05-28-2012, 10:48 AM | #26 |
Member#: 276443
TXIC
Vehicle:2005 2.1 stroker WRX OBP |
Been done guy. Thnx tho. Ive done all these other ideas
05-28-2012, 11:19 AM | #27 |
Member#: 123625
Vehicle:2015 WRX Galaxy Blue |
When I cleaned my iacv the old way before my writeup it didn't work even after doing it twice.
07-03-2012, 10:08 PM | #28 |
Member#: 131280
BAIC
Vehicle:2004 Impreza WRX WRB |
Mine goes to 1k sometimes slightly over at around 1200 at most. It is definitely reflected on during hot days only. Cold days, no worries.
09-03-2012, 01:56 AM | #29 |
Member#: 318903
Vehicle:02 WRX White |
this worked on my stock 04 and my tuned 02
04-25-2013, 10:12 PM | #30 |
Member#: 136106
bumping an old thread.
Fixes for this issue? I have had my CC cable disconnected for some time but would like to actually fix this issue, I cut up a sheet metal heat shield for the CC unit itself as an extra shield from turbo heat but this did not resolve. Anyone have any decent fixes for this aside from pulling the cable off. In my case at least you cant loosen the cable enough to fix it on a warm day. Only started when I went stage 2 with a tbe, its heat wrapped and I have the factory heat shield although modded to fit the larger dp.) |
04-25-2013, 11:28 PM | #31 |
Member#: 342331
Vehicle:2003 wrx blue |
my 2003 has been doing this ...i thought it was programed into the Cobb 2 reflash.....but come to think of it i removed the heat shield just before the reflash. mine only does this when in stop and go traffic .going to adj the cable .thanks guys .
05-02-2013, 08:53 PM | #32 |
Member#: 342331
made the cruise control adj ....and what do you know while in traffic the idle stay normal the whole time ...thanks for the tips guys.
06-04-2013, 10:05 PM | #33 |
Member#: 285961
Alright, Iv'e totally removed my cruise control. I loosened my throttle cable. I cleaned the IACV and replaced the gasket. My car still idles at 4.5k RPM in hot weather only. Right as it cools off at night, I have no idle issues. any help?
06-09-2013, 06:38 PM | #34 |
Member#: 339966
I had the same issue today, I adjusted both cables last winter and its been fine since. Today I was idling for a long time and it started idling very high 3.5k max. I then noticed my coolant temp gauge in dash was much lower than it usually is at operating temp. Seems odd, I am going to have to assume its a coolant temp sensor issue giving false readings causing the issue..? Anyone have any experience with this?
06-09-2013, 06:52 PM | #35 |
Member#: 276443
TXIC
Mine does all the same things. Hot days only
06-11-2013, 06:06 PM | #36 |
Member#: 129385
As everyone stated the cruise cable expands from the heat and for some reason makes idle go up. Just detach the cruise cable and you will be good. Dealer clip recall didn't work for me or my friend. We both detached the cruise cable and never had this problem again.
06-14-2013, 11:20 PM | #37 | |
Member#: 350257
Vehicle:2005 9-2x Aero Artic Silver |
My issue was in an '05 Saabaru 9-2x. I have been experiencing the same hot weather idle climb. Eventually, I got back to my garage while it was still happening and check the CC cable; sure enough, it was tighter than it ought to be. Grabbing a 12mm wrench and loosening the cable solved it instantly. |
06-15-2013, 12:30 AM | #38 |
Member#: 342331
just loosen the cruise cable(put some slack in it) ...no need to disconnect it ,mine is still working well no more high idle
06-15-2013, 07:03 AM | #39 | |
Member#: 339966
06-15-2013, 12:18 PM | #40 |
Member#: 350257
Just make sure you're loosening the cable, and not tightening it. Seems obvious, I know, but you want to bring both nuts closer to the front of the vehicle. Moving them toward the firewall tightens it.
07-16-2013, 09:13 AM | #41 |
Member#: 359062
I have a impreza rs non turbo and mine does the same exact thing, i know you guys were saying that this happens from the turbo getting hot, could this happen to mine even though i don't have the turbo?
07-24-2013, 09:07 AM | #42 |
Member#: 291158
South East
Vehicle:2005 wrx wrb |
when its hot, mine gets really high. i drove last nite, no problem. hot days, problem.
06-28-2015, 09:47 PM | #43 |
Member#: 417035
in my 04 wrx after sitting at idle for a bit my rpms raise to over 2 and takes awhile after driving for to return to normal but now I'll go and it stays around 4 for a sec or so then only lowers to about 2 not sure what causing it any suggestions
06-29-2015, 08:38 PM | #44 | |
Member#: 279525
Vehicle:06 Fxt |
Its the cruise control cable. Search. Its a known issue when the summer hits and car gets overly hot. Just loosen the nut on the cruise control cable. Simple fix. |
07-24-2015, 07:29 PM | #45 |
Member#: 417035
awesome did exactly that completely fixed the issue
07-27-2015, 06:38 PM | #46 |
Member#: 426755
How do you adjust the throttle and cruise control cable?
07-28-2015, 07:43 PM | #47 |
Member#: 279525
Vehicle:06 Fxt |
2004 WRX hanging/high idle issue
You just adjust the cruise cable not throttle cable.
There is a nut where the rubber portion of the lines begin, smack dab in the middle top portion of intake manifold. Just loosen the back nut on the cruise cable all the way so that there will be more slack on the line. |
12-05-2017, 04:54 PM | #48 |
Member#: 475644
Cruise Cable
Disconnect the cruise cable completely from the throttle body, when its idling high like that especially when the turbo is hot, the cruise cable sticks and holds the throttle open, you can confirm this by duplicating the high reving, when it does push the throttle closed by hand.
Similar Threads | ||||
FS : 2004 WRX Helix High Flow Cat Downpipe | brynboy | SCIC Private Classifieds | 6 | 12-06-2010 05:39 PM |
FS : VA 2004 WRX STI Highly Modded $21k OBO | billy720 | Private Vehicle 'For Sale' Classifieds | 1 | 11-11-2010 11:16 PM |
another high idle issue, with lights dimming | R-raid | Service & Maintenance | 14 | 08-23-2010 10:46 PM |
high idle ISSUES!! | majunche66 | Built Motor Discussion | 6 | 03-14-2009 07:44 AM |
People with cold startup high idle issues | 98EJ20 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 01-22-2008 06:47 PM |
