Welcome to the North American Subaru Impreza Owners Club Thursday May 6, 2021
Old 11-09-2017, 12:56 AM   #1
Shanesajda
Member#: 460045
Default Can boost leak cause cylinder misfire?
I've been getting a code for a cylinder 2 misfire, wondering if boost leak could be a factor. I have thought the car has been sluggish. Now it's sputtering at around 3500rpm/16psi (hence the misfire)
It's an 05 saab 92x, with Blouch 16g turbo upgrade, STI TMIC, 1000cc injectors, fuel pump, exhaust etc. Its a factory auto transmission as well.
The car isn't as fast as I thought itd be. I know turbo lag is real, it just seems more than that to me
Any way to check for boost leak?
Shanesajda is offline   Reply With Quote
Old 11-09-2017, 12:59 AM   #2
Shanesajda
Member#: 460045
Just thought I'd mentioned it's obviously shop tuned as well. And I have a boost control solenoid installed
Old 11-09-2017, 08:15 AM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Step #1 - Go back to your tuner
Step #2 - See Step #1
What? No CEL code?
So many things could cause a misfire.
Old 11-09-2017, 02:47 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
i had a problem like that, the car would stop reving if I went into boost. no cel light or anything.. anways it ended up being the coils 2 of the 4 went bad but it took like a long time to figure it out
subaru_gc8 is online now   Reply With Quote
Old 11-09-2017, 05:40 PM   #5
Shanesajda
Member#: 460045
Yea I'm getting a cel, it comes and goes. I'm gonna check the coils and plugs
Old 11-10-2017, 01:05 PM   #6
Shanesajda
Member#: 460045
My gas mileage dropped quite a bit too. I was at 22 a couple tanks ago, now averaging 17.6. Mostly highway
Old 11-10-2017, 05:53 PM   #7
Shanesajda
Member#: 460045
Just found a huge fuel leak
Old 11-11-2017, 02:39 PM   #8
Shanesajda
Member#: 460045
Pouring out of the injectors on both sides. Bad O Rings??
Old 11-14-2017, 01:25 PM   #9
foresterstb2001
Member#: 477704
I'm having a similar problem with my stb and thinking it might be an air leak... such a pain trying to trouble shoot. Best of luck!
foresterstb2001 is offline   Reply With Quote
Old 01-23-2021, 09:44 PM   #10
JayTV1027
Member#: 503227
2009 Impreza WRX
Sterling Silver
Not to bring this back from the dead but what was the solution to your problem?
JayTV1027 is online now   Reply With Quote
