Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2020
Old 01-16-2014, 09:12 PM   #526
mathiasfinkel
Member#: 378960
mathiasfinkel is offline   Reply With Quote
Old 01-16-2014, 09:37 PM   #527
rexblake
Member#: 178426
2010 S4
Gray
Originally Posted by ciege125 View Post
Thinking about running NGK one step plugs, but have read on a few sites that they arent nesecary and can even be harmful if your motor isnt putting down enough power..? Any truth to this? I was planning on throwing those with a fuel pump and ebcs on my stage 2
You don't need them. Don't run them. Once you go a couple hundred ho over stock you might need them depending on fuel.
Old 01-23-2014, 01:12 PM   #528
dIrTy-StI
Member#: 322280
2002 Subaru WRX
I have a 2002 WRX Goal number is 300 whp on a mustang dyno using 93 oct in Pennsylvania
Mods:
-Cobb Sf Intake
-Cobb accessport
-Invidia V2 Catless down pipe
-Invidia N1 catback
I know this will require a lot but any help would be awesome
-Thomas
dIrTy-StI is offline   Reply With Quote
Old 01-23-2014, 02:10 PM   #529
rexblake
Member#: 178426
2010 S4
Gray
Mods:
-Cobb Sf Intake
-Cobb accessport
-Invidia N1 catback
-Thomas
20g, injectors, fuel pump, fmic.
Old 01-23-2014, 04:29 PM   #530
Razgeiz
Member#: 358782
2013 STi
You don't need an FMIC. An upgraded TMIC would be more than sufficient.
Razgeiz is offline   Reply With Quote
Old 01-23-2014, 04:34 PM   #531
rexblake
Member#: 178426
2010 S4
Gray
True, but a fmic would work better. More efficient.
Old 01-29-2014, 02:58 AM   #532
Goneau
Member#: 362269
2016 WRX
ISM
2006 WRX 5 speed want to daily and get 320/320
also want peak tq before 4k would be amazing. looking at 18g 8cm?
mods will be as follows
header/up combo (invidia)
TurboXS tbe catless
gs pnp intake mani
short ram intake (brand undecided)
gs EBCS
walboro 255
dw 750's
turboxs FMIC
bigger inlet?
clutch and flywheel
bov or ewg?
pistons and rods will most likely be done because of high mileage on motor
Goneau is offline   Reply With Quote
Old 02-03-2014, 12:22 AM   #533
tjmazz13
Member#: 291681
2004 Pearl White STi
IAG1000, PTE6870, Haltech
2004 STi looking for atleast 400whp/400wtq.
Mods will be:
2013 shortblock
CP pistons
Killer B oil pick up
Killer B oil baffle
ARP headstuds
TurboXS rotated turbo kit
AGP 50 trim turbo
TurboXS rotated FMIC kit
Tial MVR 44mm ewg
Grimmspeed EBCS
Invidia midpipe
3in straight pipe
Modded 820cc injectors
Walbro 255lph fuel pump
Competition Stage 3 clutch
tjmazz13 is offline   Reply With Quote
Old 02-05-2014, 03:40 PM   #534
rexblake
Member#: 178426
2010 S4
Gray
Mods will be:
2013 shortblock
CP pistons
Killer B oil baffle
ARP headstuds
AGP 50 trim turbo
Tial MVR 44mm ewg
Grimmspeed EBCS
Invidia midpipe
3in straight pipe
Your link is for a SRT-4 turbo? Also, a gt3076 would be perfect for ya. Or the newer gtx3071. Particularly in rotated. Also would be cheaper than some proprietary AGP turbo (who apparently is using old tech anyway). Also, go with 1000cc injectors, no reason to go smaller. And are you sure you want a straight pipe? It's going to be unbearably loud.
Old 02-05-2014, 03:44 PM   #535
rexblake
Member#: 178426
2010 S4
Gray
TurboXS tbe catless
gs pnp intake mani
gs EBCS
walboro 255
dw 750's
turboxs FMIC
bigger inlet?
clutch and flywheel
bov or ewg?
Get 1000cc injectors, no reason to go smaller. Plus, if you want more you can easily throw a bigger turbo on with no issues.
A BOV and a EWG are two very different things. The EWG lets exhaust escape so you don't over boost, the BOV vents boost from the air intake when you let off the gas. To very different things, research both some more.
A bigger turbo inlet pipe is a pain to fit, but you will probably want to run an aftermarket one just so it's easier to put on and off. The stock one cracks very often when you remove it, particularly on these older cars.
Old 02-09-2014, 01:01 PM   #536
Goneau
Member#: 362269
2016 WRX
ISM
Idk why I worded it like that lol. I will have a bov and it was more of a should I invest in an EWG setup, is it necessary
Old 02-21-2014, 12:34 PM   #537
Fawkes_STI
Member#: 380833
2013 Impreza WRX STI
Sparkling Silver
i have an 2013 sti sedan and i want to be putting around 500-550hp to the wheels
not sure what type of dyno ill be on, im trying to find some really good shops in the area and really havent any good luck, i want things to be done right with some of the best parts. this the planning process for me im gonna get the basic stuff along the way but i plan on getting these parts and installing them around june/july.
I live in the bi polar state of Texas in Houston
Whatever suggested by you, I recently came to becoma an owner of a Subaru from a mustang gt, and 550hp at the wheels would typically be 93 octane.
and im perfectly fine with those FMIC!
I come from a race enthusiast type of family. my brother just bought a ZR1 and that car makes mine look like a prius, i want to be able to hang with it if not beat it.
Fawkes_STI is offline   Reply With Quote
Old 02-24-2014, 01:53 AM   #538
tjmazz13
Member#: 291681
Yeah I know a lot of SRT-4 people use this turbo but the whole rotated kit is already on my car, and this turbo is 50lb/min and a 30r is 52lb/min so not too much smaller. 820cc's have been in the car for months so I'm not changing them out lol, and the straight pipe has been on my car too and I love it.
Old 02-25-2014, 03:12 PM   #539
STIgirl18
Member#: 283000
2009 STI
panda
2009 STI
would like to hit as close to 350whp as i can
probably going to turboXS to get protuned
I live in Baltimore, MD
Current Setup:
Cobb AP
Cobb SR intake
TBE with no cats
parts i have awaiting install:
UEL GTspec headers
IAG uppipe
Tail 44mm wastegate
Perrin EBCS
Perrin Lightweight crank pulley
i want to upgrade my intercooler but idk if i should go with TM or FM?!?
any info is apreciated!
STIgirl18 is offline   Reply With Quote
Old 02-27-2014, 02:53 PM   #540
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Originally Posted by STIgirl18 View Post
2009 STI
Current Setup:
Cobb AP
Cobb SR intake
TBE with no cats
UEL GTspec headers
IAG uppipe
Tail 44mm wastegate
Perrin EBCS
I'm not an engineer but you said anything is appreciated so here is my 'get what you pay for' opinion: Can't say if 350 is possible but to get close with that set up it would probably take an aggressive tune and/or E85. I think many will say you need bigger injectors, a bigger fuel pump, and an ECBS. What I hear about intercoolers tends to be 1. Stay top mount unless you're using a bigger turbo 2. FMIC's take a little longer to spool.
My best advice? Contact a reputable tuner in addition to what you see on here.
Also, see if you can find an equivalent setup here http://forums.nasioc.com/forums/show...ht=vf48+thread
Here is how one guy did it: http://www.iwsti.com/forums/power-br...hp-360wtq.html
In this post some guy lists mods needed: https://www.toronto-subaru-club.com/...t-350-whp.html
Cheers and props on the EWG can't wait to get mine on.
joek92 is offline   Reply With Quote
Old 02-27-2014, 03:50 PM   #541
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
Looking to get 300 whp for my wrx, is a turboback all i need?
WhatsASubie is offline   Reply With Quote
Old 02-27-2014, 04:02 PM   #542
itsAllgood
Member#: 378398
2013 WRX sedan
Dark Grey Metallic
I wish! An exhaust doesn't give as much HP on our cars as other cars.
itsAllgood is offline   Reply With Quote
Old 02-27-2014, 04:37 PM   #543
chillengillon
Member#: 342422
Red
I have a '11 WRX with catback, intake, custom mild tune. looking at injectors, fuel pump, dp. Wondering what other mods I would need to reach my goals:
1. HP at the WHEELS (whp) or hp at the CRANK (chp)?
300-350whp would prefer closer to 350whp
2. What type of dyno are you going to be shooting for this number on?
DynoJet
3. If possible, tell us what shop it is. Someone may know how high or low that particular dyno reads.
Most Likely Moore Automotive
4. Where do you live? If not a well known city, what is the elevation?
Front Royal VA
5. What kind of gas will you be using? (octane level)
91
6. Are you opposed to a FMIC?
Would rather stay TM
chillengillon is offline   Reply With Quote
Old 02-28-2014, 05:32 PM   #544
STIgirl18
Member#: 283000
2009 STI
panda
Originally Posted by joek92 View Post
I'm not an engineer but you said anything is appreciated so here is my 'get what you pay for' opinion: Can't say if 350 is possible but to get close with that set up it would probably take an aggressive tune and/or E85. I think many will say you need bigger injectors, a bigger fuel pump, and an ECBS. What I hear about intercoolers tends to be 1. Stay top mount unless you're using a bigger turbo 2. FMIC's take a little longer to spool. My best advice? Contact a reputable tuner in addition to what you see on here. Also, see if you can find an equivalent setup here http://forums.nasioc.com/forums/show...ht=vf48+thread Here is how one guy did it: http://www.iwsti.com/forums/power-br...hp-360wtq.html In this post some guy lists mods needed: Cheers and props on the EWG can't wait to get mine on.
Thanks! I actually changed my mind and I am skipping the TMIC and going with ID 1000cc injectors, walbro fuel pump and then gettin protuned after putting the rest of my parts on.
Old 02-28-2014, 06:25 PM   #545
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
So if i get turboback, intake and a tune, what is my whp? What have other people gotten? I dont want to get bigger injectors fuel pumps and what now.. least not until my warranty is over( want to be able to do quick swap out). I know the intake wont do much, but will the turboback and tune get me to 265 whp? I want to at least make what subaru advertised at the crank to the wheel. If not what else can i do?
Old 02-28-2014, 07:41 PM   #546
rexblake
Member#: 178426
2010 S4
Gray
Buy a different car. You are looking at 40-60k in mods and questionable reliability.
Old 02-28-2014, 07:42 PM   #547
rexblake
Member#: 178426
2010 S4
Gray
You should be able to hit that with a tbe, intake, and tune. Even on pump gas (on almost all dynos anyway).
Old 02-28-2014, 07:46 PM   #548
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
does catless or catted matter?
I know people say catless makes more power, is it a lot more?
Old 02-28-2014, 07:46 PM   #549
loboilermaker
Member#: 380420
2014 WRX
Ice Silver
If it helps 280 whp with invidia q300 tbe and aem intake and tune on 2014 wrx.
loboilermaker is offline   Reply With Quote
Old 02-28-2014, 07:52 PM   #550
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
OO i like those numbers! Do you have catted or catless? what dp are you running? ots cobb tune or pro tune?
what do I need to hit 250whp? juvenescence Newbies & FAQs 29 01-15-2019 02:38 PM
What do I need to hit 350-375 HP? pipchick Newbies & FAQs 60 01-15-2019 02:38 PM
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-14-2010 11:49 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 06:43 AM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
