04-13-2013, 01:07 AM | #201 |
Member#: 188219
VIC
Vehicle:2007 2.5i Ltd. CGM |
I don't think my current halogen projectors have it, but I won't know for sure until I bake the lights open again. It's been more than 2yrs since I've had them open so I can't remember.
Is it safe to say that the D2S bulb and ballast don't require this ground wire though? I bought these projectors used I was told that they are 07 STI projectors. They may have been used in a previous retrofit, is it possible that the piece that looks like an aluminium sort of rear shroud that the ground wire is attached to is from the halogen projector? I notice the OPs STI projectors don't seem to have that aluminium rear shroud/guard piece. Edit: Nope, that aluminium guard is definitely part of the projector housing and it keeps the bulb clip in place. I don't think it's actually a big deal but I would prefer to connect the ground since it's there, just wondering if there is a ground to connect it to inside the housing?
04-13-2013, 07:30 AM | #202 |
Member#: 239452
Vehicle:2012 Volvo S60 T6 2005 Outback 2.5i |
The bulb does not need this ground wire. I am not sure where that came from as my '07 STi projectors didn't have them, and my '10 WRX projectors did not have them either.
04-15-2013, 11:17 AM | #203 |
Member#: 338329
Vehicle:2017 STI Lapis Blue |
I removed those ground wires on mine. No need for them!
Did my OEM STI w/ TSXR lens retrofit this weekend. This thread helped a ton! Here's my post! http://forums.nasioc.com/forums/show...1#post39591635 http://imgur.com/NfzLV7N |
04-15-2013, 11:36 AM | #204 |
Member#: 261730
Vehicle:17' GTI |
Ditto^ This thread was a great help for my recent project, replacing my Mini D2S with RX-AFS w/ custom curved shields:
http://forums.nasioc.com/forums/show...&postcount=114 @ ~25ft: Testing the shields indoors: |
04-15-2013, 12:22 PM | #205 |
Member#: 239452
Looks like you had greenkouki from HIDplanet do the shield mod job? Very nice.
04-15-2013, 12:42 PM | #206 |
Member#: 261730
Vehicle:17' GTI |
Yep! It was well worth it, he's legit
05-02-2013, 04:14 PM | #207 |
Member#: 334215
Vehicle:2015 Forester Silver |
great thread
05-14-2013, 09:58 AM | #208 |
Member#: 239452
05-14-2013, 10:07 AM | #209 |
Member#: 261730
Vehicle:17' GTI |
Sweet
05-20-2013, 10:21 AM | #210 |
Member#: 239452
Here are some of his supplied images. I should be getting the projectors today so I'll take a few shots of them as well, compared to the OEM setup and the TSX-R with OEM shield.
I'm super stoked to try them out. He was impressed by their immense width after the custom shield work. |
05-21-2013, 10:14 AM | #211 |
Member#: 261730
Vehicle:17' GTI |
Wow they look great. Sti projectors can be modded pretty effectively
05-21-2013, 10:28 AM | #212 | |
Member#: 239452
The OEM fresnel lens shots are straighter, so it has to be lens curvature. |
05-25-2013, 08:48 AM | #213 |
Member#: 64405
E. Canada
Vehicle:2018 STi WRB |
Glad to hear you found the reason for the dreaded bowing! Haha that was one hard to find it appears. So you can order tsx-r ajd not get the same focal point as the next order or was it early vs later batches?
Edit: I guess if greenkouki could not get rid of the bowing entirely nobody will haha |
07-09-2013, 02:30 PM | #214 | ||
Member#: 343078
South East
Vehicle:2013 WRX Hatchback SWP |
I just did my retrofit this weekend and didn't get the cut off I was expecting. (STI projectors w/ tsxr lenses) Here is a pic of my cutoff... Is this the "bow" you are talking about? |
07-09-2013, 02:56 PM | #215 |
Member#: 239452
Yep, that looks exactly as mine did unmodified. Unfortunately, I had no idea how to fix it. My deduction is sloppy manufacturing tolerance with TSX-R lenses, as there's nothing else non-OEM in my setup, and I've seen both bowed upward and bowed downward with identical setups over and over again on this forum.
07-09-2013, 03:09 PM | #216 |
Member#: 169537
NESIC
Vehicle:1999 Legacy GT 05 Wrx Swap |
bowing is caused when the lens is shorter or taller than OEM lens. In order to fix this you need to space the lens farther away OR closer to the projector bowl. Add washers between the sheild / lens section to space it, to bring the lens closer u need to take a dremel and slightly bring down the area where the screws go into the lens holder. (IE make them shorter)
-B your 2nd option is to make a custom shield. When a custom shield is made you can alter where the shield sits, and can easily move it towards or away from the lens. this is the STi projector with tsx lens and custom shield (from allum flashing) is used. |
07-09-2013, 04:32 PM | #217 | |
Member#: 343078
South East
Do you offer custom shield / tuning services ? |
07-09-2013, 04:34 PM | #218 |
Member#: 169537
NESIC
I do make custom shields and tune projectors and do full retrofits. I've been doing it since 2005 in hidplanet.com and done numerous lights on nasioc, i just dont advertise cause I'm not a legit business, its more of a hobby
-B |
07-09-2013, 04:42 PM | #219 |
Member#: 169537
NESIC
07-09-2013, 04:49 PM | #220 | |
Member#: 343078
South East
07-09-2013, 10:23 PM | #221 | |
Member#: 239452
greenkouki made my shields (output shots in post #210 above), and he couldn't eliminate the bowing completely either, although the bowing is reduced still and the width increased tremendously. The width is on par with my Fusion fog projectors. Sadly, none of the other 2.5" lens options would fit the holder, so he couldn't try another lens with a different focal length and lens curvature profile, although from what I know, most of the other clear lens options are taller than the OEM (22.5 mm). I remember someone one here claiming that the GD had clear 2.5" lenses on their Euro spec HID cars. I would love to get my hand on those and see if they would fix the issue. Maybe the answer would be a polished OEM lens such as those polish jobs done on RX350 lenses. |
07-09-2013, 10:44 PM | #222 |
Member#: 169537
NESIC
how about e30 lenses? i mean for the amount of work going into this, people should just buy a pair of rx330 non-afs projectors for the install. I've done custom work with these projectors before and had better much results than Oem sheild with tsxr lens
-B edit* I re-read yoru post on tsxr batch of lenses being off. I'd recommend an S2k lens than those are more rounded and crystal clear lenses found only in the ap1's |
07-09-2013, 11:04 PM | #223 | |
Member#: 239452
If I hadn't already owned a set of OEM STi bowls, I might have just gone with some 330 AFS's (however, they were also an issue to mount apparently, based on honestabe's install, the sets out now seem to be all symmetric whereas the earlier versions were all side specific and easier to mount without having issues with the vertical adjustment screw). IIRC you had a few sets in your huge projector sale just recently, and I debated picking up a pair from you. I also tried to get the pair of OEM STi's you had to send to greenkouki instead of taking my lamps apart and sending them to him, but someone else beat me to it quick. I haven't seen too many pairs of AP1 lenses sans projector bowls. That might be a fun project to try if I get a hand on one, I have one more STi projector sitting around that I want to dabble and tinker with in the near future for fun. |
07-10-2013, 09:40 AM | #224 | ||||
Member#: 343078
South East
If the lens is taller, did you have to bring the lens closer or further away to the bulb? I was thinking the tsxr lens needed to be further from the bulb but it sounds like you are suggesting bringing it closer to the bulb? Quote:
I thought the black series were also a 2.5" diameter? |
07-12-2013, 08:54 AM | #225 |
Member#: 239452
Is the additional .1mm really significant?
If the lens is taller, did you have to bring the lens closer or further away to the bulb? I was thinking the tsxr lens needed to be further from the bulb but it sounds like you are suggesting bringing it closer to the bulb? The lens has to be closer if you want to remove bow. Unfortunately, the only way to do that is to grind the black lens housing. However, I don't think the issue was the lens focal height. I think the issue lies in the lens convexity from bottom to top. How long did it take greenkouki to make your custom projectors? Recommend his work? It took him a couple of days to do it. I would highly recommend his work. Width and brightness will increase, and color will be amazing. FWIW though, there are better projectors than the STi, so there's that. I thought the black series were also a 2.5" diameter? The diameter of each lens base can vary by several mm. Since the black holder uses a snap-in retention to hold the lens in, the sizing of the lens has to be exact. |
My WRX...Now With 100% More Car Frog | DonkeyPunch | Member's Car Gallery | 60 | 10-13-2007 10:38 AM |
2006 Aspen White STI pics.. now with 100% more Gram Lights | SCRAPPYDO | Member's Car Gallery | 12 | 09-18-2007 06:23 PM |
The Exeter Subaru meet june 18th- $25 06 STi raffle- now with 100% more autox | Keith | New England Impreza Club Forum -- NESIC | 129 | 06-19-2006 02:13 PM |
My SVX, now with 100% more STi! | Bwana | Member's Car Gallery | 48 | 05-20-2005 11:27 PM |
Impreza: Now with 100% more STi lip action | Versus | Member's Car Gallery | 36 | 04-16-2005 08:58 PM |
