Welcome to the North American Subaru Impreza Owners Club Tuesday September 26, 2023
Old 04-30-2023, 10:04 AM   #1
Mauled
Member#: 500169
Default How much boost and timing
How much boost and timing can I run on a ej207 v8 with stock bottom end, gtx 3076r + meth, 625 head studs, and built heads with cams?
Right now I'm running 27 psi and 24 degrees at redline but I want more power. How much can I turn it up?
Mauled is offline   Reply With Quote
Old 04-30-2023, 11:47 AM   #2
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
02' EJ205 20G 6MT wagon
We can't tell you this as it varies from engine to engine.
Your tuner is the only one who should be altering timing and boost if you aren't comfortable tuning yourself.
K3rm1tth3fr0g is online now   Reply With Quote
Old 04-30-2023, 01:19 PM   #3
19std
Member#: 510366
Depends on a lot if things you didn't list, but from naisoc water meth sticky:
"I want m@d p0w3r y0! Great! Some have been able to go as agressive as: 3 more PSI, 5 more degrees timing, and 12.5-1 a/f without detonation and safe EGTS!!!!!!!!"
Although i would be more concerned with the torque capabilities and clearances of your rods and pistons at this point cause your already at the big boy boost numbers.
See sticky here:
https://forums.nasioc.com/forums/showthread.php?t=937176
Good lean bedtime reading.
19std is online now   Reply With Quote
Old 05-02-2023, 01:19 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
tyr in small incriments. 24 is a pretty good amount if you want more I would go with a bigger turbo, ie 3576 or the new g30 770, what are you making btw?
subaru_gc8 is offline   Reply With Quote
Old 05-02-2023, 03:25 PM   #5
Mauled
Member#: 500169
I might just get a bigger turbo 3582 or 3576 maybe. I'm just worried about spool it already doesn't spool till 5k. I never dynod it but I'd say its making around 480.
