Welcome to the North American Subaru Impreza Owners Club Sunday May 20, 2018
Old 05-15-2017, 04:52 AM   #11301
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
I pump Sunoco 93 only, I go to different stations to minimize the chance of ending with **** fuel.
D-Rodman is online now   Reply With Quote
Old 05-16-2017, 11:14 AM   #11302
akturbogti
Member#: 119474
01 Jdm sti
black
I am in New Zealand and have a jdm bug eye sti, I only put 98 in the car and I still need to pull timing.
akturbogti is offline   Reply With Quote
Old 05-16-2017, 11:28 AM   #11303
D-Rodman
Member#: 110078
05 Saabaru JDM STi
I'm taking the car to a local Subaru performance shop to have a proper boost and exhaust leak test. I don't think there are any leaks but I want to make sure. Our 93 oct fuel is as good as it gets round here other than $10 per gallon race fuel.
Old 05-16-2017, 07:35 PM   #11304
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Default EJ207 Owners?
98 in new zeland is 92/93 in north america.
up in canada we have 94 which 101 on your scale. (tested at 101.4 to be exact)
Titter is offline   Reply With Quote
Old 05-17-2017, 10:25 PM   #11305
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Went to MR Performance in Westbury NY (Long Island) today for a boost leak test. It was my first time there, excellent crew, cool shop. No boost leak was found, very happy about that, found my new favorite local Subaru performance shop.
Old 05-19-2017, 01:18 PM   #11306
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
*sigh* it's been quite a while since I needed to post in here. I have no where to start.
Morning commute as always. started up the car and let it idle for a little bit and everything seemed normal. I get about 3-5 miles away or so from the house and while waiting for the traffic light to change to go on to the freeway I notice the idle sounds weird and is starting to climb when i'm out of gear and CEL is on. I pull over and turn it off and restart it and still sounds ****ed up like an exhaust leak. I have no other alternative than to drive back home. Pulled up RR on my laptop and pull these codes =\
P0102
P0113
I think i got these two because i pull the MAF connector to see if idle changed. it did a little
P0335
P0340
P0562
P1507
never ever got these codes before
iNfEk is offline   Reply With Quote
Old 05-19-2017, 04:33 PM   #11307
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
My guess would be camshaft position sensor died
Gigs90 is offline   Reply With Quote
Old 05-19-2017, 05:27 PM   #11308
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Thanks for the reply. ****. Why would it just die and how do I know which one it is? Are the JDM versions different?
Old 05-19-2017, 06:45 PM   #11309
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
you can check the cam position sensors through RR by logging the VVT advance. And yes the JDM sensors are different. IAP carries them if yours are dead.
fastnoypi is offline   Reply With Quote
Old 05-19-2017, 06:48 PM   #11310
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Thanks! What am I looking for when I look at that log? I'm at work right now so I cannot really look it over until I get home later on today. I plan to reset the ECU and try to start it again and see which codes pop up.
I have already been on their website looking it over. Thanks again
Old 05-19-2017, 07:09 PM   #11311
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Its been a while since i logged, my laptop died a while ago but if i recall you need the engine to come up to temperature and select the vvt banks you can see them advance. IIRC if both advance more than 10* when driving they are good. Otherwise its just straight up oil pressure adjusting the cams slightly.
Old 05-19-2017, 07:18 PM   #11312
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
The engine idle is weird though. Would that cause it?
Old 05-19-2017, 11:45 PM   #11313
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Ok finally home from work. Cars cold. Hooked up the tablet and reset the ECU. started the car and no CEL. Tried to get it to go to normal operating temp and idle. It hung around 1100-1250 and then finally threw P1507.
I'm not running coolant lines to the throttle body and have changed out the gasket many many years ago along with cleaning the whole assembly. Am I seeing an IACV issue?
EDIT: also, anyone know where I can get replacement IACV connectors on the engine harness? I tried to remove the connector and the clip broke.
Old 05-20-2017, 12:10 PM   #11314
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You can always just zip tie the connector together for now until / if you find the new ones
Samurai Jack is offline   Reply With Quote
Old 05-20-2017, 03:44 PM   #11315
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
already a head of you. Thanks! Know where I can get one?
Old 05-20-2017, 07:26 PM   #11316
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Cars running "normal" again after cleaning the mostly clean IACV and replacing the gasket with a spare I've had for a while. I still do need the IACV connector though but the zip tie is holding it in. Idles back to normal and revs fine now. Maybe because the IACV gasket was stretched out slightly that while I was driving it triggered the various codes I got. Hmm. Thanks for the help guys.
Old 05-21-2017, 02:33 PM   #11317
Samurai Jack
Member#: 21145
2002 Enemy of Aku
This question has been asked before.
I believe the answer was you won't be able to find new ones available by themselves. You will have to buy an engine harness and scavenge the connectors from the harness you buy.
So, look for a used harness but get pictures of the connectors before you buy
Old 05-21-2017, 02:51 PM   #11318
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Thanks. I've come to that realization
UGH! It's back. Idk if it's the IACV being faulty or something else. Ran the car for a short distance (not even a mile) after full warm up. No CEL. car idle hangs around 800RPM. but after coming to a stop RPM climbs before trying to go down which isn't normal. Throws a CEL then when it goes down again clears. ****. P1507
Did a reset on the ECU. Engine idle at about 1550 for about 10 minutes before trying to go down. Hanging at around 1000 and isn't going down. No CEL just yet.
IACV is clean. Connector is connected via zip tie. Gasket was replaced with a spare. I wonder if it's not sealing
EDIT: replaced gasket with 3M sealant since the gasket stretched a little bit. Still not running right. Must he the IACV =\ might have to replace it.
Old 05-21-2017, 09:09 PM   #11319
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Sounds like you are going to have to replace the iacv, I've had 2 go bad on me exactly the way you are describing. The one on my car is starting to act up if I sit in traffic, the warmer the day is the faster it starts to misbehave. I'll be replacing it soon.
Old 05-21-2017, 09:46 PM   #11320
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Thanks. Sigh. I have another spare on the side but don't have a gasket to use which could be the culprit and it's squeaky clean inside.
I'll go pick up a cheap one that comes with a gasket just in case. I do want to buy a Subaru one but they're pretty expensive.
Old 05-22-2017, 12:56 AM   #11321
D-Rodman
Member#: 110078
05 Saabaru JDM STi
You must have a brand new gasket anytime you remove the iacv screws, the gaskets stretch the first time it takes heat. Both my JDM STi motors had the iacv go bad soon after first starting them. It's a $300 part at the dealer, ouch.
Old 05-22-2017, 07:08 AM   #11322
Samurai Jack
Member#: 21145
2002 Enemy of Aku
It may not be the chamber, but the electronic connection. Either way, sounds like you need to replace the IACV an gasket.
Don't buy a cheap one. You'll just be replacing that in short order. There is a reason why a $300 OEM part can be had for ~$60 from someone else, allegedly a "genuine" part.
It may not be much, but you can get the part slightly cheaper if you buy from a on-line Subaru Parts Dept.
https://www.ebay.com/p/?iid=141824151879&&&chn=ps
$235 from SubaruPartsOnline
The EJ207 v7 and the 2002WRX share a lot of parts, so this would be a direct swap
Old 05-22-2017, 11:12 AM   #11323
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
I agree. I just don't want to spend the $300 if I don't need to.
EDIT: just ordered the gasket and IACV from subaru. I think I found a source for an IACV connector. If it works I'll post in here with where I got it and their part number. fingers crossed!
Old 05-24-2017, 08:50 PM   #11324
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
so my brand new replacement engine harness arrived from IAP along with the replacement connector i found online showed up today.
From a visual it looks like a good match and a possible replacement for the IACV connector. I will check fitment...etc. when i get home later on tonight.
Old 05-28-2017, 05:42 PM   #11325
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
S204 engine got a full timing service this weekend
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
