:56 PM | #1490 |
Member#: 108051
AKIC
Vehicle:2005 WRX STi WRB |
Nobody's gonna know as I'm sure that's the only surge tank we've seen designed like that.
Personally I never liked surge tanks, If you think about it your 044 can easily pull more fuel then the intank pump can supply. Is that the Jay's racing 044? IIRC they flow a heck of a lot more then the normal bosch 044 Oh and did you notice you mounted this in a crush zone? very dangerous! Last edited by spoolinsti05; 11-14-2012 at 12:06 AM. |
11-14-2012, 06:16 AM | #1491 |
Member#: 195711
What pump do you have in the surge tank Bariga? ( Way I read it the 300 is in main fuel tank) What size line coming from the surge tank to fuel rails?
The 044 Can pull more fuel, but it also will return the unused fuel from the rails. Typically a surge tank isn't operating at any pressure, so the lift pump doesn't have to work that hard, somewhere north of 275 lph at 0psi, at 12volts for a W255. I don't think you'll have to worry about it with your build Bariga. Some time attack cars where they're on the gas hard would need a bigger lift pump, but I think the serious cars run straight up fuel cells anyways. the 300 you have in tank would be more than enough. My fuel system, as mentioned above made 631 with 1 W255 lifter and 2 044s at bottom Y'd together. |
11-14-2012, 07:17 AM | #1492 |
Member#: 112759
Vehicle:2015 Stock OEM AsFu* 3.6r OMG S.C'd |
11-14-2012, 11:32 AM | #1493 | |
Member#: 179846
NWIC
11-14-2012, 01:04 PM | #1494 | ||
Member#: 180514
He suggested to have feed on both ends of the rails. Two end ports in each rail makes four ports for feeding. That means splitting the feed line to 4. Maybe i misunderstood what he meant. |
11-14-2012, 01:53 PM | #1495 | |
Member#: 179846
NWIC
12-02-2012, 12:26 PM | #1496 |
Member#: 199536
Vehicle:2018 WRX Silver |
my first idea for my new fuel system, my plan as of now consists of the 300SX FMW Turbo on Full Race Twin Scroll Kit, i am new to the fuel system side, is this overkill or just right? thanks brad |
12-02-2012, 02:25 PM | #1497 |
Member#: 76785
Vehicle:2000 700Whp The RSTI SRP |
About right. You probably only need a -8 feed line if your going with a -6 return
12-02-2012, 02:31 PM | #1498 |
Member#: 199536
12-02-2012, 02:49 PM | #1499 |
Member#: 76785
12-05-2012, 10:54 AM | #1500 |
Member#: 59837
SWIC
Vehicle:2004 Spec-C Type RA What MAF? -Speed Density! |
Alright fuel gurus, take a look at my electrical design for retaining stock PWM pump operation and direct battery connection, I don't want my pump screaming at 100% all the time so this is my solution. Thanks to rocketperson7 for electrical assistance.
Need APS fuel system and tumbler deletes to use APS fuel rails? | GoRacerXGo | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 06-17-2005 02:07 AM |
Difference between fuel SYSTEM cleaner and fuel INJECTOR cleaner? | burnout555 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 12-17-2003 11:52 AM |
Maximum HP on stock RS fuel system with walbro fuel pump | Chav | Normally Aspirated with bolt-on Forced Induction Powertrain | 11 | 06-17-2002 03:42 PM |
fuel system managment system | jeffsnyder | Normally Aspirated Powertrain | 2 | 09-23-2001 01:13 PM |
Fuel Injectors / Fuel system | JC SPORTS | Technical Forum Archive | 75 | 07-14-2000 08:51 PM |
