09-13-2018, 02:30 AM | #1 |
Member#: 10854
SCIC
Vehicle:'02 WRX; '08 OBXT; '08 G37 (S/C'd); '09 XF |
Windows update = not recognizing Tactrix
Hey,
I just wanted to check to see if anyone else was experiencing this issue - I just updated my Windows OS (Cumulative update for Windows 10 version 1803 for X64-based systems; security update for Flash Player for Windows 10 version 1083 ) via the updater, and now ECU Flash doesn't recognize the cable. When I open ECU Flash, it says "No vehicle selected. No vehicle interface." Have any of you experienced this? Is there a workaround? Thanks!
09-22-2018, 05:17 PM | #2 |
Member#: 453872
Vehicle:2005 wrx wagon 48w |
i had issues with ECUflash a month or two ago. i think i just uninstalled it and got the latest version re installed.
09-24-2018, 03:53 AM | #3 |
Member#: 10854
SCIC
I checked the latest version available for download, and it's the same as I was already running. But yeah, maybe a fresh install would do it. Here's another thing though - I tried opening RomRaider Logger, and it wasn't recognizing the cable or car. So it isn't just ECU Flash. And I haven't moved any of my ECU/car definition locations either. Maybe I need to uninstall and reinstall the Tactrix driver...
09-28-2018, 02:57 PM | #4 |
Member#: 453872
possibly. or try a new usb cable.
09-28-2018, 05:39 PM | #5 |
Member#: 10854
SCIC
Update - Got it working!
I tried a new USB cable, that wasn't it. But after going back and forth with Mike at Tactrix (excellent customer service!), we deduced that it wasn't a hardware problem. So I uninstalled/reinstalled the driver and that let the computer recognize the cable. But ECU Flash still wasn't recognizing the car. I tried the RomRaider Logger, and it DID recognize the car. So I uninstalled/reinstalled the ECU Flash software, reloaded the latest Subaru definitions in the Metadata folder, and then assigned the default vehicle. And we're back in business! So in short, heads up - if you update your OS software, you might need to reinstall your software and drivers. |
09-28-2018, 06:30 PM | #6 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
Awesome and thank you for actually sharing the solution.
A lot of guys don't follow up, but you're old school, so you must be good people |
