Brakes & Suspension Forum sponsored by The Tire Rack |
11-19-2001, 07:45 PM | #1 |
Member#: 4766
Vehicle:2001 2.5 RS BRP |
17x7.5 42 offset...good or bad
I know offsets should be around 48 or so, is 42 too low? Most likely there will be rubbing right?
Thanks Kurt
11-19-2001, 07:59 PM | #2 |
Member#: 8678
Vehicle:1999 Silverish 2.5GT |
if your car is lowered, then yeah it will probably rub. but, either way, it's going to look fugly with the tires sticking outside the fender.
11-19-2001, 08:30 PM | #3 |
Member#: 1911
Vehicle:2000 Impreza 2.5RS Silverthorn Metallic |
Rubbing and extra stress on the bearings.
11-20-2001, 01:03 AM | #4 |
Guest
Member#:
i could be wrong, not totally sure, but isnt that the distance from the mounting surface to the outside of the wheel.. and if it is, the wheels would be further inside the wheel well than a 48mm offset..
11-20-2001, 01:11 AM | #5 |
Member#: 1911
To quote my hero Jack Black, you can be and are wrong.
Offset is the distance from the center plane of the wheel (which is equidistant from both edges of the wheel) to the mounting face. Positive offset means the mounting face is towards the "outside" of the center plane, and negative offset means it is towards the "inside" of the center plane. Ben |
11-20-2001, 01:12 AM | #6 |
Member#: 6971
NWIC
Vehicle:2008 WRX STi SSM |
11-20-2001, 01:17 AM | #7 |
Guest
Member#:
42mm would still be further inside the well than a 48mm
11-20-2001, 01:30 AM | #8 |
Member#: 1911
A +42mm offset means the mounting face is 6mm CLOSER to the center plane than a +48mm offset wheel, which pushes the wheel 6mm OUT from the car (assuming the same width), meaning it is NOT further into the wheel well.
Ben |
11-20-2001, 01:24 PM | #9 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Yeah, what he said!
11-20-2001, 01:27 PM | #10 |
Member#: 10433
Vehicle:1942 Kettenkrad WR Blue Pearl |
acceptable Subaru offsets:
53mm for 7" wide wheels 48mm for 7.5" wide wheels 45mm for 8" wide wheels |
FS: Advan RG2 18x8.5 45 offset & Rays RS-Zero 17x7.5 48 offset | exige | Wheels/Tires | 10 | 07-14-2010 09:05 PM |
Work Emotion XD9: 17x7.5, +42 offset, 5x114.3 bolt pattern | KA-T_240 | Wheels/Tires | 8 | 01-16-2010 06:24 PM |
13.5 gallon= 25mpg good or bad? | awdguy | General Community | 28 | 07-06-2007 11:26 PM |
HR: Rota Formel 17x7.5 42 offset (gunmetal) | elmer20 | MAIC Private Classifieds | 4 | 08-25-2006 03:19 PM |
42 offset, KONIG toxin's....good or bad?? | SuBaRu-ImPrEzA_RS | Brakes, Steering & Suspension | 13 | 05-20-2001 02:17 PM |
