Welcome to the North American Subaru Impreza Owners Club Sunday September 23, 2018
Old 01-13-2002, 03:55 AM   #1
okamikatekore
Member#: 12536
1999 forester GT
2.0 Turbo, green
Default 4.111 final drive ratio change to 4.4????
i have a 99 forester gt (turbo)with 215/60-16 tires.if i put a lower profile tire(215/55-16) on,this will change my final drive ratio from 4.111 to 4.250.if i put a 50 series tire the ratio will go from 4.111 to 4.4.the 99 spec wrx had a ratio of 3.9,while the 99 spec sti had a 4.444 ratio.what effect will a taller ratio have?eg)will it rev harder at the same speed compared to the original etc.......
reasons for lower profile include:
ultra high performance tires are available in 55 series and lower
performance
aesthetics
oh yeah.....im aware of the issues involved with speedo accuracy(easy fix)
okamikatekore is offline   Reply With Quote
Old 01-13-2002, 11:01 AM   #2
Si2WRX
Member#: 13173
309 hp on 93 + W/I
on Dyno Dynamics
It'd be interesting to see if the car pulls harder set up like that.
But the thing I would be most concerned about myself...your mileage will tick by faster than actual.
Erik
'02 WRX semi-stock ~240hp
'94 Grand Cherokee 5.2 QuadraTrac modified ~275hp
Si2WRX is offline   Reply With Quote
Old 01-13-2002, 11:56 AM   #3
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
Changing the gear ratio like this will trade top speed for acceleration. By all accounts an RS upgraded from 4.11 to 4.44 accelerated significantly faster.
Why do I have the strange feeling I already answere this question in the transmission forum where it ought to have been anyway.
-Michael
d00f is offline   Reply With Quote
Old 01-13-2002, 12:30 PM   #4
Austin
Member#: 7089
2016 STi
With smaller tires you'll be at a higher rpm than before at the same speed in the same gear.
Austin is offline   Reply With Quote
Old 01-14-2002, 02:51 AM   #5
okamikatekore
Member#: 12536
1999 forester GT
2.0 Turbo, green
Default oops......
doof.......sorry about that but i wasnt getting many views in the transmission forum.
si2WRX........if i do go ahead with this, MRT sell 'thingy' that you can recalibrate your speedo for larger/smaller wheels
this could be worth a try.only thing is ill have to getthose 18" superleggras now.otherwise my car will look like an impala with rollerskate wheels
Old 01-14-2002, 02:37 PM   #6
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Default Re: 4.111 final drive ratio change to 4.4????
performance
aesthetics
How do you calculate final drive ratio and corresponding changes made by adjusting tire profile? I'd really like to know this...and since my speedo was 5 mph fast from the factory, speedo accuracy doesn't matter to me. Right now with my 17" UK rims w/45 profile, my speedo is only 2.5 mph fast...
annointed is offline   Reply With Quote
Old 01-15-2002, 06:55 AM   #7
okamikatekore
Member#: 12536
1999 forester GT
2.0 Turbo, green
annointed.......this is the easy wayhttp://www.tolan-hoechst.com/cars/tirecalc.htm quick and easy
Old 01-15-2002, 09:49 AM   #8
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Do you have a link to the MRT 'thingy' that recalibrates speedos? That would be alot better than paying a speedo shop (maybe!).
Conduit is offline   Reply With Quote
Old 01-15-2002, 07:48 PM   #9
Austin
Member#: 7089
2016 STi
Conduit - do *you* have a link to the mrt thingy? Any more info on it?
Old 01-20-2002, 01:46 AM   #10
okamikatekore
Member#: 12536
1999 forester GT
2.0 Turbo, green
Default here we go..........
here is the info on the speedo recalibrator:
ADJUSTABLE SPEED LIMITER and speedo signal calibrator.
Designed to be fully "programmable" the electronic part simply converts the speedo drive digital signal to a setting that is "user definable".
Able to redefine the speed cut to a user chosen limit
Able to re calibrate the signal to suit larger or smaller dia wheels. (Great for new big dia wheels!)
The part is available with a program disc (DOS based) to allow owners to set two functions:
Speed limit
Speed ratio.
you will have to email MRT for prices
Old 01-20-2002, 01:53 AM   #11
okamikatekore
Member#: 12536
1999 forester GT
2.0 Turbo, green
Speed limit
Speed ratio.
Old 01-20-2002, 02:00 AM   #12
Austin
Member#: 7089
2016 STi
Thanks! I'll email them tomorrow.
final drive ratio change. subyboy Transmission (AT/MT) & Driveline 12 10-07-2009 03:21 PM
is there a 4.37 final drive ratio front diff? greg donovan Transmission (AT/MT) & Driveline 1 08-18-2004 12:36 AM
RalliSpec 4.44 Final Drive Ratio Gear Set eness76 Transmission (AT/MT) & Driveline 2 09-18-2003 03:28 PM
converting from 3.9 to 4.444 final drive ratio DoinkMobb Transmission (AT/MT) & Driveline 11 03-13-2003 05:24 PM
How to change final drive ratio? subliminal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-29-2002 03:00 PM
