12-27-2012, 08:59 AM | #1 |
Member#: 340910
Vehicle:07 WRX LTD Urban Grey Metallic |
FPHTA68 & DW750cc map, anyone?
Well, I just purchased a vehicle with a tune that makes me a little uncomfortable. It's running 20 pounds of boost in every gear, at a 10.0 WOT AFR on a 2007 wrx sedan, stock motor & trans.
I don't have money for a dyno tune, as I just dropped a ton on purchasing the vehicle several days ago. Any help would be greatly appreciated. It's mod list: HTA68 turbo TurboXS front mount intercooler TurboXS RFL blow off valve TurboXS MBC ACT 6 puck sprung clutch ACT flywheel Walbro 255 lph fuel pump Deatschwerks 750 cc injectors Invidia cat-back Invidia up pipe Invidia catted down pipe Eibach lowering springs SPT short ram intake AEM wide band a/f gauge Autometer EGT gauge Autometer boost gauge Cobb Accessport I don't care much about power at this point, I just want it to be safe. Thanks very much in advance.
12-27-2012, 07:50 PM | #2 |
Member#: 133893
Vehicle:2011 BMW 328i Xdrive EJ255 02 Wagon (retired) |
If you are running that rich under WOT, I would have it checked for leaks, the tune might be fine.
Plug in your Accessport, and under the Live Data section, what does A/F Correction A, B, C, and D say? What does the Dynamic Advance Multiplier say? Could you take a log with the Accessport and post it up? I saw another post where you said Ptuning did the tune...did you mean Precision Tuning in Lakewood, NJ or Ptuning in Virginia? |
12-28-2012, 10:40 AM | #3 | |
Member#: 4803
What does the AEM gauge read at idle? In closed loop? I would compare the reading at idle/closed loop to the front o2 sensor (which can be viewed/logged via AccessPORT with the A/F Sens 1 Ratio monitor). As SkateAndDestroy mentioned, you can check your long-term fuel trims (A/F Learning 1 A,B,C,D) if you have had a good amount of driving since reflashing a map, resetting ECU or disconnecting the car's battery. Generally speaking, each of these trims should be within +/- 5% or so. Bill |
01-01-2013, 09:34 PM | #4 |
Member#: 262117
Vehicle:2001 Forester STI MKtuned |
Get some logs and post them up. 10.0 AFR isnt motor ending, but that is a tad rich and can slowly harm motor components over time as unburnt gas ends up washing down cyl walls, which clears away oil and lets metal on metal abrasion occur slowly, scratching the walls . Even some reputable tuners wont go past 10.5 when tuning for a very rich mixture. The optimal range is around 11.1 for most Top mounts , even up to 11.4 with a FMIC because of how much cooler the charge is.
Listen to skatendestroy, he is an expert with tuning these 68HTA's. |
