Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 09-18-2017, 10:42 AM   #11426
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Default EJ207 Owners?
its probably the coolant hose between the timing cover and the exhaust manifold on the front of the motor. it goes from the thermo housing to the oil modine.
Titter is offline   Reply With Quote
Old 09-18-2017, 03:03 PM   #11427
ddaley60
Member#: 211988
05 v9 ej207
Ill give it a check when i get back from work. Its not a lot of coolant but it builds up and runs down the oil pan and/or the rad hose. Hopefully its something as simple as that.
ddaley60 is offline   Reply With Quote
Old 09-18-2017, 10:43 PM   #11428
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
its a sneaky hidden hose thats notorious for leaking due to the heat of the exhaust manifold.
Old 09-19-2017, 07:49 AM   #11429
ddaley60
Member#: 211988
05 v9 ej207
update, both hoses around the water pump are clean no cracks or signs of a leak, for the $6 they are i still am going to replace them. Didn't have any drips during the day yesterday or evening but there were drips when i went out this morning but only underneath the radiator (drips through that little hole in the front subframe). So its only in the front and its only at night, temps have been between 50-60 lately.
Old 09-20-2017, 09:59 AM   #11430
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Have you checked both radiator hoses to be sure the connections are tight?
Have you checked the two small coolant hoses that run from the expansion tank down to the radiator?
Samurai Jack is offline   Reply With Quote
Old 09-21-2017, 12:56 PM   #11431
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Anyone have a part number for a version 8 IACV gasket or USDM compatible model?
Psychoreo is offline   Reply With Quote
Old 09-21-2017, 06:13 PM   #11432
08OBS
Member#: 274397
2005 WRX V9 207
2018 Colorado Duramax
I believe it's the same as an EJ205 gasket. From doing some research I found this p/n.
22659AA120
08OBS is offline   Reply With Quote
Old 10-02-2017, 12:49 PM   #11433
salvi
Member#: 188132
Did everyone who swapped to the 207 get tuned right after the swap? I'm currently finishing up my friend's v9 swap and he doesn't want to double spend on tuning. He was wondering if he could run the car with the stock ecu and get tuned once he has upgraded injectors, dp, etc.
salvi is offline   Reply With Quote
Old 10-02-2017, 01:29 PM   #11434
Samurai Jack
Member#: 21145
2002 Enemy of Aku
What ECU is he planning to use? USDM or JDM?
Either way, you have no idea what tune is on the ECU to be used, so not a good idea to use something you have no idea about.
Who is doing the tune?
He may be able to get a base tune for now, and then get a complete tune by the same Tuner after his upgrades.
The cost of the base tune would be applied to the final tune
Old 10-02-2017, 02:59 PM   #11435
salvi
Member#: 188132
Using the JDM ecu.
Old 10-02-2017, 10:28 PM   #11436
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
get it tuned. very least load a base map from romraider.
otherwise have him sign a waiver that he knows driving his car untuned *may* cause damage.
Old 10-03-2017, 11:57 AM   #11437
08OBS
Member#: 274397
2005 WRX V9 207
I got tuned the week after my swap. For that week I was driving on a JDM ECU not using boost. I suggest getting a tune asap. It's worth the reassurance that everything is running correctly.
Old 10-04-2017, 12:40 PM   #11438
salvi
Member#: 188132
I'm going to advice my friend to tune as soon as possible.
We got the engine running late last night. The jdm power steering pump was whining bad even after adding proper fluid levels. Has anyone had this and how did you remedy the issue?
Old 10-04-2017, 01:10 PM   #11439
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
I run Castrol Dexron 4 trans fluid in mine and my 163k mile 2003 Wrx power steering pump has no issues
Gigs90 is offline   Reply With Quote
Old 10-05-2017, 12:06 AM   #11440
jdm05
Member#: 180155
05 Jdm Sti 2.0
Black stone results
Any input from others will gladly accept, thanks again.
jdm05 is offline   Reply With Quote
Old 10-05-2017, 11:33 AM   #11441
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Copper seems a little high but overall it looks healthy
This is mine
Old 10-05-2017, 12:39 PM   #11442
jdm05
Member#: 180155
05 Jdm Sti 2.0
Thanks ^ gigs90
I compared yours to mine, I知 wondering thoughts on redline vs motul and I only use the car in summer and store it for the winter if that makes any difference. Anything to check for to decrease copper %? Thanks
Old 10-05-2017, 12:46 PM   #11443
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Originally Posted by jdm05 View Post
Thanks ^ gigs90
I run Motul in my 2006 LGT and Redline in my 207 Wrx both are quality oils.
I drive the Wrx so little now it gets one or two oil changes a year maybe , Redline seems to hold up very well on the track.
Old 10-05-2017, 12:57 PM   #11444
jdm05
Member#: 180155
05 Jdm Sti 2.0
For sprinted driving and summer driving would redline be an overkill? I知 thinking of running it next and compare results
Old 10-05-2017, 12:58 PM   #11445
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Not at all , I know a bunch of BMW guys and they literally run Redline all year in their Time attack cars changing it once a year.
Its good oil.
Old 10-05-2017, 01:00 PM   #11446
jdm05
Member#: 180155
05 Jdm Sti 2.0
Great will try it out next
Old 10-06-2017, 02:15 AM   #11447
salvi
Member#: 188132
Finally got my friend's bugeye running with the 207 after replacing the IACV.
We r having a weird issue though. The will start but after u shut if off and try to restart it, nothing, won't even crank. We also see the security light blinking on the cluster.
I was able to turn it back on by removing the neg battery cable and quiclkly starting it. As soon as we shut it down, the issue returns.
Is there an issue with running ps fluid instead of Dexron? I had them bring ps fluid and they didn't know it was suppose to be Dexron.
Old 10-06-2017, 12:26 PM   #11448
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Why would you think using a quality oil like Redline be overkill?
You WANT to use quality lubricants in your car, not the cheapest stuff you can find.
Old 10-06-2017, 12:29 PM   #11449
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Try re-setting the Security mode as described in your Owner's manual. That will probably clear up the issue. It's not just disconnect battery and then re-connect.
Owners manual states that the ATF should be DEX II or DEX III type ATF.
It also states that the P/S fluid should be DEX IIE or DEX III type.
Subaru specs this type of fluid for a reason. Using a non-specified fluid will damage the system.
You can use either for the PS fluid.
Old 10-06-2017, 01:44 PM   #11450
jdm05
Member#: 180155
05 Jdm Sti 2.0
I don稚 really thinks it痴 overkill just saying it lol. I believe I have only used quality oil (motul) and parts too. Will be using redline next to compare results
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
