12-15-2008, 03:17 PM | #1 |
Member#: 83633
RMIC
Vehicle:2012 bright green box |
how to tell if turbo is going bad?
As of yesterday my turbo (stock) is making a wierd noise.
I think it's the turbo, because the sound only happens when I am in boost (usually takes 4-5psi before the sound starts). It's hard to explain, but it sounds like normal engine sounds just become louder and more high pitched. (like I'm going into warp speed) Everything still seems to run normal, and I still see full boost according to my gauge. So I guess my question is how do I know if my turbo is going bad? could it be anything else?
12-15-2008, 03:18 PM | #2 |
Member#: 113012
Vehicle:'04 XT red LIFTED '15 XV CROSSTREK LIFTED |
did you install a downpipe yesterday??
12-15-2008, 03:20 PM | #3 |
Member#: 83633
RMIC
nope, I did nothing but drive to and from my parents house for dinner.
12-15-2008, 03:22 PM | #4 |
Member#: 113012
if its still running the same it did before then you should be fine..if your turbo went you would know it..as for the sounds..maybe a leak but you said the car still hits boost at the same rpm so who knows
12-15-2008, 04:04 PM | #5 |
Member#: 83633
RMIC
So if not the turbo, what else could it be?
Maybe me bpv is busted and is opening at 4psi? but boost seems good and car still pulls like normal. |
12-15-2008, 09:07 PM | #6 |
Member#: 47646
RMIC
Vehicle:0511 RallyBaja DGM Sedan |
If its loud and screaming then its somewhere in the exhaust half.
Do you build boost the same way? What mods do you have? An gasket may have let go... |
12-16-2008, 11:49 AM | #7 |
Member#: 83633
RMIC
Up pipe, down pipe, exhaust, stage 2. (Been running this for years.)
Boost seems to build and hold like normal. there is no abnormal noise at any rpm as long as I stay out of boost, but once boost hits so does the noise. |
12-16-2008, 12:00 PM | #8 |
Member#: 183480
South East
hmm...
I would check all around the downpipe where it meets the turbo. The exhaust leak there, if its a small one on the wastegate side, will not be very noticeable in your gauges, but it is definitely audible. If you take off the heat shield, start your car, and have a friend rev the engine a little bit, you should be able to hear the exhaust coming out of there. OR....you can take some soapy water or kids bubbles stuff and brush it real thick over the part where the turbo and downpipe meet...if it blows bubbles it has a leak. Mine sounded kinda like that when I was leaking out of the wastegate side of the turbo to downpipe gasket. Just a guess and easy thing to check...
12-16-2008, 01:11 PM | #9 |
Member#: 83633
RMIC
I will check the turbo to down pipe gasket tonight.
12-17-2008, 09:18 AM | #10 |
Member#: 83633
RMIC
There was a small leak in the turbo > downpipe. I ordered a new Grimmspeed gasket, let's hope it's that easy.
Thanks for your help. |
12-18-2008, 04:28 PM | #11 |
Member#: 183480
South East
well...
awesome if it is that easy...and...if not, a decent used TD04 is really cheap on here, and not too bad to install. I would say that for a used TD04 in good shape plus the gaskets wouldn't be more than $125 shipped so...not too bad either way.
12-29-2008, 09:59 AM | #12 |
Member#: 83633
RMIC
I installed the turbo - downpipe gasket, but the sound still persists, so I decided to run a little sea foam through and look for smoke.
It appears I have a leak down low on the passenger side. I'm thinking either header - downpipe, or block - header, so I am just going to replace all the exhaust gaskets. I just find it realy strange that boost seems normal. Thanks for your help. |
12-29-2008, 10:05 AM | #13 |
Member#: 177101
Vehicle:04 Hoopty |
Very helpful post as i`m having the very same problem....
12-29-2008, 10:36 AM | #14 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
Probably the header/uppipe gasket, that thing is a PITA. A leak there would have to be HUGE to cause boost problems. I had a massive leak there once (3-bolt header/uppipe, one of the bolts fell out), it was silent when I was in vacuum, sounded like I had an EWG when I was in boost, yet it still hit and held boost like normal.
12-29-2008, 10:43 AM | #15 |
Member#: 114609
Vehicle:2006 Legacy GT |
This is what my car sounded like when it had an up-pipe leak where it meets the turbo:
http://homepage.mac.com/sgallagan/ot/scream.mov |
12-29-2008, 10:55 AM | #16 | |
Member#: 83633
RMIC
12-29-2008, 03:27 PM | #17 |
Member#: 177101
Vehicle:04 Hoopty |
Bingo.......same problem here(as stated b4)...efing car sounds like it have a s/c intead of a turbo
12-29-2008, 04:56 PM | #18 |
Member#: 134272
HIIC
Vehicle:2007 Sti, UGM Rotated EFR 6758 |
Considering that it has been WTFCOLD there lately I would guess its one of your pre-turbo exhaust gaskets, OR the headers themselves cracking. Since you are not running aftermarket headers the latter seems less probable so I would guess gaskets
01-05-2009, 08:22 AM | #19 |
Member#: 83633
RMIC
It's not the uppipe gaskets. Changed those out yesterday.
Moving on to the exhaust manifold/crosspipe gaskets next week. One of these SOB's is going to fix the problem. Last edited by justincredible; 01-09-2009 at 02:08 PM. |
01-05-2009, 08:40 PM | #20 |
Member#: 163445
Vehicle:l33t ******* [email protected] |
Does smoking count as possibly going bad? Like literally smoke coming from the hot side casting? Egt's are wonderful... Don't think the td04 is doing so hot, or maybe its too hot...
Jerod Seriously though this just happened on my way to pick up the wife, never once came out of vacuum |
01-09-2009, 11:59 PM | #21 |
Member#: 115154
Vehicle:2005 Outback XT White on grey |
blargh, I got an exhaust leak on the manifold-UP gasket too (blew through the remflex gasket, apparently it's a relatively common problem).
I got the Grimmspeed double thickness gasket to go in there. Anyone got any tips on how to replace the gasket? Do I have to take out the o2 sensor that's in the manifold? |
01-10-2009, 10:33 AM | #22 |
Member#: 45076
Vehicle:2004 Stg 2 wagon AT 16 BRZ. Both silver |
Yes the O2 sensor needs to come out. You can get the tool at Autozone. Unless you have small hands and can get the two bolts out with the sensor there. I could not. Good luck.
01-10-2009, 03:24 PM | #23 |
Member#: 115154
Which bolts did you have to loosen? the UP-manifold, mani-crossover, head-manifold? I hope I don't have to loosen all of those things; I may end up just getting more exhaust leaks
01-12-2009, 04:10 PM | #24 |
Member#: 83633
RMIC
Still no fix.
I'm going to stab someone in the eye with a fork. also, when I did the lower up-pipe gasket I just removed the heat shield, used a flex head ratchet with deep socket (can't remember if I used an extension or not) to remove the 2 bolts, slipped the old gasket out, slipped the new one in, bolted back up, replace heat shield. |
01-13-2009, 09:43 AM | #25 | |
Member#: 160434
Vehicle:2007 WRX Limited CGM |
Similar Threads | ||||
how to tell if o2 is bad?? | hulkSTi | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 11-12-2006 10:15 AM |
How to tell if diff is going? | yelWRXlow1 | Transmission (AT/MT) & Driveline | 2 | 05-08-2006 06:16 PM |
How to tell if strut is bad | engr | Brakes, Steering & Suspension | 7 | 06-20-2005 10:18 PM |
how to tell if turbo is bad? | Costanza | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 04-24-2003 08:56 PM |
how to tell if amp is toast? | Kaffiene | Car Audio, Video & Security | 8 | 09-22-2000 06:49 PM |
