Welcome to the North American Subaru Impreza Owners Club Sunday January 21, 2018
Old 05-19-2001, 10:41 AM   #1
cakagan
Member#: 251
1998 Impreza 2.5 RS
Question MY98 owners - what intake/exhaust do you have?
OK, I'm still plugging away at my research for the MY98 RS and figure this is the best place to start gathering specific info.
The '98s have a MAS (IIRC), so aftermarket electronics aren't needed, correct? What CAIs or mods do you all have on the car? Please be specific in listing the make and model of the CAI, any differences it's made, and definitely any problems you've had.
Do the '98s have two air boxes? If we do and you've installed the drop-in gasket (the plastic frame w/o screen), please post what differences it's made and any problems you've had (if any).
And lastly, what exaust are you using? Again, post any differences in performance and any problems you've had. What is best to upgrade first, the intake or the exhaust?
Thanks for your help! More questions to come...
-Chris
cakagan is offline   Reply With Quote
Old 05-19-2001, 11:30 AM   #2
2yLiTe
Member#: 660
Post
MY98 RBP with STI exhaust. Excellent sound (no droning) and good flow.
Rallispec intake due in 1.5 weeks.
2yLiTe is offline   Reply With Quote
Old 05-19-2001, 03:13 PM   #3
JayE
Member#: 5023
1998 RS
RBP
Post
I got rid of the airbox and installed an MAF adapter and cone filter. It sounds nice and deep at WOT and like a vacuum cleaner at idle. Pretty sure I gained some power. I also had a custom 2.25 cat-back installed with a Dynomax muffler(couldn't make myself pay $300 for a muffler). Borla header is on the way now. And I also have a UOR pulley. The best mod I made though was a 22mm sway bar. By far the most fun addition so far. Hope the info helps.
JayE is offline   Reply With Quote
Old 05-19-2001, 03:15 PM   #4
JayE
Member#: 5023
1998 RS
RBP
Lightbulb
I forgot, I did the cone filter thing after first trying a K&N drop in. I didn't feel any difference with the K&N.
Old 05-19-2001, 04:06 PM   #5
HpiRally
Member#: 3864
Post
Minnam Intake with stock exhaust and nothing else. I hope this isnt bad. If so someone let me know.
Joe
[This message has been edited by HpiRally (edited May 19, 2001).]
HpiRally is offline   Reply With Quote
Old 05-19-2001, 04:41 PM   #6
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Post
-'97 Legacy intake tube w/ stock air filter box and Amsoil panel filter. Have to feed a bit more throttle off idle because it delete the pigtail and the black chamber immediately before the throttle body,(the 2.5" exhaust might have something to do with it also). Excellent throttle response. Sounds and look factory stock.
-Tanabe Hyper Medallion 2.5" catback. Nice sound, w/ an off throttle burble.
The only thing I would do different is to get a system with 2" - 2.25" exhaust pipes.
Albert
[This message has been edited by Albert (edited May 19, 2001).]
Albert is offline   Reply With Quote
Old 05-19-2001, 07:42 PM   #7
98mpreziveRS
Member#: 972
Post
when i had my98..i was honestly too lazy to do an induction kit..so i just pulled an airfilter and left it alone other than that.snorkus and all remained..
the exhuast..well..if you feel like shelling 600 for a muffler with no piping i can hook you up with a company that does custom rally exhaust... sounded SWEEET, just beyond the legal limit..with a silencer
Anyhow..enjoy them DOHC ej25's.
98mpreziveRS is offline   Reply With Quote
Old 05-20-2001, 12:26 AM   #8
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Post
Did I read correctly...you ran the car without an air filter?
Old 05-20-2001, 06:52 AM   #9
[email protected]
Member#: 548
'98 Impreza RS
dinged up faded black
Post
still workin' on it. k&n filter and that's about it... I'm empting the cookie jar on a paint job first ('cause of a nice little chevy truck that hit me and split). Hopefully after that I can get something going... well, ummm... suspension, exhaust, suspension, intake, 99+ bumper... yeah, well it'll get there eventually.
mike
minix42@ is offline   Reply With Quote
Old 05-20-2001, 08:29 AM   #10
Stubaru
Member#: 2073
15 AMG 45
Cthulhu Gray
Thumbs up
Weapon R intake is one of the best IMHO, very loud, but only when you want it to be, if you caress the pedal its quiet, if you stop the pedal it roars. Its perfect for the 98 because our air flow sensor is one of the stronger ones produced. So there's no worries about it breaking.
Stu
Stubaru is offline   Reply With Quote
Old 05-20-2001, 05:34 PM   #11
cakagan
Member#: 251
1998 Impreza 2.5 RS
Question
Can someone tell me whether the '98 RS has 2 airfilters or not?
And what is a MAF adapter and why do we need one? Isn't the sensor OK, as Stu stated?
Thanks,
-Chris
Old 05-20-2001, 06:34 PM   #12
JayE
Member#: 5023
1998 RS
RBP
Post
98's only have 1 filter. The box that sits right behind the throttle body is just an empty box. I think it makes the intake quieter and also holds some air to help with low rpm acceleration. The MAF adapter I was talking about is just a coupling that lets you remove the air box and bolt a cone filter to the MAF tubing.
Old 05-20-2001, 09:11 PM   #13
Overtime
Member#: 1346
Post
The Turn3 intake I have on MY99 is designed for MY98 and earlier. It's a 4.5" opening K&N cone filter with a Stillen adapter and a heat shield. Very nice setup, but it doesn't fit the MY99 I have perfectly. Anyone here interested in it?
Overtime is offline   Reply With Quote
Old 05-20-2001, 09:37 PM   #14
98mpreziveRS
Member#: 972
Post
yeah you read that right..i ran with no airfilter for a little while..just a peice of filter from a airconditioner you know..the blue foamie filter stuff..cut it to fit, threw it on, worked OK, not great..so i just put a K & N flat panel in and kept it that way.
Old 05-21-2001, 04:52 AM   #15
MichiganRS
Member#: 3069
Post
I am running a custom piped 2.25" eliminated farthest cat and res. using a dynomax turbo muffler for the small cost of 125 plus muffler which was 30 woohoo saved what like 400 from stainless straight through mufflers kits that actually would have hurt more than gained. Speak of gained I am thinking of running a larry gainz kit but my concern is that cold air pipe work running and getting water sucked by those huge puddles Impreza owners can't resist I donnu how far it goes down though.....anyone?
PS...98s R fastR
MichiganRS is offline   Reply With Quote
Old 03-01-2002, 08:31 PM   #16
Will98RS
Member#: 15816
1998 Impreza RS
Question 98 mods?
i just got a used 98. what mods do all you MY98 owners have? what do you recomend?
will
Will98RS is offline   Reply With Quote
Old 03-04-2002, 02:27 AM   #17
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Turn3 R&D Cold-Air Intake Kit with MRT Performance Secondary Bonnet Scoop (http://www.mrtrally.com.au/). Stock exhaust. Great performance and sound. Make sure to seal around the edges of the secondary scoop or water will drip through the cracks directly onto the filter when it rains. No water gets sucked in when moving, even when pouring.
Here is the secondary scoop (replaces passenger side hood vent):
And the intake:
The remains of the silencer (the two empty tubes sticking out of the fender into the engine bay) have been removed and sealed over with metal heating tape to seal up the cold air box as much as possible.
Fear the Trunkmonkey. There is no cone.
Trunkmonkey World Headquarters | Trunkmonkey Racing
[email protected] | What is a Trunkmonkey?
Somebody set up us the WRX. All your rice are belong to us!
Sean is offline   Reply With Quote
Old 03-04-2002, 02:34 AM   #18
Sean
Member#: 518
762 PGT Impreza L,
Default Re: MY98 owners - what intake/exhaust do you have?
OK, regarding water. If you open up your hood vents water will drip in. Opening up the vents also sucks air AWAY from the intake. Bad. Adding the secondary bonnet scoop, however, pushes more air into the intake. Yay!
No, the 98s do not have two air boxes. The box towards the throttle body is just a baffle to keep the noise down and the torque up. Removing the baffle will decrease low end torque while adding high end horsepower. This is tuning. Sacrificing the low to get the high.
A complete list of mods for my MY98 can be found at:
http://www.trunkmonkeyracing.com/v00...rprofiles.html
A complete list of mods for WAC's (Wayne's) MY97 can be found at:
http://wac.addr.com/auto/obs/obs.html
Sure, we drive the Impreza 2.2 OBS but most of the mods are compatible. With the exception that we've upgraded to 2.5 RS brakes (which you already have). Duh.
Old 03-06-2002, 09:47 PM   #19
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Here we go. On my MY98 Brilliant Red RS coupe, I have done the following.
CAI: Modified JC Sports Intake. Used parts from Larry Ganz and a PRM filter to create CAI with the MAF adapter. Pictures of the install and final product can be found HERE This added an awesome sound to WOT. As for HP increase and the like, it's hard to say, but things seemed to breath easier, and it just opened up the boxer sound some more.
Exhaust: Recently put the Brullen header back system on the car. Dual 3.5" tips fill the whole in the rear bumper and it has 2.25" piping, pretty much the limit of NA cars. It came with a high flow cat as well. It sounds great and there is a definite difference in the way the car pulls and sounds. I love the system so far, and the MY98 electronics haven't had a single problem with the new system at all. That's what I love about it so far. It's not picky about things, and adapts to changes really well.
AJ711 is offline   Reply With Quote
Old 03-09-2002, 01:04 AM   #20
Will98RS
Member#: 15816
1998 Impreza RS
midnx03 this is exactly what i want to do! i have been saving pictures and talking to people. i talked to larry ganz and he recomened a cone style intake but i wanted to use the fender to get cold air and no one makes one for the 98.
any info you have that would help be duplicate what you did would be great. im going away for two weeks but after that i will be back to hound you til i find out how to make that intake
im really excited to find someone that did exactly what i wanted
you are cool!
will
Old 03-12-2002, 02:28 AM   #21
5252
Guest
Member#:
I believe I have the most developed supercharged Impreza in the United States. It has an Eaton m62 pushing twelve lbs through a front mount intercooler and reads down to 39 degrees intake charge temp (N.Idaho winter). The exhaust is three inch from the heads to the black tip. Needless to say it has a full street/strip built engine, is extensivly ported, and sports a dogbox trans. It is a hairy hairy beast., to say the least. I am a very lucky individual.
Almost 100 pics at www.printroom.com under the album name "breathless"
Old 03-16-2002, 08:42 PM   #22
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Albert
Just want to add that the hesitation that I [most DOHC] originally had at 3600-4000 rpms is gone and the car pulls strong to redline. It could be a combination of the filter and the intake but I never removed one or the other to verify. I have also installed an UR pulley and a quicker spool-up is definately noticable. If you want to look stock get a K&N or Amsoil type filter at the very least.
Future plans include a "cleaned-up" and balanced oe flywheel with the CM Stage 3 clutch kit that I have sitting in the garage since last fall, the warranty replacement has less than 15k miles on it and is still holding.
If the STI is more than $32K TOTAL out the door I [might] have keep my '98 and will probably install the centrifugal SC that Templar will soon release. I personally have stayed away from a turbo because I wanted a system that I can easily remove for smog inspections.
Exhaust Thread - What exhaust do you have? JeffyLube General Community 3 05-14-2009 08:27 PM
RS-Ts what exhaust do you have?! trilap5e Normally Aspirated with bolt-on Forced Induction Powertrain 15 06-09-2003 10:54 AM
What kind of Exhaust do you have? and have you been busted? nu2rex New England Impreza Club Forum -- NESIC 36 02-27-2003 12:17 PM
What exhaust do you have? chrisj Mid Atlantic Impreza Club -- MAIC 17 10-13-2001 09:14 PM
What Exhaust do you have? GQ Mid Atlantic Impreza Club -- MAIC 12 05-19-2001 10:33 AM
