Brakes & Suspension Forum sponsored by The Tire Rack |
03-01-2012, 05:44 PM | #1 |
Member#: 279317
Vehicle:2002 wrx wrb |
06 STi subframe and steering rack with 04 STi hubs and LCA's. Will it work?
What's up fellas. I have a 2002 WRX with 04 Sti 6 speed, hubs, axles, lca's and struts. I recently acquired a 2006 Sti front subframe, steering rack, steering column and hubs. I don't have the money to buy new rotors, wheels and struts so I'm gonna hold off on doing the hub swap as of now.
My question is, can I swap the subframe and steering rack and retain the 04 Sti hubs, LCA's and sway bar? Is the steering column different? Do I need to change it? Is there anything else I need to get?
03-01-2012, 06:44 PM | #2 |
Member#: 71875
no problem at all.
03-01-2012, 08:19 PM | #3 |
Member#: 279317
I'm not gonna have a problem with alignment? Toe in or toe out? The LCA's will bolt up to the subframe? What about my motor mounts? Can I reuse them? They're pretty new. Lol. Is the steering column worth upgrading too?
03-01-2012, 09:17 PM | #4 |
Member#: 71875
well, yeah you should check the toe after changing all that stuff out, but everything will bolt up just fine. 04 and 06 sti use the same LCAs. you have to use the 06 sti rack with the 06 subframe (they changed for 05), and it's little quicker so that's a plus. You should also use the sti linkage between the column and rack because it doesn't have a chunk of rubber in the middle of it.
How does a Cobb Accessport work and will it work with my parts? | Twin_Cities_WRX | General Community | 5 | 03-08-2009 01:39 AM |
WTB: WRX steering rack or 04 STI rack. 02-03STI hoodscoop STI steering, 04 gold BBS's | Davenow | Private 'Wanted' Classifieds | 3 | 05-01-2007 05:52 PM |
04 sti struts and springs on a 04 wrx wagon.. will it work | OvrClkdPmp | Brakes, Steering & Suspension | 3 | 07-11-2005 11:32 PM |
v6/v7 sti seat - does it come with airbag or will it work with side airbag? | maaw | Interior & Exterior Modification | 4 | 05-27-2004 01:37 PM |
Will the JDM STi Spec C steering rack fit in the USDM 04 STi? | Mach5WRX | Brakes, Steering & Suspension | 7 | 09-20-2003 11:20 PM |
