Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Old 02-04-2015, 06:29 PM   #26
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Originally Posted by 69subaru360 View Post
Step 1- Remove Subaru badge.
Step 2- Walk into Dodge dealer and buy a hellcat.
Step 3- install Subaru badge on hellcat trunk.
You'll spend about the same money trying to get a 700 whp Subaru, but the hellcat has a warranty and won't blow up.
Except RWD, makes it a bitch to control. AWD all day for high powered builds
user1029 is offline   Reply With Quote
Old 02-04-2015, 06:41 PM   #27
Annihilator817
Member#: 296742
'16 STI, '11 WRX,
'96 328i DSP
I was going to suggest that it would likely be cheaper, and more reliable, to just install AWD into his old Mustang.
Annihilator817 is offline   Reply With Quote
Old 02-04-2015, 07:03 PM   #28
wEaK Squad
Member#: 337250
Originally Posted by alfriedesq View Post
ID 1300 on E65 aint going to make any serious power - those injectors are too small
I am making 420 on a mustang dyno on 93 octane and maxed out on ID1000
-8 fuel line and double pumper
Al
i made 503/535 on E85 with 980's
.... 12v mod 485 with stock lines and rails
wEaK Squad is offline   Reply With Quote
Old 02-04-2015, 07:07 PM   #29
wEaK Squad
Member#: 337250
Hella fail
what a joke... there was a hellcat at the ocala 1/2 mile last weekend that was running high 140's low 150's..
doesnt seem worth the price tag imho
i ran 148.8 in my subaru at heavens landing and i only ran 1 time
https://www.youtube.com/watch?v=ncR_lzwXBQY
Old 02-04-2015, 08:04 PM   #30
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
500whp only for all that work? On a 1.06A/R?!?! Switch up to E85, ID2000cc injectors, dual pumper radium surge tank, -8an lines, and run a hearty 35psi through that thing!
Our dyno is the lowest reading of the low reading. 575 whp on our dyno goes 9.7 at 146. I've seen people from a dyno jet not to far from us put down 550 and go 11.7 at 121.
Tony
Old 02-04-2015, 08:18 PM   #31
wEaK Squad
Member#: 337250
Damn trapping 146 is like 750ish dyno jet if im not mistaken
What kind of dyno?
We just got a new dual eddy current awd dynojet
Old 02-04-2015, 08:28 PM   #32
Rogue_P
Member#: 371737
2003 **** Your
Fake Parts
My roommate is selling his 800whp Evo 8. Wayyyyy cheaper than you can build the wrx.
Rogue_P is offline   Reply With Quote
Old 02-04-2015, 09:01 PM   #33
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Everyone has their way and route
Another would be finding my build thread, although the turbo I'm on should be good for well over 700.
A 6466 would pry be the best turbo for a clean 700.
Id set more of a trap goal because you will always have someone come in here and argue that on their dyno 550whp traps 146 around x weight, sounds super unrealistic to me but hay what ever.
Shortpersonbk is offline   Reply With Quote
Old 02-05-2015, 01:23 AM   #34
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Trap speeds are highly dependent on density altitude. 100mph car here could be a 112 mph car at Cecil or Atco.
If the op wants to numberhunt it really doesn't matter what number he hunts for.
ProfessWRX is offline   Reply With Quote
Old 02-05-2015, 01:24 AM   #35
user1029
Member#: 57064
2008 STi IAG built
wai
Old 02-05-2015, 01:47 AM   #36
VladiWrX
Member#: 145658
On my 10th scoob
and lovin it
trolling nabisco 101:
-Start thread in PPB
-Ask about a random dyno number
-Sit back and watch the thread take off.
VladiWrX is offline   Reply With Quote
Old 02-05-2015, 02:08 AM   #37
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Hella fail
All that power and they are both slow as hell.
Old 02-05-2015, 10:05 AM   #38
Shortpersonbk
Member#: 319017
15 Prius
True but it is at least a better way to show actual real world performance.
Old 02-05-2015, 10:24 AM   #39
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
700 WHP what do i need?
you need a much more realistic goal
odds are you wouldn't get much use out of a 700whp car
Old 02-05-2015, 10:25 AM   #40
Uncle Scotty
Member#: 16200
OK buy Nates beans
and this is the REAL answer, here
Old 02-05-2015, 11:34 AM   #41
Turn in Concepts
Member#: 93646
Many Track Records
What kind of dyno?
Dyno Dynamics.
Tony
Old 02-05-2015, 11:48 AM   #42
Delphi
Member#: 239335
2011 WRX
Originally Posted by Turn in Concepts View Post
Dyno Dynamics.
Tony
Oh man are they heart breakers for number seekers.
Airboy in Calagry Alberta has one. STI's with ELH, Downpipes, intakes and what not usually barely crack 270whp. Buddy had a DOM2.5XTR made 370whp and was trapping 119-120 here.
Delphi is online now   Reply With Quote
Old 02-05-2015, 11:53 AM   #43
Turn in Concepts
Member#: 93646
Many Track Records
Typically for us 400 whp will trap 120.
Old 02-06-2015, 12:33 AM   #44
user1029
Member#: 57064
2008 STi IAG built
Stop being stubborn and use a correction factor. Everyone who has dyno'ed there has to explain their short e-peen
Old 02-06-2015, 02:18 AM   #45
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
700 hp on what dyno? On our dyno 700 whp would run somewhere in the 8's. 500 whp is good for low 10's.
We are just finishing up a 500 whp build on a 2005 STI. Here's the list:
TiC Closed deck Honey Badger Short Block
Kurt Brown ported heads
GSC Springs
+1mm Ferrea Valves
Tomei custom cams
GTX3582 with 1.06 hotside
APS FMIC
Custom piping
EJ255 plastic intake manifold
Accessport tuning
ID1300 injectors
E65 fuel
This will be reliable if treated well and maintained properly. Not simple or cheap to build though.
Tony
Al
Tony
Strange
400whp gets you 120s, 575 gets you 146mph? 175whp picks up 26mph? I do a little drag racing and I would say we are not comparing 2 like cars.
What kind of car made 575 and trapped 146mph? I would assume it wasn't a subaru or if it was, its a GC/Light weight with good gearing.
600whp dynojet has netted me low [email protected] but I know its not a good comparison for how the dyno reads. 750s has actually netted me mid 8s at 160mph, but again I know that is not a good indicator of how the dyno reads being that the car is 800lbs lighter then any customers car would be and is geared for going fast. I would be misleading them if I told them at 700whp they would go 8s or 600 would net them low 9s.
As for the id1000s/Id1300s thing.
No way in hell someone is maxing out id1000s with dual pumps at 420whp on 93oct on any dyno. Fuel SUPPLY issue or you are running like 25psi base pressure.
Id1300s will make 600whp DYNOJET with 55psi and 1 rewired 485 ON E85.
Junior2JZ is offline   Reply With Quote
Old 02-06-2015, 04:31 AM   #46
layne5400
Member#: 403044
2011 subaru wrx
pearl white
Dude .. you need a Honda civic with a spoon engine and on top of that a t66 turbo with nos and a motec exhaust
Sent from my SM-G900R7 using NASIOC mobile app
layne5400 is offline   Reply With Quote
Old 02-06-2015, 12:07 PM   #47
Turn in Concepts
Member#: 93646
Many Track Records
Originally Posted by Junior2JZ View Post
Strange
It was an evo 8 that was gutted without a cage.
Old 02-06-2015, 01:44 PM   #48
Nickcrsx
Member#: 196071
700whp in a subaru is hilarious. go home your drunk.
Nickcrsx is offline   Reply With Quote
Old 02-06-2015, 02:15 PM   #49
Nickcrsx
Member#: 196071
Clearly i mean reliable 700whp.
Old 02-06-2015, 02:26 PM   #50
VitorBelfort041
Member#: 177568
2000 2.5 RS
BRP
Closed deck
GTX35R
headwork/cams
upgraded fuel system
35psi on E85
+ Typical supporting mods
Done.
You could take all the brainwork you have to do by just shipping your car to IAG + $$$.
IAG brah
^Ha! Illegal street racing video! lol
VitorBelfort041 is offline   Reply With Quote
