Welcome to the North American Subaru Impreza Owners Club Tuesday September 26, 2023
Old 06-19-2013, 12:35 AM   #126
Josh909
Member#: 167725
2004 WRX
Bump because this might be my next step with my motor issues
Josh909 is offline   Reply With Quote
Old 10-24-2013, 12:48 AM   #127
Rally2
Member#: 132023
2005 STI
blue
Bump for same boat as above
Rally2 is offline   Reply With Quote
Old 04-04-2014, 07:31 AM   #128
Silverbullet_07
Member#: 281910
OP, did you have to take the hood off?
And has anyone else used the intake manifold as a place to lift the engine? Kinda worried about the weight messing up something
Silverbullet_07 is offline   Reply With Quote
Old 04-04-2014, 07:56 AM   #129
BeastianSTI
Member#: 310506
2005 WRX STi
CGM
Originally Posted by Silverbullet_07 View Post
OP, did you have to take the hood off? And has anyone else used the intake manifold as a place to lift the engine? Kinda worried about the weight messing up something
I've used the intake manifold as the hoisted point multiple times before. Also used a couple of bolts like the power steering in conjunction with them.
You do not need to the the hook off or anything. I draped a towel over the front bumper just for protection. The key is to make sure you have an even hoist point so that both sides are pulled up evenly. Also make sure there isn't too much slack in the chains. Your Crane will hit the hood, if the tension point is too high due to too much chain.
BeastianSTI is offline   Reply With Quote
Old 04-04-2014, 08:08 AM   #130
BeastianSTI
Member#: 310506
2005 WRX STi
CGM
Believe it or not, the block isn't that heavy lol. I'm not weak but i pulled the short block off the engine stand and put it on my bench. The crank is heavy. Heads are maybe 60 lb total or something. I think the entire block weighs like less than 350lb, but don't quote me on that
Old 04-04-2014, 08:57 AM   #131
ToneWrx02
Member#: 239095
2002 Wrx
Long block is heavy ish(more awkward to grab). Short block pfft if someone cant lift that they seriously need to hit the gym.
ToneWrx02 is offline   Reply With Quote
Old 04-04-2014, 09:03 AM   #132
BeastianSTI
Member#: 310506
2005 WRX STi
CGM
Maybe it's just us Swedish ;-) but i'd agree. Two people could probably pull the engine out by hand if the quarter panels and frame wasn't there haha!
Old 04-09-2014, 09:45 AM   #133
ToneWrx02
Member#: 239095
2002 Wrx
Ha i actually thought of doing just that when i couldnt get a engine lift.
Btw im mexican, living in Sweden. Ya i know weird.
Old 01-10-2016, 11:13 PM   #134
PhillyPhan90
Member#: 351013
2006 WRX TR
Crystal Gray Metallic
Must say, thank you. Followed your walk-through and the motor came out without a hitch. Had to use the pry bar, but used hardly any effort when I did. Now to tear it down, put all on the new shortblock and hope that it goes back it almost as easy as it came out.
PhillyPhan90 is offline   Reply With Quote
Old 08-16-2016, 06:14 PM   #135
Impreza_wrx_03
Member#: 404040
2003 Impreza wrx
Originally Posted by beavis820 View Post
9. Remove starter
I already had 1 bolt out so the top bolt that is sticking out had a ground on it.
There is a 1 wire plug and a big wire on a stud like the alternator.
10. Remove turbo. Straight forward when you have a UR GT35R. Comes out on the uppipe.
11. Transmission bolts. Theres a bunch don't miss any.
And a nut WAY down on both sides.
No pic on the drivers side but it's there.
Pitch stop has to be unbolted in the front
12. Disconnect clutch fork from throwout bearing.
10mm hex
Thread something in. I use 1 of the battery tie downs (stolen idea from themadscientist)
OH MY GOD!!! thank you soooooo much, without this thread I never would have gotten my motor out, we were stuck for two days then I stumbled upon this tread and you saved our lifes. No one has said anything about the pin that hold the throw out fork. Yours was the only post that had it and it was the only problem. Thanks again.
Impreza_wrx_03 is offline   Reply With Quote
Old 08-16-2016, 08:41 PM   #136
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
Lol, I told you in your other thread to remove the clutch fork pin!!!
monkeyposeur is offline   Reply With Quote
Old 08-16-2016, 09:01 PM   #137
Impreza_wrx_03
Member#: 404040
2003 Impreza wrx
Yeah, but you didn't tell me you had this thread for me to look at... I just happened to find it about 4 hours ago lol. I didn't know what I was looking for until I found this thread.
Old 01-02-2018, 03:36 PM   #138
xVern
Member#: 241860
2008 LGT
Damn, i'll be doing this soon and these photos would have really helped. Stupid photobucket.
xVern is offline   Reply With Quote
Old 01-18-2018, 11:19 PM   #139
Harey
Member#: 270569
'15 Foz XT & GT86
Great thread, my brother and I lifted the longblock out of the bay by hand haha
But I was parting the car out so wasnt too worried about scratching anything etc
Harey is offline   Reply With Quote
Old 11-14-2019, 09:11 PM   #140
GK1707
Member#: 373868
'04 STi
pics arent working anymore, can we get an update on those. would be really helpful
GK1707 is offline   Reply With Quote
Old 05-24-2023, 12:38 AM   #141
yinwrx
Member#: 534365
Default Help
have a question, i’m new to the subie community or jdm cars in general and just picked up a 2005 wrx and the head gasket is blown i just purchased another engine for it car came with aftermarket headers , downpipe , aos , cobb intake , access port and exhaust i just want to know what i should purchase to support those mods and what i should replace while the new engine is out on the engine stand ?
yinwrx is offline   Reply With Quote
DIY: Pull your engine winterfourever Service & Maintenance 28 12-18-2018 10:29 PM
How to pull your oil pan without pulling the motor ihadmail Service & Maintenance 55 11-27-2017 09:49 PM
DIY: Piecing together your own stealthback exhaust Donzo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-17-2008 11:20 PM
Making your own wrist pin pulling tools reddevil Built Motor Discussion 14 08-24-2007 06:06 PM
Lots of pics from Lane Motor Museum, Nashville sigurd Member's Car Gallery 13 02-22-2007 09:11 PM
