Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Old 10-07-2018, 10:24 AM   #51
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Originally Posted by can250 View Post
Got my tuned a couple of weeks ago 415 kw atw on e85
Awesome! How much boost you running? My target was around the 420 mark
CEEBEE is offline   Reply With Quote
Old 10-08-2018, 06:22 AM   #52
can250
Member#: 452601
Not exactly sure as I work away as well and they had problems on the dyno
can250 is offline   Reply With Quote
Old 10-31-2018, 09:35 PM   #53
rocklizzard91
Member#: 226287
How well does your core keep up with air temps? I am really on the fence for an AWIC setup but I am afraid of how the system works both on the street (traffic) or on the track (not shedding heat through the exchanger fast enough)
what are typical IATs?
rocklizzard91 is offline   Reply With Quote
Old 11-06-2018, 04:24 AM   #54
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Today with heavy stop start traffic and ambient of 36 degrees centigrade (97F) plus 65% humidity it was around 38 deg c max. Usually around 40 deg c mark but results vary from kit to kit.
Old 11-07-2018, 02:44 AM   #55
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Originally Posted by CEEBEE View Post
Today with heavy stop start traffic and ambient of 36 degrees centigrade (97F) plus 65% humidity it was around 56 deg c max. Usually around 40 deg c mark but results vary from kit to kit.
Edit! Found an issue with the pump connection today. Repaired connection intake temps now 38deg c after multiple wot pulls
Old 11-07-2018, 05:12 AM   #56
can250
Member#: 452601
Are you fully tuned now
Old 11-07-2018, 08:35 AM   #57
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Having back pressure issue so waiting to get a 3.5” dump pipe fabbed up. Been back on the dyno making 375kw and 595nm @25psi. Just driving it for a few weeks then back in for dump but won’t be finished till new year. All good very quick as it is
Old 11-09-2018, 01:16 AM   #58
bp05obxt
Member#: 459799
What turbine housing are you running? Seems to me it would make more sense to go to a larger turbine housing to aid flow then fabricating a new exhaust. A 3 inch exhaust shouldn’t be restricting you at that power level. I would be curious on your manifold and pre-turbo exhaust is like as well as your heads specs..
bp05obxt is offline   Reply With Quote
Old 11-09-2018, 03:15 AM   #59
can250
Member#: 452601
If he is running a t3 they only come in one size
Old 11-13-2018, 03:40 AM   #60
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
.85 rear housing. Only other size is a 1.03. Head specs are ported heads, 1mm os valves, custom billet cams 240 deg duration 10.8mm lift. Headersand up pipe are Roger Clarke Motorsport.
Old 11-13-2018, 11:13 PM   #61
bp05obxt
Member#: 459799
I can see the 1.03 becoming beneficial as your power increases, but not sure that it is really necessary. How are your measuring this pressure issue? Or is is speculative that back pressure is the issue? The cams are interesting; have you you dialed them to compare to an off the shelf cam option?
Old 11-14-2018, 09:41 AM   #62
Dotica
Member#: 493937
Talking 2007 2.5i wagon STI swap?
I love my wagon, but I don't love it's lack of power. I got around 12k to throw at my 2007 Subaru Impreza 2.5i wagon to make it a quick little bugger. I'm planning on using 1k for rims and tires (285's), 1k for bucket seats and steering wheel/ steering wheel accessories (I will be using primarily NRG branded stuff here), 1k for new paint, 1k for coilovers. That leaves 8k for an STI engine and a manual transmission. I can get an STI engine for about 4k with 50k miles (I will probably rebuild it anyways to replace gaskets) and that leaves me with 4k for a transmission and clutch pedal. Any ideas on what a shop would charge me for this process?
Dotica is offline   Reply With Quote
Old 11-14-2018, 10:26 AM   #63
fuelMuncher
Member#: 301554
2002 WRX Wagon
PSM, 2007 OBP WRX Limited
A full STI swap will also need a bunch of other parts. ECU, cluster, axles, hubs, differential, knuckles, rotors, brakes, fuel pump, etc. Sell the Impreza and buy an STI or WRX.
fuelMuncher is offline   Reply With Quote
Old 11-15-2018, 12:38 AM   #64
justacarguy2012
Member#: 424268
nice! have a very similar build on my 2014 STI, made 498whp on E55 (couldn't get a very high blend unfortunately) but still very pleased with it.
justacarguy2012 is offline   Reply With Quote
Old 11-19-2018, 01:51 AM   #65
can250
Member#: 452601
Where do you get the 1.03 size as its not on there web site and when I ordered mine there was only one size
