Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 10-18-2016, 12:45 PM   #1
_bwrx
Member#: 443701
2003 Impreza WRX
Default 02/03 USDM WRX Base map Questions.
Okay guys, I am a super noob to tuning. I know basics about Subaru engines and I am fairly inclined in their mechanical workings. I've done some reading on tuning these cars and all about Knock control and WGDS and all that jazz. I know most of the acronyms but it is still quite confusing. So bare with me if I come off as a "retard" in the tuning definition...
I have been scouring the forums for a while now looking for a good Stage 2 base map to flash and then log to make the correct adjustments. I've looked at testes1010's and have been very interested in the Carberry map that was modified for MAF tuning. I've heard the good and bad in testes1010's map and I don't think I am qualified to even begin with a SD or Carberry map. So I ask to great people of the RR forum. Any suggestions for some maps to flash?
Mods consist of...
USDM 2003 Subaru WRX
Was purchased with a (new to the car) EJ205 - Was told it was a JDM Motor with the JDM ECU, therefor I cannot use a Cobb AP.
Stock TD04-13T
Stock Injectors
Stock Fuel Pump (have a wal255, installing soon)
Stock TMIC
Stock JDM Catless UP
3" Catless Turboback
K&N Panel filter
Running Floridian 93 Octane
Low Altitude and High humidity air where I drive
If any more info is needed let me know.
Thank you all for your help!
Cheers! -Ben
_bwrx is offline   Reply With Quote
Old 10-27-2016, 10:56 PM   #2
iceman.kcmo
Member#: 264683
Go check out http://www.romraider.com/forum/index.php .
I have had a little experience tuning Nissans before the WRX. I did all my reading there for a couple weeks, Then bought a tactrix and flashed a tune. Download all the stuff and a stock base map and start looking at the maps. ROMRAIDER also has descriptions of each map in the options for each map. I don't remember exactly where.
I have an 03 and i used the Testes1010 base map and have been tweaking/logging it for the past 2 weeks. here is where you can find that. Http://www.romraider.com/forum/viewt...hp?f=28&t=4075
Good luck!
P.S. Read all of this too...http://forums.nasioc.com/forums/show....php?t=1410201
iceman.kcmo is offline   Reply With Quote
Old 11-04-2016, 09:32 PM   #3
anjuna
Member#: 401977
IDFK Wat
bish whet
i can send you a "safe" ej205 tune that will be stage 2ish...
anjuna is offline   Reply With Quote
Old 11-01-2018, 06:41 PM   #4
ashikaitc
Member#: 459259
Hi there, can I please get the map ? Thanks
I've an EDM 03 WRX
ashikaitc is offline   Reply With Quote
Old 11-04-2018, 12:00 AM   #5
jasongenelanc
Member#: 493521
Hi may I please have the “safe” ej205 tune as well?
jasongenelanc is offline   Reply With Quote
Old 11-17-2018, 08:17 AM   #6
Smurftastic
Member#: 243697
2002 TOPSCOOB031
HighwaystarGarage
I don't know about any of you, but Testes tune ran lean for me, on account of his modified OL fueling tables. I ended up taking Testes tune, swapping in some richer OL tables, and then MAF scaling, and being GOOD.
Smurftastic is offline   Reply With Quote
