Welcome to the North American Subaru Impreza Owners Club Tuesday September 26, 2023
Old 01-27-2014, 09:05 AM   #26
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
hey walter, which coils did you end up getting?
ken
Old 02-02-2016, 09:15 PM   #27
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Sorry for the ancient bump, but I'm trying to sort out the difference in coil pack boot length. It's been mentioned several times, but which ones are longer never seems to get answered.
I have a new set of oem subaru 04+ sti coil packs and am running ngk bkr6eix11 iridium plugs. My heads are the 97 jdm 2.0 with the chambers converted to newer wrx 2.5 style to match my built 2.5 block. I've been running an apexi powerfc which was designed with dwell controlled internally and to run the wasted spark setup, instead of using wasted spark I've been running aftermarket beck/arnley coil on plug packs and have fried one recently. (I also fried one of the old used oem coil packs years back a matter of months after converting to coil on plug). The reason for them dying may be from the way the apexi ecu is programmed to fire wasted spark coils, maybe a dwell time incompatibility.
The haltech I will be installing soon will allow me to adjust dwell for the new coil packs, so that won't be an issue. What I want to be sure of is that the boots on the coil packs are sliding over the ngk plugs far enough for the internal spring to press on the ends securely, and that the boots seal snug and keep water out. I will be running higher boost with the ethanol sensor and the new ecu and don't want any weakness in the spark department.
Which ignition coil boots are longer, 02-05 usdm wrx oem or 04+ sti wrx oem? The coil packs I bought are the 22433AA541 model. If the 02-05 coil boots are longer, would I be able to just buy a set of those boots and swap them? The boots on mine are easily removed and reinstalled.
Thanks for any help
Old 11-24-2017, 04:01 PM   #28
jonoc4
Member#: 387455
2010 STI Hatch
bumping this rather than starting a new thread. searched and found just a bunch of for sale posts.
Coil pack part # 22433AA602 says fitment is:
FORESTER 11-13 w/turbo
IMPREZA 11 (2.5L), w/turbo
IMPREZA 12-14 2.5L (turbo)
LEGACY 10-12 2.5L, w/turbo
I have a 2010 STI, what is different from the 2010 that they'd have a different coil pack
jonoc4 is offline   Reply With Quote
Old 11-24-2017, 09:56 PM   #29
Alex_Is_Dead182
Member#: 478130
2002 Impreza WRX
Gun Metal Grey
Originally Posted by 01lgtsleeper View Post
its like a cadilac escalade compared to a suburban its all in the name man, some people are purists and wont buy it unless it says sti! (great chance for subaru to make some money.)
This is why USDM bugeyes are targeted for STi products ***128517;
Alex_Is_Dead182 is offline   Reply With Quote
Old 10-22-2019, 01:09 AM   #30
DatGriff
Member#: 371326
I recently needed to figure out what coils to buy for my car. There's a lot of conflicting information out there.
Here's what I've gathered:
There are two types of coilpacks, grey and black, with two separate dwell values. There are also two lengths of boots. One length for 2.0 L motors and one length for 2.5 L motors.
This, as far as I've gathered, only applies certain versions of EJ motors.
02 - 03 USDM WRX use 2.0 L length black coilpacks. These coils correspond to the V7 JDM motors.
04 - 05 WRX use 2.0 L length grey coilpacks. These coils correspond to the V8 and V9 JDM Motors.
06 - 08 WRX use 2.5 L length grey coil packs. These are never used in JDM motors.
USDM STI 2004+ use 2.5 L grey coilpacks. These are never used in JDM motors.
You can use either color coilpack on any of these motors if and only if you are able to modify the dwell time in your tune to match the color of the coilpack you use. All four coils must be either black or grey. No mismatching. Boots may be swapped between a 2.0 L length coil and a 2.5 L length coil.
I hope this alleviates someone's confusion in the future.
DatGriff is offline   Reply With Quote
Old 03-24-2020, 08:54 PM   #31
gc8fxt
Member#: 393747
Hmm... my Legacy (BP5; gt spec b; JDM) takes:
22433AA480 - original part #
22433AA540 - superceded
22433AA640 - superceded
22433AA641 - superceded
So while there may be some differences in the part, it seems strange that they would allow any of these as direct replacements.
This is direct from Subaru Canada SCI Parts Enquiry.
gc8fxt is offline   Reply With Quote
Old 05-02-2020, 02:23 PM   #32
GK1707
Member#: 373868
'04 STi
22433AA602
This is the latest part number for STi coils. Anyone know whats the difference between these and 04 STi coils? They're supposedly an update.
GK1707 is offline   Reply With Quote
Old 05-03-2020, 10:12 PM   #33
dScooby
Member#: 277465
11 STi
04 FXT
Originally Posted by GK1707 View Post
22433AA602
Not sure on the new part #. But the 11+ wrx and sti has a different connector than the 02-10 wrx/sti
dScooby is offline   Reply With Quote
Old 05-04-2020, 10:23 AM   #34
GK1707
Member#: 373868
'04 STi
They both look identical, I have a set of oem 04 sti coils in front of me and currently looking at pics of the 11+ sti coils.
Connectors and everything else look identical except the 11+ coils are black instead of gray.
Old 05-31-2020, 09:39 PM   #35
GK1707
Member#: 373868
'04 STi
22433AA602
Can confirm that these coils will fit 04+ STi, I just installed a set in my 04 and it runs great with a fresh set of NGK step colder plugs.
Old 06-02-2023, 10:41 AM   #36
subiblue2002
Member#: 225666
2002 2.18 stroker
super wagon
Anyone still have knowledge about coils being "Tune specific"?
I'm possibly having an issue with some new NGK coils for my 2002.
Sent from my SM-N960U using Tapatalk
subiblue2002 is offline   Reply With Quote
06/07 wrx vs sti internals ihatehondas Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-18-2011 01:01 PM
wrx vs. sti, whats the difference? b0nd18t Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 04-11-2011 05:20 PM
FS: MA - 2 WRX & 2 STi Ignition Coils Coil Pack Aphex28 Engine/Power/Exhaust 17 09-07-2008 07:53 PM
sti ignition coils vs wrx coils wickedwrx2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-23-2006 07:23 PM
04 WRX vs STi Security Upgrade Differences?? paperchasin Car Audio, Video & Security 3 07-11-2004 03:28 PM
