Welcome to the North American Subaru Impreza Owners Club Sunday April 18, 2021
Old 10-18-2007, 09:39 PM   #1
WRXfoME
Member#: 95338
04 WRX - 18g'd
Default After new turbo install, feels like fuel cut-off at 7psi....
I dont think its the restrictor pill. I followed this diagram when putting all my vacuum lines back together. http://forums.nasioc.com/forums/show...estrictor+pill
I have everything in the right location, like the diagram.
I installed an FP 18g, 680injectors, 255 Walbro, and an SS Auto FMIC. Along with my already installed TBE and Uppipe.
I got a basemap from XXChris. I am babying the car but one time going up a hill on the highway, I gave it a little gas and right at .5 bar it felt like I hit fuel cut. Car had no more go in it. I thought maybe I connected some vacuum lines wrong with the turbo, but, after taking everything off, that wasnt the problem. I cant take any pics tonight, but, I will tomorrow. Can anyone think of what else it could be?
Another thing is I had done the 3/16th mod, but, didnt like the results. (This was a few years ago). I lost the stock connector which I believe is 1/8th. Anyways, right now I have a 5/32 connector in place of the 1/8th. I dont think this is the problem either, I havent had a problem since putting it in, Its only 1/32 bigger than the 1/8. Idk, I will stop by Subaru tomorrow and see if I can get a stock one.
Anyone?
WRXfoME is offline   Reply With Quote
Old 10-18-2007, 10:01 PM   #2
subaru222
Member#: 92967
1993 RX-7
dark grey metallic
any leak or anything
subaru222 is offline   Reply With Quote
Old 10-18-2007, 10:02 PM   #3
WRXfoME
Member#: 95338
04 WRX - 18g'd
No, no leaks.... I have one more thing to add that I just thought that might be the problem. On the new turbo, the wastegate needle (where the hose attaches) is facing a different direction than the stock one was. And the hose was cut to fit. I had to move some of the locations of the hoses and I think maybe the line with the restrictor in it is pinched. If the line was pinched, would I still only be getting wastegate boost?
Old 10-18-2007, 10:10 PM   #4
subaru222
Member#: 92967
1993 RX-7
dark grey metallic
ya that only boost
Old 10-18-2007, 10:37 PM   #5
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
im not following, if it feels like your hitting fuel cut everytime you hit a certain psi, how are you getting into restrictor pills and that stuff?
are you saying it wont go past 7psi, or at 7psi you get fuel cut?
PaulRex is offline   Reply With Quote
Old 10-18-2007, 10:50 PM   #6
WRXfoME
Member#: 95338
04 WRX - 18g'd
At 7psi, my car starts stuttering and backing off. Its not just like my boost is maxing out at 7psi. Its weird.
Is it possible to turn the nipple around on the wastegate so that its facing the other direction? or is it stuck where it is?
Old 10-19-2007, 02:43 PM   #7
Silver'04
Member#: 116904
'04 Wagon
Haha, I remember one time I just swapped my catback with another one and didn't reset my ECU. I jumped on the freeway and right at about 7-8 lbs of boost the car just dropped power. I literally could not boost more than 7#, and the car had no power! I got out of the car, disconnected the battery, stepped on the brake a few times, and hooked the battery back up. Started her back up and immediately went back to hitting 17#. Not too sure if resetting the ECU will take care of your problem, but your story brought back some memories.......i was like WTF !
Silver'04 is offline   Reply With Quote
Boost/Fuel cut when reachiung 7psi Jcrite8987 Newbies & FAQs 8 10-01-2009 08:34 PM
Smoke After New turbo Install dlewis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-21-2005 08:14 PM
car not reving past 5k acts like fuel cut off NITROS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-30-2004 10:40 AM
Would like to install a fuel cut off switch cwb124 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-19-2002 03:11 PM
why is my fuel cutting off at 5580rpm? Otaku64 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-16-2002 02:48 AM
