03-21-2010, 07:09 PM | #1 |
Member#: 140799
BAIC
Vehicle:2007 WRX Satin White Pearl |
Rear swaybar question
Hey guys so im just starting to get into autoxing and im debating on whether or not to add a rear sway bar to my set up. My main concern is how to keep the car from three wheeling around the track, my current set up is as followed.
2007 wrx vf-39 sti topmount cobb catted dp, greddy tic catback zeal function xs coilovers 8k front 6k rear cobb front swaybar with whiteline endlinks whiteline steering rack bushing stock rims with 225/45r17 direzza star specs. I dont have my exact alignment with me but its something like 1.5 camber in the front and .58 camber in the rear with zero toe all around. Right now ive been running novice class street mod and the car still pushes. Im in the process of looking for different rims i think im gonna end up running 245's or 255's most likely stick with street tires for now. Any input would be helpfull
03-21-2010, 08:49 PM | #2 |
Member#: 61536
Vehicle:WRX' 04Road02gravel www.ToltecRally.com |
IMO, you already have too much tension in the suspension w/ those spring rates, a stiff(er) rear anti sway bar will add more. But to each his own...
03-21-2010, 09:03 PM | #3 |
Member#: 180430
South East
Vehicle:2008 335i |
Coilovers are the key. You need more droop travel to keep all 4 wheels down.
Also why are you so concerned with lifting the inside rear. It's not as critical with the wrx compared to the STI because of the viscous lsd. |
03-21-2010, 11:08 PM | #4 |
Member#: 71875
different spring rates will help. for the cheapest fix switch them front - rear, although less of a differential and softer springs would be preferential, especially for street tires. Somewhere in the range of 400f, 450r would be best. And yes, get a rear swaybar.
wait, are they 600lb/800lb, or 6k/8k? Last edited by jamal; 03-22-2010 at 02:50 AM. |
03-22-2010, 03:50 AM | #5 |
Member#: 140799
BAIC
oh sorry i meant to say 8k/6k
03-22-2010, 07:03 AM | #6 |
Member#: 128002
International
Vehicle:2023 Toyota 4Runner Silver |
If you just add a rear sway bar, the car will feel unstable at high speeds. Your rear end will come out when you least expect it. Get both front and rear sway bars to be on the safe side.
03-23-2010, 07:05 PM | #7 |
Member#: 37359
Vehicle:2003 WRX |
Can you have a local expert autoxer give the car a drive? Sometimes driving adjustments are the answer if the car appears to be pushing a lot.
Also, if your struts are adjustable, have you tried stiffening up the rears and/or adjusting tire pressures. That way you can get the back looser and adjust it back for daily driving. |
03-23-2010, 07:40 PM | #8 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Instagram | arthurlam89 |
Stiffer front springs and more camber.
03-23-2010, 11:57 PM | #9 | |
Member#: 140799
BAIC
I have been getting advice from a co-worker and autoxer Scott Fraser, who has driven my car and is helping me set up my car and we have been arguing about me getting a rear sway bar or messing with springs. So for this weekends autox im going to try more camber and see how it goes. We have adjusted the shocks which have helped but its still not right. |
Similar Threads | ||||
Rear swaybar question | minx1225 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 08-29-2005 06:06 PM |
STi stock rear swaybar question | Kaze | Brakes, Steering & Suspension | 10 | 06-27-2005 11:59 AM |
Front & rear swaybar questions | QAScooter | Forester Forum | 9 | 08-12-2002 11:06 AM |
Cusco Front & Rear Swaybars Question | natasha talarico | Brakes, Steering & Suspension | 14 | 05-10-2002 09:40 AM |
front and rear swaybar question | psaeko | Brakes, Steering & Suspension | 7 | 02-14-2002 03:11 AM |
