Welcome to the North American Subaru Impreza Owners Club Tuesday September 26, 2023
Old 04-27-2023, 12:51 PM   #1
wantsti
Member#: 134764
04 sti
java black pearl
Default Are King pMaxKote worth the extra price?
I'm trying to decide what bearing to use for my new build on a +2mm ej25. Are the king pMaxKote bearings that much better? They are almost double the price of the regular king xpg bearings but if they will help prevent a spun bearing I'm ok with the price. Does anyone have experiance with these?
wantsti is offline   Reply With Quote
Old 06-19-2023, 11:02 AM   #2
spoolinsti05
Member#: 108051
2005 WRX ST5
I was also debating on getting those bearings. They seem worth it. But the old ones did great on my old build. Trying new parts can be a little risky. So I might personally stay with the tried and true since they worked fine.
Sent from my moto g 5G (2022) using Tapatalk
spoolinsti05 is online now   Reply With Quote
Old 07-12-2023, 09:27 PM   #3
spoolinsti05
Member#: 108051
2005 WRX ST5
Nobody tried them yet?
Old 07-19-2023, 07:11 AM   #4
Unabomber
Big Ron
Super Moderator
Member#: 18062
on car parts so PM
me b4 j00 buy
Marketing says "15% - 30% greater load capacity than traditional bearings" and this metric has nothing to do with longevity. If you are trying to make 900WHP, maybe go with these, but normal/tested/known bearings are fine. Plus this is a new/proprietary thing for them and I'm shy to try something unknown. I'm making 400 for over 100k on my built motor on some Kmart bearings....I'm of the opinion that a solid build is more a part of your right foot than the components used.
Old 07-19-2023, 08:15 AM   #5
Lenny01STi
Member#: 534844
2001 JDM WRX STi WRB
2005 WRX STi Silver
While I can't speak too much on the longevity, I built an EJ257 with these recently, they looked great, and of course high quality as King's products always are. Great fit and finish.
Lenny01STi is offline   Reply With Quote
Old 07-27-2023, 07:34 PM   #6
spoolinsti05
Member#: 108051
2005 WRX ST5
I am probably going back to oem bearings honestly. I was thinking about it a few year back. Jr tuned my stock engine to 512whp and the bearings looked great more then i can say about the ringlands though on piston nunber 2.
We also made 525whp and 650whp on the king race bearings with stdx size on mains and rods and acl (std mains stdx rods) bearings previous. Both didnt look great after.. however the build i did with the kings in those clearances looked the best with some slight wear marks afterwards though i also had a few detonation events. Due to injector sealing issues and another issue with a ecu pinout connection. That i repaired using i wire parts. Then had a fuel pressure issue due to over running the regualtor at 42psia. So i cant really blame the bearings. In fact considering the events and a few lean situations my engine build that i personally built took a beating and handled it well.
Old 07-28-2023, 10:21 AM   #7
cboggess
Member#: 30804
87 Yugo
Red
There is absolutely NOTHING wrong with the stock bearings. They are good. They are also more expensive, and don't have the size ranges of aftermarket. Hence why everyone runs aftermarket.
If you can get OEM in the sizes you need to hit your clearance then go for it.
cboggess is offline   Reply With Quote
