Welcome to the North American Subaru Impreza Owners Club Thursday January 18, 2018
Old 01-11-2018, 09:19 PM   #1
Chf9663
Member#: 480445
Default Remote start
I got my wifeís 2014 Outback and she hasnít used the remote start for 3 years. Now I drive the car I would like to use it but it doesnít work. Itís a dealer installed remote start. When you push the start button the horn beeps once then the lights flash once and then the horn beeps 3 times but it doesnít start. I would appreciate any help thanks.
P.S. my wife drives the new 2018 WRX and I replaced my 2002 outback with the 2014 outback
Chf9663 is offline   Reply With Quote
Old 01-11-2018, 09:53 PM   #2
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Is it a manual?
Manual you need to follow special procedure (usually allow engine idle in neutral, set hand brake, get out and close door, then lock the car, engine will shut off after you locked the car), that way the remote starter knows your car is safe to be remote started.
jasonwrx86 is offline   Reply With Quote
Old 01-12-2018, 12:58 AM   #3
Chf9663
Member#: 480445
Itís a automatic
Old 01-12-2018, 01:44 AM   #4
ThinWRX
Member#: 401876
2008 WRX
Try pressing the button 3 consecutive times.
ThinWRX is offline   Reply With Quote
Old 01-13-2018, 09:36 AM   #5
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
If it is an OEM Subaru remote start first thing I would check is the hood switch. Right side of the engine compartment, inner fender, forward of the VDC module (ABS). It could be broken, loose, or the bracket bent. Other than that about the only other thing is it has become unmarried from the immobilizer.
Elbert Bass is offline   Reply With Quote
Old 01-13-2018, 07:45 PM   #6
Chf9663
Member#: 480445
Thanks for all the replies I have tried pushing the button 3 times already.
This is a dealer installed Subaru remote start, the remote start fob is separate from the key fob
Old 01-13-2018, 09:08 PM   #7
cerbomark
Member#: 475983
point towards car, press twice and wait for remote to beep/flash, then press again and it should start.
cerbomark is offline   Reply With Quote
Old 01-14-2018, 07:52 AM   #8
Blktrax
Member#: 220971
2002 WRX 223K Mi.
Does the vehicle have a Check Engine light on?, see below.
When attempting the remote start system, the ignition powers briefly then shuts down followed by three (3) horn honks. The system attempts to restart the vehicle three (3) additional times with the same result.
- This condition indicates that the vehicleís BIU has
processed a CAN message request to the RES module
preventing it from remote starting the vehicle.
* This usually occurs when a vehicle DTC or component
failure is present. Resolve any vehicle component or
DTC concerns prior to attempting to activate the remote
start system.
Blktrax is offline   Reply With Quote
Old 01-15-2018, 09:32 PM   #9
Chf9663
Member#: 480445
No check engine light. With no check engine light how do you know what issues are present.
Old 01-15-2018, 10:58 PM   #10
Blktrax
Member#: 220971
2002 WRX 223K Mi.
It needs to be checked with a Subaru Diagnostic Monitor (SSM3) to read faults in the Body Integrated Unit (BIU)
Old 01-16-2018, 09:41 AM   #11
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Have you checked with the dealer?
