Welcome to the North American Subaru Impreza Owners Club Monday November 11, 2024
Old 05-17-2010, 12:34 PM   #1
JKizzle
Member#: 171848
05 STI
Default 05 STI electrical problem please help
I have a 05 STI and when I connect the battery I get no power to anything but if I run a cable from my positive battery terminal to my alternator pos I get inside cabin power and headlights but no starter power. Does anyone know what this could be? I did realize the fuse box under the hood looks to be missing a fuse where the two studs stick up on the lower right hand side of box. Does anyone have a pic of sti fuse box so I can compare? Also what should I do about the starter. Any help would be greatly appreciated thanks.
JKizzle is offline   Reply With Quote
Old 05-17-2010, 03:33 PM   #2
JKizzle
Member#: 171848
05 STI
bump anyone have a clue?
Old 05-17-2010, 04:50 PM   #3
JKizzle
Member#: 171848
05 STI
bump help please im lost got the head lights and interior on just need the 100 amp sbf no 1 fuse but checked all the others they are good but starter not working neither is the fuel pump any ideas?
Old 05-17-2010, 09:15 PM   #4
JKizzle
Member#: 171848
05 STI
okay so my car was a theft recover car and I dont think the key I have has the chip in it so would that make my starter and fuel pump not work? Im pretty sure that may be my problem but would love some feedback from anyone who has had this problem or knows the solution.
Old 05-17-2010, 11:40 PM   #5
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
There should be an 80A fuse where those studs are in the fuse box. That is a main fuse, nothing will work without it. Replace that fuse and see what happens.
If you don't have the proper key you will need to get one from a dealer matched to the VIN, you will have to prove ownership to get it.
Old 05-18-2010, 01:47 PM   #6
JKizzle
Member#: 171848
05 STI
Must be the key it's not the one with a chip so I guess since it's an 05 it's in immobilizer causing the starter and fuel pump to not work..still doesn't make sense about the blinker and daytime running lights and tail lights not working but the brake and head lights do work..not sure why I checked all fuses and relays so I'm kinda lost on those problems
Old 05-18-2010, 05:08 PM   #7
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I suggest you remove the battery connections and clean the connections using a battery post cleaning brush. Also check all the fuses under the hood using a test light to make sure both sides of the fuse has power. Many people have mistaked a bad fuse for a good one by just looking at it.
Old 05-18-2010, 10:09 PM   #8
JKizzle
Member#: 171848
05 STI
Havent thought of checking the fuses like that I will give that a try in the morning and post the results of my test. Does anyone know what all the immobilizer cuts power to?
Old 05-19-2010, 01:08 PM   #9
Cougar4
Member#: 53443
Winestone
Don't forget to clean the battery connections.
Old 05-19-2010, 07:40 PM   #10
JKizzle
Member#: 171848
05 STI
Havent been able to find what all the immobilizer cuts power to can anyone help me so I know what I cant get power to until I get the key with a chip in it which I ordered already. I just need to know what power gets cut so I know everything else is getting power because Im not sure about this immobilizer situation I have never owned a subby with one before. I did clean the battery terminal today and still no blinkers or tail light but do have brake lights. I cant find my light tester so I guess Im going to have to buy a new one. Anyway if someone can fill me in on some info with the immobizler it would really help me out.
Old 05-19-2010, 08:39 PM   #11
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Have you replaced the missing main fuse yet? If you haven't nothing is going to work regardless of whether you have the proper key or not. AFAIK the engine will still crank without the immobilizer, it just won't start.
Old 05-19-2010, 08:48 PM   #12
JKizzle
Member#: 171848
05 STI
Ya the main fuse is a 100 amp on a STI and Its fine I checked it and that got my power to the headlights interior lights and brake lights working but the starter, fuel pump, blinkers, and tail lights are not working. I checked those fuses and they werent blown just havent had a test light to check them like you stated above.
Old 05-19-2010, 08:54 PM   #13
JKizzle
Member#: 171848
05 STI
I think my nuetral safety switch and the other sensor on the tranny not sure what it is I need to look it up but they are not connected because I have a built 5 speed in this sti and I think the wiring harness may be different but im not sure I will have to research that or find someone who has done a 5 speed swap in a sti. I have put a new low mileage stock 2.5L in, built 5 speed tranny, rear end, axles, hubs, struts, clutch, everything to make the 5 speed work except for the sensors so that may be my problem with the starter but not sure about the fuel pump, blinkers, and tail lights yet.
Old 05-20-2010, 01:07 PM   #14
Cougar4
Member#: 53443
Winestone
I think you are going to find out that you missed a blown fuse in the main panel under the hood.
Old 05-20-2010, 02:55 PM   #15
JKizzle
Member#: 171848
05 STI
Okay so I figured out im missing all kind of electrcal parts under my dash near the fuse box. The blinkers were missing the relay so I had one plugged it in and they work fine now. The anti theft security box was missing on that side also so I had one from my wrx plugged it in and now the door chime works. However there is lots of wire harnesses that are still missing whatever connects to them. Let me snap a pic so I can show you.
Old 05-20-2010, 03:16 PM   #16
JKizzle
Member#: 171848
05 STI
Here is the pics of under my dash its a mess at the moment just need to find out what goes to these harnesses
Heres a pic of the whole thing
Old 05-20-2010, 04:54 PM   #17
Cougar4
Member#: 53443
Winestone
After seeing that last picture you would be wise in purchasing at least the factory wiring manual. It will show the connector details. You can get the info on CD disks for a low price on Ebay.
Old 05-20-2010, 05:07 PM   #18
JKizzle
Member#: 171848
05 STI
There has to be a diagram somewhere or someone who has done a complete sti build that can help me just need to find that person. The manual I purchased sucked it didnt help near as much as google and this forum has. I think I need a subby guru for this one
Old 05-20-2010, 05:25 PM   #19
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Wow, that's quite a mess.
I'd need to go home and look at my car to figure this out...
Old 05-20-2010, 05:27 PM   #20
kpluiten
Member#: 120273
06 WRBWRXWGN
I think those three dangling white/grey ones that are hanging to the left of the last picture below the fuse box are the plugs for the switches that are usually on the STi there including Fogs (if installed), HID leveler, and IC sprayer. I wouldn't worry about those yet.
Old 05-20-2010, 05:31 PM   #21
kpluiten
Member#: 120273
06 WRBWRXWGN
Is the steering wheel installed? Is the column harness connected with the cruise control, horn and airbag connectors?
All Airbag stuff is yellow FYI.
Old 05-20-2010, 05:32 PM   #22
kpluiten
Member#: 120273
06 WRBWRXWGN
Also, have you looked to see if the fuse box is all plugged in?
Is the cluster installed? Are the green cluster plugs (3 of them) present?
Sorry for the 10,000 questions, but I'm trying to get a feel for what is present after this theft.
Old 05-20-2010, 05:36 PM   #23
kpluiten
Member#: 120273
06 WRBWRXWGN
That top picture looks like those are the Radio illumination plugs (white) and the cigarette lighter plugs. What makes me think this is their proximity to that area (center console) and the fact that the black plug has very large prongs which in usually indicative of high amperage circuits like that on the cigarette socket.
I don't have any FSM in front of me, just my memory and the parts catalog at opposedforces.com .
Old 05-20-2010, 05:45 PM   #24
kpluiten
Member#: 120273
06 WRBWRXWGN
I sent you some links that I don't think I can post up... They may help.
Old 05-20-2010, 06:03 PM   #25
kpluiten
Member#: 120273
06 WRBWRXWGN
OK, by my count, this has 7 "pole" as Subaru calls it. (7 pins or terminals) If this is true (are there 7 wires going into it?), then there is only one connector in the interior that has 7 poles and that is "B52" that goes to "Fuse & relay box (F/B)"
Just a guess. But this looks grey and the manual has it as white.
electrical problems please help rs4buddy Normally Aspirated Powertrain 2 08-17-2007 07:31 PM
electrical problems please help rs4buddy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-16-2007 04:23 AM
Another Electrical Problem, Please Help. ric923 Electrical & Lighting 33 06-11-2007 11:46 AM
Major Electrical Problem - PLEASE HELP i102spd Electrical & Lighting 3 11-22-2006 02:20 PM
Strange electrical problem - Please help if you can Rice & Gravy Car Audio, Video & Security 12 04-01-2006 01:48 AM
